I have an older RCA TV and the picture is larger than the screen, you can't see the whole picture. If there are words or anything in the picture it goes off the screen and you can't see it all. Any suggestions on how to fix this?
  • Televison & ... Master
  • 1,213 Answers
I can only guess at this solution as I have no model# of your TV. For starters and the most simplest solution I would direct you to one of two diodes. You may have to resolder diode location# CR4403 or diode location 4402. In many, many cases this has corrected the RCA problems in this TV. If you can safely remove the board, you will note the top front and to the right of this board on the edge you will see diode CR4402. Look underneath and inspect the solder connection. You may see a cracked ring. Cr4403 is nearby and inspect that one also. Try this first. Thanks for asking and give me a few hands of support!
Posted on Sep 03, 2010
RCA TV, Model L42FHD37. Gray or black bars on either edge, but not getting the entire picture. If I "zoom" I still can't see what is obviously behind the black or gray bars.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Jan 20, 2016 | RCA L42FHD37 42 in. LCD HDTV
Rca picture
Very bad symptom indeed.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations.
Aug 12, 2014 | RCA 42" LED42C45RQ Class LED 1080p 60Hz...
Picture larger than screen
I think you have overscan enabled.
I don't know anything about that specific TV, but that's the magic word you're looking for.
Jul 22, 2014 | RCA P52926 52" Rear Projection Television
Picture on 47
You do not worry at all, because the set is under warranty.
Launch a complaint and sit peas fully.
Jul 23, 2012 | RCA 47LA55RS 47 in. LCD TV
RCA entertainment series TV does not show the entire image
Check the picture settings. It sounds that the picture settings to TV is Zoomed.
May 29, 2012 | Televison & Video
RCA 36'' Tube TV Picture is Blurry
Out of focus picture. have many reasons. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Jun 03, 2017 | RCA Televison & Video
Green picture only
The projection TV has 3 guns RED GREEN BLUE. In your case the red and the blue guns are gone. So you are getting the green color screen. You got to replace the picture tube.
Jul 25, 2009 | RCA TruFlat 27F520T 27" TV
Error on screen showing 'unusable signal' - input probs
Make sure you have all the cables in the right places, best to disconnect everything and start from scratch. Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | RCA HD52W58 52" TV
RCA P60752EBLG1 Convergence Problem
If you wish to get some details; visit the site linked here. Pull up older posts.
Convergence adjustment to projection TVs are given.
Apr 24, 2017 | Televison & Video
RCA 27" TV
typical problem with an older set. sounds like the crts starting to fade as manufactureres Im thinking build into a set faults that they know will happen after a certain time frame and most do this is why there are so many reoccouring falures in a tv sets life. this is simply my thoughts on this subject!! You could have your local tv guy shoot the tube (not with a gun!!) with a crt rejuvenator to maybe clean off the grids of the tube. sometimes this will help BUT its a risk also Sometimes it will ruin the picture tube also. I have a set that I rejuvenated the tube 4 years ago as it looked like crap but to this date s its stil looking good as it did when new!
Apr 01, 2006 | RCA F27645 27" TV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
