Question about Canon Cameras
When I inserted the SanDisk micro card into my Canon Digital IXUS 55 camera, the card bent (kinked) along its weakest line - at the small notch of its 'lock' micro-switch. The data can no longer be read, even though the card was correctly engaged in its slot.. Is there a way to recover the images stored on it? Thanks, Michael
  • 1 more comment
  • seleanu Sep 03, 2010
    Best I know, data recovery services deal with hard drives and the like. Anything that SanDisk can do - directly or indirectly?
    Thanks.
    Please advise how to Google this to find the right if not the best place.
    We live in Dubai (UAE).
    Thanks,
    Michael Seleanu
  • Canon Master
  • 3,866 Answers
Michael
As long as the circuit board inside is still entacted you will need to send it to a data recovery place with your fingers crossed.
But if its damaged then its a no can do, Hope you do not shoot the messenger, I hate to be the bear of bad tithe.
Please do click the accept button for my efforts.
Posted on Sep 03, 2010
  • Grand Canyon Tech
    Grand Canyon Tech Sep 03, 2010
    Most data recover places handle San disk and flash memory. Not just hard drives,
    The comapny Sand disk would not be able to help you recover your data.
  • Grand Canyon Tech
    now if you card can be read
    http://www.cardrecovery.com/
    Best bet
    But if not then it will need to be taken from its plastic shroud and recovered differently. there are plenty of services on the web that offer this. We do not here at fixya, But do hope this answer was help full
    please do click the accept button for my efforts.
I have a canon ixus 700. i've tried to insert a new SanDisk 4 GB memory card. the menu says the card is locked when (i've treble-checked) it definitely is not locked. i read from others that...
According to the specs on Canon's web site, the IXUS 700 works with SD cards, not SDHC cards. SD cards are limited to 2GB in size (there are rare 4GB SD cards, but they tend not to work in SD devices).
Of course, it's your call as to how definitive any manufacturer's web site touting their product might be.
Jul 20, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
Digital ixus55 compatible memory card
Hi. Your Canon IXUS 55 accepts SD Card cards.The maximum SD Card card capacity you can use in your Canon IXUS 55 is 2GB.
SD card larger than 2GB is not supported and will not work with your camera.
Hope this helps.
Feb 04, 2011 | Canon Cameras
Can I use an SDHC 4GB memory card for my Canon Digital IXUS 55? If not, what is the second best?
The IXUS 55 uses SD cards, not SDHC cards. You can use any SD card, 2GB and smaller.
Aug 25, 2010 | Canon Powershot SD450 / IXUS 55 Digital...
Will my canon ixus 60 take a 16gb memory card
Yes. The IXUS 60 was designed to work with SD cards. Cards larger than 2GB are actually SDHC (the HC stands for High Capacity) and will not work in this camera.
Jul 12, 2010 | Canon Cameras
How can i solve the Card locked Problem
Take the card out of the camera, move the small notch on the left hand side of the card to "Write Enable". Re-insert the card, you should be away.
Jun 19, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
Tell me how to format my sandisk camera card and erase the photos
your cam come's with data cord or USB BUS hub drive which can be easily connected to an y pc or note book pc or laptop but first see that you install the driver & software on your system for proper working or function of cam on the PC or Laptop after installing connect the cam to USB cable then it will automatically show each & every content on your PC or Laptop & their is the option of deleting every thing you need to erase so till then see your hope that it help you out ......!
Sep 29, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Card is locked of CANON IXUS 960IS
There is a little slide switch on the side of the SD card that will lock it.  It could be that it got bumped the last time it was inserted, or the memory card could be defective.  I saw this happen with a SanDisk card that hadn't been removed from the camera.  Removing the card and sliding the lock switch back and forth, then re-inserting finally solved the problem.  It was a bit disconcerting when it happened.  I would recommend that you get a replacement memory card to use if it starts to happen repeatedly.
Apr 25, 2009 | Canon IXUS 860 IS Digital Camera
Memory card
There is a little slide switch on the side of the SD card that will lock it.  It could be that it got bumped the last time it was inserted, or the memory card could be defective.  I saw this happen with a SanDisk memory card that hadn't been removed from the camera.  Removing the card and sliding the lock switch back and forth, then re-inserting finally solved the problem.  It was a bit disconcerting when it happened.  I would recommend that you get a replacement memory card to use if it starts to happen repeatedly.
Mar 11, 2009 | Canon IXUS 860 IS Digital Camera
Memory cards does not work
First remove battery and card and look in your flash card slot for any bent pins. If you see some, don't fret. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. Take your time and use as much patience as you can muster (take a breather in between if needed).
It doesn't have to be perfect, just as close as you can get it. When it's there, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
If there are no bent pins, then the internal BIOS battery has likely run down and is causing this error. Don't attempt to fix this yourself. Canon will fix this for you for free, with free shipping, regardless of your camera's warranty status. See and print out the following advisory:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8777&keycode=2112&id=27465
Also, see the following link for tips on contacting Canon regarding camera advisories. This particular post concerns a CCD advisory, but the tips are the same:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
Oct 10, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Card locked canon powershot sd750
Check the switch on the side of your SD memory card. It is a small sliding switch which has a lock position. Sounds like the switch is in the "locked" position. Unlock, reload card, & you should be good to go. If not, the card is probably damaged.
Mar 01, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Cameras Logo
239 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
