Question about Samsung RS2534 Side by Side Refrigerator
CherryWriter@earthlink.net There is a strange strong acidic, similar of blend of motor-oil/onion/orange, inside my fridge. I have cleaned/washed everything three times. I don't have aby onion or garlic or other products in my fridge. The odor is strong enough imperminates fruits, butter, ice cream, even covered containers. I removed every item inside both the fridge & freezer, washed every item, scrubbed all the walls shelves and bins inside and under everthing. There is nothing inside to explain the odor that has been here for four days. I'm goung nuts trying to get rid of the odor. I even place an open bowl of vinegar over night, didn't work, I tried 2 boxes of baking soda - didn''t work. The odor seems to be from the motor or something or the cooling system. HELP. I have a side by side Samsung fridge/freezer model # RS2530BWP. Many thanks for your suggestions! Mrs Hinkle
notsomot
  • 67 Answers
SOURCE: samsung fridge freezer not cold enough
Heya,
I did samsung warranty for awhile and these fridges have a faulty defrost termination clixon. What happens is when you turn off the fridge it turns it off defrost. If you do get a tech out there are two parts you need to fix it. One is a yellow sensor cable and the other is a defrost termination wire that is black and red. These two parts i use to sell for $70aus when the fridges where out of warrenty.
I actually have one of these fridges now and work so if you have any other problems please let me know
Regards Mat
Posted on Jan 08, 2009
  • 2976 Answers
SOURCE: the freezer has been melting ice-cream
The first thing to do is, give it a FULL DEFROST, the old fashioned way. set it for defrost or unplug it and melt all of the ice out of the air tunnels below and behind the freezer. In the refrigerator section, you will find a hole that you can stick your finger into, normally in the wall next to the freezer. This has the defrost timer in it. Give it a full turn CLOCKWISE to make sure the contacts aren't stuck. When you are sure all the ice is melted and the water has been dried up, power it back up. It will run properly if nothing actually went bad. The next step, if it doesn't work right, is to replace the thermostat.
Posted on May 27, 2010
  • 1531 Answers
SOURCE: my Samsung side-by-side two door RS2530BWP
you will need to use a blow dryer and defrost the back wall.Once that is defrosted then you will need to remove the back panel and defrost the evaporator coil.
There are several things that can go wrong the temp thermostat,defrost thermostat,defrost heater,or control board.you will also need to check the evap fan and make sure it is working.
Posted on Dec 19, 2010
walesarumi
  • 6993 Answers
SOURCE: I have a Samsung RS267LBSH, which is a
When the fridge side is getting too cold or icing up, this is because the control of the compressor has gone bad in some way...
There a few different things that could cause the unit to lose control over the temperature of the fridge side.
If your refrigerator has a damper door that opens and closes to allow cold air to move to the fridge side the damper linkage or the damper motor may have broken or gone bad.
The coils in your fridge may have frozen over and now the air does not move at all so then the ice builds up and can freeze parts of the fridge side.
The thermostat has gone bad and so now the compressor runs continually. This will not be noticed readily on the freezer side but will show up quickly on the fridge side.
Many newer model refrigerators use an electronic sensor or thermistor to read the temperature and supply the info for the circuit board and often a digital readout.
So, here is how I would go about troubleshooting this problem.
Check the coils for ice, defrost the coils with a heat gun or hairdryer, then check for the reason why they iced over. Defrost control or defrost timer bad? Evaporator fan bad?
Check the damper door to see if it is stuck in the open position. If it is then check the motor and the linkage.
Check to see if the refrigeration unit will shut down if the thermostat or digital setting is turned up to a higher temperature. If it continues to run then find the cause and fix it. It may be a bad thermostat, sensor, or control board.
Sometimes with a change is weather to a cooler climate this will be enough to also affect the inside temperatures. Make sure that a bit of adjustment in the thermostat or setting of the temperature will not solve your problem very simply.
I hope the above helps.
Good luck.
