Question about EuroCave Performance 83 Wine Cellar
EuroCave confort vieillitheque. have two units built in. both units ice up on the back wall, LED displays do not work. turned one unit up to 60 degrees and the ice better, other unit stays at 50 degrees with temp set to highest setting. had an expert service them, said i need new thermostats, do not know were to get them. any suggestions?
  • 1,711 Answers
The EuroCave Digital led thermostats are very special and are not avaliable in spare parts stores for other refrigerators even other domestic wine cooler.
There are not also avaliable online.
However the distributors of Eurocave they are able to supply spare parts also including thermostats so you are only chance is to ask from your nearest Eurocave distributor.
Posted on Sep 03, 2010
Fridge section has ceased to work, no longer stays cold.
Check Warranty? Some parts of the refrigerator may have extended warranty.
Likely one of two problems. Either the defrost cycle is not working or the cooling is not working.
Look for ice build up inside around the back of the unit.
26160077-ai3unifkpfov1uv0qrlw5ags-5-0.jpg If ice has built up on the back wall it is a sure tell that the defrost cycle is not working and the air flow is restricted by the ice built up around the cooling coils resulting in not cooling.
First try would be to empty the unit and allow with the doors open 24 hours with heat to melt the ice. Afterwards start normally and hope that the problem doesn't return. There is a tube that needs to thaw from the bottom of the coils that is known to freeze preventing a satisfactory defrost. This tube takes time to defrost if frozen closed.
If problem returns in a day or two then more troubleshooting is required. The heater, defrost sensor and depending on the model, timer may need to be replaced. This is far less expense then replacing the unit and I would be inclined to repair the unit.
No ice built up on back wall of unit does not mean that the defrost cycle is working so check for air flow coming out of the vents. If the air flow appears to be restricted it still could be frozen cooling coils and requires defrost.(see above)
If defrost is not the culprit than reread the warranty. It is likely the unit has a leak and the Freon is low or the compressor is failing. Check the fan located at the bottom from the rear or check for airflow from the front grill. Remove grill and check for massive lint and dust build up restricting the airflow before deciding to replace.
The cost of leak repair or compressor replacement can exceed the present value of the unit and could be better applied against the cost of unit replacement.
Hope this helps?
Apr 11, 2016 | Miele KFN12923 SD-2 Fridge Freezer, A...
Why is our EuroCave DUO wine cooler model D264 freezing 1/4 inch of ice on back wall inside cooler?
Most cases of ice build up can be traced to seals that leak humid air into the cooler. Check the door seal carefully using a fresh $1 bill. The bill should not pull out easily when the door is closed. If the unit has a self defrost feature it it is not coming on. Ice buildup inside a wine cooler is very rare. The cooler box should not reach 32deg in normal operation. Does the unit seem to run continuously?
Sep 10, 2014 | Furniture
Front grill
Check the air filter and if it is dirty, replace..
Turn equipment off and let the ice melt.
After ice melts, place a/c in cooling mode and set the thermostat to 3 degrees below room temp display.
The indoor unit fan should start blowing cold air immediately and then turn off once the room temp drops one degree below the cooling temp setting.
If the indoor unit does cycle off, check the outdoor unit and make sure it turns off at the same time.
If the outdoor unit continues to run and the indoor fan is not running, the indoor unit will ice up.
A defective compressor relay that is stuck in a closed position will cause icing of the indoor unit because it keeps the compressor running when it should turn off with the indoor fan.
Do you have an error code being displayed on the controller?
Is there an led light that is flashing on the indoor unit?
Another possibility causing the indoor unit to ice up is if the freon in the system starts to get low.
Make sure the ice has all melted for this next check.
Pretty easy to check without special tools.
If the air filter is clean and there is no dust/ dirt blocking the fins on the indoor unit, turn a/c back on to cool and check that the indoor unit fan comes on and is blowing air good.
Once everything seems to running good go to the outdoor unit.
There will be two lines with black rubber insulation covering them.
Peel back the insulation three inches on each line and observe the copper lines.
If either line starts to frost up the a/c system is most likely low on refrigerant.
Another cause of indoor unit icing could be that the aluminum fins behind the air filter are clogged with dust or other foreign material.
This would block the air that must be pulled in causing the indoor unit coil to become too cold due to lack of air flow and it will ice up.
Operating the cooling system when the outdoor temperature is below 60 degrees can cause the indoor unit to ice up also.
I'm Robert.
Florida certified a/c contractor. 30 years experience.
Hope this helps.
Mar 18, 2014 | Fujitsu Heating & Cooling
Ice in the unit. Whould shoud I do? Who should I contact to get the service...What kind of filter does it take and where can I purchase it?
I also have problems with ice in my unit. How can this problem be solved? Do it need a repair technician to come out?
Sep 02, 2011 | EuroCave Comfort 260 Collector's Package...
Eurocave comfort 264: Problem, ice formation inside the unite , half the way the middle section of the unit ( Racks 8-10)
It's likely that you need to change the filter. Have a look at this post: http://blog.wineenthusiast.com/2009/04/20/caring-for-your-eurocave-3-simple-steps-towards-long-lasting-wine-protection/
Sep 30, 2010 | EuroCave Comfort 260 Collector's Package...
Moving a Eurocave wine cooler laying flat
the reason you should not lay a fridge/freezer on its side is that you will get air bubbles in the cooling pipes,which you may not be able to get rid of when you turn it back upright.I have moved loads of f/f, in the past and have had no problems,as long as you give the unit at least 24 hours to right itself.....and keep the door(s) closed while it is "resting"
Apr 17, 2010 | EuroCave Comfort 260 Collector's Package...
No light, no fans running, nothing. temp gauge still working
It is possible that the unit has a switch somewhere which may have been accidentally switched off? On some units you can switch the complete unit off by turning the thermostat counterclockwise.
Mar 09, 2009 | EuroCave Comfort 260 Collector's Package...
Temp won't go down to target
Sounds like your unit is low on refrigerant gas.  Too little gas causes rapid boiling of refrigerant and makes the cold spots.  You'll need professional help.
Sep 09, 2008 | EuroCave Comfort 260 Collector's Package...
GE model TFX24FA side by side
Look in he back of the freezer section, if you see ice on the back wall then I would suggest defrosting the whole unit overnight and restarting to see if this makes a difference to the fridge section. If it does then you have a problem with the defrost cycle of the unit, if it doesnt then you may have a fan gone. We normally suggest defrosting first in case a door got left ajar. However if it does pull back down you will need to keep a close eye on the unit for several weeks. Hope this helps.
Aug 16, 2007 | GE PSC23NHN Side by Side Refrigerator
EuroCave Performance 83 Wine Cellar Logo
463 people viewed this question
Top EuroCave Refrigerators Experts
 steve
steve
Tom Chichester
Are you an EuroCave Refrigerator Expert? Answer questions, earn points and help others
