Question about Whirlpool LER4634J Electric Dryer
Control panel will not turn on - Whirlpool LER4634J Electric Dryer
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
My pentair master temp 400 natural gas pool heater control panel won't respond. I can't adjust temp or turn it off. Any suggestions?
Have you tried unplugging the control panel? Or turn all the power off for 15 seconds then plug back in this will reset the control panel. If it still doesn't work I think you have a bad panel.
Oct 19, 2014 | Pentair Pool & Spa
The setting push panel does not respond - can't turn it on
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 | Dishwashers
The control panel for my Amana oven, model ACS3350AS, turns off mid cycle. How do I know if the panel is fried or it's something else? Is the control panel easy to find and install?
the fitst thing i would do is check the incomig power. make sure you have constant power ad that the range isnt loosing power. if your power is good, then you may have a bad control. go to www.searspartsdirect.com. type in the model and you can view the price for the control
Nov 25, 2011 | Amana ACS3350AS Gas Kitchen Range
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
How do u turn on the fire wall
goto control panel
double click windows firewall, if you did not find windows firewall at control panel change your control panel view by clicking classic view, and control panel will show windows firewall icon
after double click windows firewall, then click turn on windows firewall, and you got your windows firewall is on
i hope this helpful
thank you for using fixya
Feb 04, 2011 | Toshiba Satellite M55-S135 Notebook
I have a whirlpool electric glass top stove (model # rf364pxpq ). our electricity went out for only a moment, and when it came back on, the control panel is blank and the oven doesnt turn on. the stove top...
I just encountered the same problem. Power surge during storm caused the control panel to go blank. I removed the panel to get the part number. Reinstalled control panel and it started working. Below are the steps 1) Turn off breaker 2) Unplug unit 3) Remove rear panel 4) Unplug all connections to control panel 5) Wait 5-minutes 6) Reconnect all wires in reverse order 7) Install rear panel 8) Plug in unit 9) Switch breaker to on position Control panel came on, set clock and all oven functions worked.
Jan 02, 2011 | Whirlpool Kitchen Ranges
Wall electric oven gets hotter than the tempature reading on the control dial
If this has a manual turn oven control (not electronic) you will have to replace the oven control thermostat.
First shut the power off to the oven at the main breaker. Remove the screws holding the front control panel in place. Some of the screws are located inside the oven and some are on top of the control panel. Tilt the control panel forward to access the oven thermostat. While holding the new thermostat in your hand transfer each wire the the corresponding numbers on the new thermostat. Unclip the oven sensor from inside the oven and feed it into the control panel area.Remove the screws holding the old thermostat to the control panel and discard old thermostat.
Insert new thermostat into the control panel and screw to panel.
Reinsert the thermostat sensor into the oven cavity and fasten to clips.
Re assemble control panel.
WARNING: make sure that no wires are touching when reassembling.
When everything is back together, turn power back on and test temperature.
Dec 30, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Control panel locked
At the far right buttons on control panel, the very bottom far right button says control lock. hold in for 5-10 secs and the control lock will turn off.
Aug 24, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