Posted on Jul 18, 2011
  • 500 Answers
SOURCE: My Samsung RS2534 side by
Hi mminottoi2004,
It uses a defrost element, built into the evaporator to melt the ice once every 1 - 2 hours. I suspect one of the sensors are failing, or the defrost element is faulty or worse.
You can test the defrost element with a decent multimeter, make sure power is getting to it, in at least 1 to 11/2 hours. If no power ever reaches the element, even when the compressor shuts off, then more likely the problem is the PCB. If power does reach it, but it does not get warm, the defrost emelent needs replacing.
Testing sensors on Samsung models are nearly impossible, so I am not even going to advise it. The resistance readings never make sense.
So in a nutshell: 1) Faulty Defrost Element or 2) Faulty Sensors or 3) Faulty PCB.
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Posted on Aug 15, 2011
2.8 oz of onion straws is how much in cups?
How much Chopped, or Sliced Onions are in a Pound?
www.howmuchisin.com/produce_converters/onion
  1. Cached
  2. Similar
How many onions do you need to purchase to measure 2 cups for a recipe? ... (2 cups), sometimes as a weight (4 ounces) and still others the onion is given ... Ancient Egyptians worshipped the onion; they believed its spherical shape and concentric rings symbolized ... ¼, ½, ¾, 1, 1 ½, 2, 2 ½, 3, 3 ½, 4, 4 ½, 5, 6, 7, 8, 9, 10.
French fried onions : Substitutes, Ingredients, Equivalents ...
www.gourmetsleuth.com/ingredients/detail/french-fried-onions
  1. Cached
  2. Similar
French's is the producer of canned "french fried onion rings" They date back to 1933 but ... 6oz can french fried onion rings = 3 cups / 2.8-oz can = 1 3/8 cups.
Onions, raw, chopped cup measurements and equivalents in grams (g ...
www.cookitsimply.com > Measurements > Onions
  1. Cached
  2. Similar
Onions, raw, chopped cup measurements and equivalents in grams (g) and ounces (oz) ... raw, chopped. equivalent values ... 1/8 cup, 20 g, 0.7 oz. 1/4 cup, 40 g ...
How much is a small/medium/large onion? - Seasoned Advice
cooking.stackexchange.com/questions/.../how-much-is-a-small-medium-large-onion
  1. Cached
  2. Similar
Mar 26, 2011 - Medium onion = 8 ounces, or about 1 cup chopped ... I've often seen large onions that were as big or bigger than "jumbo" according to this data ...
Nov 24, 2016 | Coffee Makers & Espresso Machines
2.8 oz. of dry onion straws is how much in cups?
quarter cup plus a bit
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  2. Similar
There is a strange gaseous smell in the frige
The gas that runs your fridge does not smell. Take the drawers out and clean underneath them - you'll probably find that something spilled and went behind and under the drawers. Or maybe it is just spoiled food. There is also a massive possibility that it is the smell of onions. Bottom line, do a good cleanout of your fridge
Nov 09, 2014 | Refrigerators
What does not go well with cheese
A broad question. Please send more info if you'd like - glad to help. I am posting regardless:
(from website:)
http://www.thekitchn.com/what-not-to-pair-cheese-pairin-148014)
What Not To Pair: Cheese Pairings to Avoid
(We) talk a lot about what makes a great pairing when it comes to cheese, wine, and food. And since cheese is so rarely-- really, too rarely, in our opinion-- enjoyed just entirely on its own, it's especially important to know what foods will heighten your experience of the cheeses you serve.
Equally vital is knowing what not to do. (Oranges and carrots, for example, are just a preview of two things that just won't make your cheese sing.) Here, some don'ts to keep in mind when putting together a cheese plate.
When pairing foods with cheese, your goal should be to highlight both elements equally. Ideally, go for flavors that will accentuate rather than overpower the cheese itself. Similarly, cheeses shouldn't overwhelm what you choose as accompaniments.
