Question about Whirlpool Dishwashers
I had a black out and the dishwasher was running at the time. The dishwasher emptied out all over the floor. when the power came back on the dishwasher was flashing an error code 4. I rang Whirlpool for assistance and they said it was over full but it was totally empty. We turned the dishwasher off at the wall hoping it would reset but it is still saying error code 4. Can you suggest something else we can do?
  • 901 Answers
The trouble looks to be little confusing. Whenever the power fails
during mid cycle this happens. Try running the balance cycle.
Since you say the water is fully drained, try adding water manually to
the wash chamber to certain level ( not to over flow ). Give a try!
There should be a master reset for which, you are requested to check
the user manual
Posted on Sep 03, 2010
How much vinegar do you add to the dishwasher?
For regular monthly maintenance fill the dishwasher soap dish with vinegar once a month and run a regular cycle with an empty dishwasher. If you're having problems with dishes not getting clean or dishwasher soap build up on the floor of your dishwasher do the above now. You may need to run the empty dishwasher with vinegar a few times to clean the drain lines; running empty once a week with vinegar is not too often.
Oct 30, 2016 | Dishwashers
Door on Kenmore Dishwasher dropping out pieces of black insulation on the floor and into the dishwasher basin. What is it? Can the insulation be replaced or is it new dishwasher time?
If it seems noisier, these black pieces are pitch (a hard tar-like substance) that's coated on dishwasher doors to make them quieter. Just to be safe, though, it might be a good idea to show them to somebody in an electrical shop.
Jan 23, 2015 | Kenmore 24 in. Elite Built-In Dishwasher...
GE Potscrubber,Quiet Power dishwasher leaks while running
Check to see if the door baffles are intact they are little black rubber things in the front on each side of the tub. the pump seal could be leaking underneath. the wrong detergent (dishwashing detergent) could have been used.
Oct 08, 2014 | Dishwashers
My dishwasher won't empty
This condition is commonly caused by:
- Drain pump jammed
When you wash your clothes, any small objects (e.g. hair pins, coins etc) are flushed down the drain pipe but often get jammed in the drain pumps impellar (this is the tiny propeller on the pump).
Firstly, place a bucket on the floor....then lower your drain hose (from your tub) into the bucket - the gravity will naturally drain the water into the bucket. Be careful to raise the hose and empty the bucket each time, until the machine is empty. Remove any wet clothes from machine (you will need the bowl to be emptied).
Once empty, you can now check the drain pump.
Turn the machin off at the power.
Locate the drain pump cover (usually near the drain hose, on the back or side). Place a large towel on the floor beneath the pump cover (as remaining water will escape onto the floor). Unscrew the drain pump cover and allow the water to drain (if your pump cover contains a filter, then clean everything from this filter).
Then, look inside the drain pump cavity for anything obstructing the little propeller (remove any objects). Insert your finger inside the cavity and rotate the little propeller - you should feel a resistance, similar to a rubber band.
Re-install the drain pump cover (or filter) and ensure it is sealed properly. Turn ON at the wall.
Fill your bucket with water (from tub) and pour into your machine.
Turn machine ON, and select the last SPIN (or drain) cycle and check if machine now drains correctly. If ok, then problem now solved and you can put the clothes back into the machine for a final rinse/spin.
If machine still not draining after inspecting the drain pump, then you may have a suspected faulty drain pump - a technician can run a diagnostic process on your machine's control pad to find the diagnostic codes.
Please do let me know, if the above process helps you solve this.
Cheers,
Oct 02, 2011 | Dishwashers
Water wont drain every time
Hello
When a dishwasher won't drain, that usually means that the appliance's drain line is clogged. The drain line, which connects the dishwasher to the garbage disposal, must be cleared of debris before the dishwasher will resume its normal operation. If the drain line is the problem, clearing it is simple and requires only a few standard household products.
Turn off the power to the dishwasher, if possible. Remove all the dishes and the racks. Put on a pair of rubber gloves and use towels to soak up most of the standing water in the bottom of the dishwasher.
