Question about Fisher and Paykel GWL11 Top Load Washer
Fisher paykel gwl11 won't drain
Thanks for the info. I'll have my man look at the machine to see if he wants to attempt to fix it. If not can you see if you have ant #'s for service tech's in my area. I live in the Branson area of Missouri. Thanks again. posted by mjblacks on Jan 01, 2008 Report abuse
my fisher paykel gwl11 won't drain. Sure that I or my husband can clean drain pump etc., but not sure where to find part on machine as well as, interconnecting pump and diverter.
Thanks
Jac
Still need a solution for this problem?
Try our Premium Assistance plan Best Solution posted on Jan 01, 2008
FIX IT RIGHT
Rank: Guru
Rating: 88%, 62 votes
Fisher /paykel is very easy to work on BUT every thing has plastic tabs not very many screws SO BE VERY VERY CAREFUL NOT TO BREAK THESE TABS the pump(on the early 11) is under the inner tub(and on the later which is the 12 is under the tub chassie)If memory serves me they just dont break every day so I have to back up and regroup every time. you have to take the inner tub out I would recomened having a Fisher Paykel tech not a handy man or just a appliance repair man fix it this is not fun and you can damage the machine very fast if you need and phone #'s to f/p let me know Ive got some that the customer cant get because Im a factory tech for all the name brands including f/p
Thank you for rating this solution.
Was this solution helpful? Show your Appreciation by rating it
Having same problem wtih 8 yr old GWL08 and beeping won't reset. I took apart tub and cleaned exterior surfaces.-did not mess with pump, which 'appeared' fine. Am suspecting electronics board. Can not get F&P site to load today-will try again Monday. Am located few miles East of St Louis,MO. -might have found an authorized service tech to call on Monday but am comfortable replacing components if available at reasonable price.
  • Anonymous Aug 03, 2008
    WASHES FINE. WON'T DRAIN. CAN'T FIND ANYONE TO SELL ME REPLACEMENT PARTS.
  • paykelized Dec 07, 2008
    Won't drain before final spin. De-energized diverter valve (new) and the tub drained. So.............pump works, diverter valve works (when forced). Is this a motor controller issue?
Http://www.searspartsdirect.com has all the parts for these machines
Posted on Oct 22, 2008
F & P EcoSmart top loaders have a diverter or "Y" valve in the pump discharge. This valve directs pumped water out of the machine tub (when the valve solenoid is deenergized; this solenoid operates very slowly, BTW). Conversely, when energized, the valve directs water into the top of the tub (during wash cycle, for example). If no water flows (either way) when the machine is operating, the problem lies with the pump or its conroller*.
If water is not pumping out of the tub (preceding the spin part of the cycle) -- you might notice that the machine beeps -- but continues to pour in at the top of the tub (you can hear the water recirculating), the problem likely lies with the diverter valve being obstructed (easy fix -- clean it), the solenoid is not working (less likely to be the problem, but possible) or the controller* is faulty (more likely).
To remove water from the tub, you can either bail it out or deenergize the solenoid. To accomplish the latter, you can remove the control panel shroud assy, (remove two sheet-metal screws), lay the shroud aside and you'll see the controller* situated beneath the push-button panel. Look for a pair of wires with a connector lying loosely on top of, and running across the controller* -- one of the wires is likely orange. unplugging that connector disconnects power to the solenoid and causes the valve to return to its normal position (that is, it is positioned to send the water out of the tub and into your house drain pipe in back of the machine).
You access the pump and diverter valve (I'm basing this on model GLW 10) from the underside of the machine. The washer will have a quart or more of water in it, so take it where you don't mind spilled tub water, turn the machine over so that the machine's front is on a braod cushion or foam pad on the ground/floor. Looking into the bottom end, tyou'll see the pump at about 7 o'clock and the diverter just above (at ~8 o'clock). The big circular thing in the middle is the DC motor. Have fun.
Posted on Oct 09, 2008
2 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: fisher paykel gwl11 won't drain
This machine was made similar to a lighter.When it breaks you throw it away.
Posted on May 25, 2008
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Need instructions on taking machine apart
This is a good place to get a parts manual.
Parts manual F&P
Dec 13, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel Ecosmart WA37t26gw2 won't drain
Check your belts and replace if faulty
turn the pump by hand with belt off to see if pump is jammed
still no go, you may have a faulty electronics board.
Oct 30, 2011 | Fisher and Paykel GWL11 Top Load Washer
Washing machine starts and stops
www.docstoc.com/docs/.../Fisher-and-Paykel-Circuit-Diagram-GWL11
http://washingmachinemanual.com/tag/user-repair-manuals-fisher-and-paykel-gwl11-top-load-washer/
Above is your service manual and a circuit diagram, Simply use the troubleshooting steps and you will soon isolate your issue and effect a repair.
May 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 will not drain...
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 09, 2008 | Fisher and Paykel GWL11 Top Load Washer
Jan 03, 2008 | Fisher and Paykel GWL11 Top Load Washer
RE: won't drain
I had the same symptoms (washes normally, but won't drain/spin) It would only make a faint hum. I found it fairly easy to lift and tilt back the upper section id by removing the front two screws under the lid. The aggitator came out easily by removing the softener cup and unscrewing the large plastic wingnut inside. The upper plastic shroud came off by carefully removing the eight or so plastic tabs. Once the shroud was off, I could lift out the main wash tub. With the wash tub out, I was able to remove all remaining water from the holding tub with a cup and sponge out all water down into the depression where the pump assembly is located. One screw removed the cover to the pump assembly. Once apart, I found a thin piece of plastic was jamming the pump impeller from spinning. I blew through the drain hose from the back to ensure the drain system was clean. Reassembled in reverse in less than 10 minutes. It worked. Thanks Fixya!!!
Jan 01, 2008 | Fisher and Paykel GWL11 Top Load Washer
Need to replace drain hose
there is a kit available to replace just the part from the back of the machine.normally the drain hose comes with the wiring loom big job.not sure what country you are in.kit is available in australia.
Nov 15, 2007 | Fisher and Paykel GWL11 Top Load Washer
Changing the drain hose
Try: http://usa.fisherpaykel.com/global/customer-care/trouble-shooting/washing-machines.cfm?CFID=5795181&CFTOKEN=46306735
Nov 29, 2006 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
2,235 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