The exceptions to the rules below may be fresh cheeses, which act as excellent foils to stronger flavors. But generally speaking, the following things are examples of what to stay away from when constructing a cheese plate with a variety of different styles, ages, and flavors:
Spicy things: There may not be a worse way to kill the flavors of your cheese. While a searingly spicy hot pepper jelly is actually great with a cooling, sprightly puck of goat cheese (see above disclaimer regarding the fresh cheese exception), it wouldn't do anything for the subtle flavors of a semi-soft, natural rinded sheep milk cheese, for example. Veer from olive mixes speckled with dried red pepper flakes, really spicy pickled items, spicy meats, hot jellies, mustards, or chutneys, and even crackers with black peppercorns. While delicious, these accompaniments will linger on your palate and hinder your experience of the cheese in its natural state. Lightly spiced things can be great with cheese, liked sweet, spiced nuts and herbaceous olives. But beware of things that taste more of what was used for flavoring than of the food itself!
Garlic- or Onion-flavored Crackers and Bread: Unless you want to be left tasting the bits of dehydrated onion or garlic that so often sully the surface of breads and crackers, save these items for other moments. And beware of the "Everything" flavor, too, which may have lots of onion and garlic lurking within. Some cheeses, like stronger mountain cheeses and some funky natural rinded wheels, actually have subtle notes of spring garlic or onion. Breads and crackers infused with onion-y flavors can mar these compelling undertones, so beware.
Vegetables: Clearly this is a category that may be a bit too large to generalize, so to be more specific, stick with vegetables that have relatively mild flavors, like sliced fennel and endive spears. Slightly peppery greens like arugula or radicchio can be great compliments to cheese if you're thinking of making a cheese-laced salad. But on a cheese platter, stay away from the most vegetal of vegetables, like broccoli, carrots, green beans, celery, and cauliflower. While these all may make great additions to a crudite platter (and broccoli and cheddar soup is undeniably delicious), they seem straight-up strange to pair raw with nice cheeses.
Citrus or high-acid fruits: Orange segments, grapefruit, kiwi, and pineapple have their place, but not on a cheese plate. While so many different kinds of fruits go seamlessly with cheese-- like apples, pears, grapes, and figs, not to mention all of the dried fruit that compliments cheese so well-- those fruits that are higher in acid tend to turn cheese acrid. My mouth nearly cringes with the thought of the curdling effect these fruits would have on cheese!
Tannic Red Wines are similar to citrus in their ability to turn cheeses bitter. The lingering effect of tannin on cheese can be so negative, you may walk away with an inaccurate opinion of what you're tasting. You'll ruin not only your impression of the cheese, but of the wine, too!
On a final note:
What do you call cheese that 'isn't yours'?
Give up?
"NACHO cheese"
Jul 11, 2014 | Games
What kind of oil do i use for a 2000 dodge carivan?
ENGINE OIL
You will need to use a 10W-30 grade engine oil, such as any of the following Mobil products.
"Fully synthetic" oils are more expensive. Conventional oils or syn blend engine oils are fine for the vehicle but need to be changed more frequently.
Mobil 1 Extended Performance 10W-30
fully synthetic motor oil ;
spacer.gif Mobil 1 High Mileage 10W-30
fully synthetic motor oil;
spacer.gif Mobil 1 10W-30
Mobil Clean 7500 10W-30
synthetic blend motor oil ;
spacer.gif Mobil Clean High Mileage 10W-30
a conventional motor oil;
spacer.gif Mobil Clean 5000 10W-30
a conventional motor oil .
Nov 30, 2010 | 2000 Dodge Caravan
Leaking inside of fridge
i guess u will benifit from this link
plz rate this post
click here
Sep 02, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Fridge smells
Are there any drip channels in the back or bottom of the interior of the unit that may be clogged? These channels collect condensate and feed them to a pan under most refrigerators. I assume you have removed bottom food storage drawers and cleaned inside. Also try open box of baking soda which absorbs odors.
Feb 26, 2008 | Refrigerators
Samsung RS2534 Side by Side Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
