Question about Toshiba TEC B-452 Thermal Label Printer
When i press the feed boutton after putting the printer ON it exceeds the size of the page length. please help on the same.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Toshiba TEC Expert
  • 142 Answers
Send the correct length to the printer.
Use a windows driver to sent a test page at the correct size and dectection
Posted on Jan 14, 2014
Print on ribbon is 1/2 off label
check the driver (length and with) from the driver if is the same that the size from the labes that you have.print test page (print full label?) if not work, Reset to Factory Defult (Turn On with FEED and CANCEL buttons pressed, and relese after 5 seconds.
Oct 31, 2010 | Zebra S4M Thermal Label Printer
Problems with Printing Special Size Forms
you have to chk the setting on the print setup.
Jul 04, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Label size formatting I have 4 x 6 labels and each
This can depend upon several things -
Does the printer feed the tickets through normally when pressing the feed button?
If it does not, I suggest the ticket has the length and width defined incorrectley.
The othe rissue maybe in the printer detecting the gap bewteen the tickets. To solve this issue , more information is necessary,
can you print a ticket to a file and post it?
Sorry I can`t be of more help
Aug 30, 2010 | Toshiba TEC B-472 Thermal Label Printer
Epson LX-300+ II
just change the page length setting in printer .just press pause button and switch on the printer and change the setting accordig to the page size it is bettreif you take online help from epson service call center they will guide you how to set the page length.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | Epson LX-300 Matrix Printer
The printer cannot be set to a page length when printing from a dos program. The page length is incorrect but changes with every print even though the same file is printed
Prints from DOS programs do not have a "page length" setting of their own, nor do dot matrix printer have a page length of their own.
Page feed is achieved by sending a special control code (^L), and the meaning of ^L can be set through specific escape codes that the DOS program has to know.
My guess is that you need to tell the DOS program the page size in lines or inches, and maybe instruct it to send a page feed command after each page.
You can try directly programming the printer, but if the DOS program is sending out the wrong codes, this is not going to help. Anyway, here goes. Good luck!
http://www.masondesigns.com/staging/dhl/printer/lasernet/turboset.html
Feb 01, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
Printing a label 4x 1 7/16
Try setting the page lenght using the printer panel
To do this, enter MENU mode by pressing SHIFT+MENU
press GROUP button until prints REAR feed or BOTTOM feed ( depend on where you load the forms from )
Press ITEM button until it prints form length
Press SET to change length as required
To exit, repeat SHIFT+MENU
All the best
KM Hoo
Feb 11, 2009 | OKI MICROLINE 590 Matrix Printer
For some reason when I print from the HP Pavillion dv2000, my printer feeds a blank page through for each page I am printing.
Appears to be a relatively common problem for different reasons--sometimes system, sometimes printer. Things to check--page length settings, try reducing the printout size, margins. What's the printer and what size paper? Thanks
Oct 31, 2008 | HP Computers & Internet
Paper is 8x7
The User guide is available on the Epson web site.
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=6p8Gbf6kzcDjBDX5CN0IhYGAuQVqVCJs&tc=5
Essentially, this suggests (page 2-9) that you turn off, leave for 5 seconds min, and turn on holding the Tear off(Font) button. Press this button once and select the language, then press it again to print the settings and instructions for changing them. Set the printer to tractor-feed and your required length and you're away (turn off after).
Sep 12, 2008 | Epson LX-300+ II Matrix Printer
Epson FX-2190
What operating system are you using? In Windows, you can set it through server properties in the Printers area of the control panel, you can do this by creating a custom paper size. If you are running in DOS, you can set the page length through the printer itself by going to its default setting. In the printers default setting, make sure you are setting the length on the correct paper path (FRONT FEED, BACK FEED).
Jun 03, 2008 | Epson FX-2190 9 PIN Matrix Printer
TALLY T2250 PRINTER
It sounds like there is 12 inch form length (or may be A4) selected on the computer system. The data from the system will take precidence over the 11 form length set on the printer.
If using Windows, ensure the Printing Preferences in the pritner driver are set to 11 form, Also check Printer Properties for a paper size ensure this is set to 11 inch
On the 'System' check the paper size selected within the application (if available) Check this is set to 11 inch form length
Check document margins to ensure these are not reducing the 'printable area' on the page. If availabe to a Print Preview on system to see what the document looks like.
If your application outputs raw data to the printer, check the number of lines per page assming printing at 6 lines per inch you can fit 66 lines on an 11 form. Check no more than 66 lines are per page, it sounds like 72 might be being sent befor a Form Feed in the data. (there may be a 1 line top margin set on the printer)
Finaly check the top margin setting on the printer to ensure it is set to 0 so you have the full 66 lines available on a page on the printer I think you would be looking to set the FORM ADJUST to 0 to adjust the top margin
Feb 22, 2008 | Tally T2250 Matrix Printer
Toshiba TEC B-452 Thermal Label Printer Logo
Top Toshiba TEC Office Equipment & Supplies Experts
matt
matt
richie46
 steve
steve
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