Unscrew the rotating sprayer arm in the bottom of the dishwasher. Rinse off the arm and all its seals and screws in the sink and set it aside.
Locate the filter screen in the back of the dishwasher's floor. Pop off the screen, using a screwdriver to loosen any bolts that may be holding it in place. Rinse off the screen, then wipe the dishwasher floor with paper towels to remove any large pieces of food or other debris. Wipe the area clean with a damp sponge.
Replace the screen and the sprayer arm. Locate the drain line; it should be near the back of the floor of the dishwasher, right underneath the filter screen. Pour 1/2 cup baking soda into a cup and add enough water to make it into a pourable paste. Pour the paste into the drain line through the screen. Add 1/2 cup vinegar to the drain line and let the solution fizz for 15 minutes.
Boil a quart of water. Remove the pot from the heat, allow the bubbling to subside and pour the water into the drain line to clear the baking soda solution. Watch the water go down the tube; if it seems to be draining slowly or not at all, repeat the baking soda treatment.
Replace the racks and make sure that everything is put back together properly. Turn the power back on and run the empty dishwasher through one normal cycle to see if the drainage problem is fixed. If not, repeat the process a few more times. If the issue still isn't resolved, the problem may be with the pump or another electronic part. A professional is best suited to deal with an issue like that.
Sep 07, 2011 | Dishwashers
Water collecting at bottom of dishwasher. screens have been cleaned.
is there water sitting in the bottom of the dishwasher or on the floor? If its sitting in the bottom of the dishwasher, most likely the discharge pump isn't working properly and not emptying all the water out. The pump will usually run for an extended time to pump the water out until it finally times out and you're still left with water in there...
Sep 09, 2009 | Dishwashers
Leaks when being unloaded
I may not have the full solution here, but to avoid (expensive) sub-floor damage, I recommend you do the following.  Assuming that the water is not coming from some dripping between the opened door at the hinge....
-Remove the kick plate that is in the bottom, front of the dishwasher.
Use a flashlight to look for wet flooring.  Run the dishwasher with the kick plate removed, watching for leaks/dripping.  It is possible for a leak to seep under the floor.  If leaking is found, do not ignore it.  Pull the dishwasher, fix the leak or replace the dishwasher.  Remove the first layer of sub-floor under the dishwasher, looking for deeper damage.
You should probably do the same with the carpeted area.  Pull the carpet back and decide if the sub-floor needs to be replaced.  A flooring expert should probably inspect.
Sorry to be such an alarmist, but I have been around floor damage that was unnoticed and ignored.
Apr 14, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Water won't go out of the dishwasher
Begin at your sink drain that the dishwasher drain hose connects to. Disconnect the hose and check both directions for anything plugging the connection.
Make sure the drain hose has not become "kinked"
(After you have emptied the water from the dishwasher) remove the lower spray arm and the filter in the sump area. Look for obstructions and remove all debris. Rinse the filter thoroughly and reassemble.
If you dishwasher has a timer on the front of the dishwasher that you can manually turn, start a quick cycle with no DW soap and empty.
Allow the water to run in for several seconds and then manually (slowly, gently) turn the timer knob until the DW should begin draining the DW. Listen closely for the sound of the pump motor running.Is water properly draining out of the dishwasher into the drain?
After you have done these things, please post back here and we can take the next steps. OK?
Apr 09, 2009 | Dishwashers
Water flooding out
Hi KellyW,
The dishwasher drain hose may be clogged.  When the dishwashr starts up can you hear the water running into the Sink faucet drain. If not inspect the hose that attaches to the Sink Drain for restrictions.  Also in the bottom of the dishwasher you should have a filter.  If this filter is clogged you cannot expel water.  Clean the filter.
Oct 23, 2007 | Asko D1776 Stainless Steel Built-in...
Floor cleaner in jet dry resevoir
If you run the dishwasher it will produce suds coming out the door.You can take the door off and clean it all out. One remedy is to add a gallon of vinegar to react with the soap and prevent foaming, another solution is to add cooking oil.
May 26, 2007 | GE GSD5650D Dishwasher
Dishwashers Logo
166 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
