My Dell Inspirion 531S desktop won't start back up after power went out at home. Push power button and tries to start up then power button stays amber and tower beeps twice, pause, then repeats. Tried reseating memory several times with no luck. Any other suggestions?
  • Sreekanth C Menon Sep 03, 2010
    Remove your memory modules and check it is prompting the same error code. If you getting the same error code check with different memory module in different slot (if your motherboard having multiple memory slot). Again you getting same error clean the memory slot with a antistatic brush (if it is not available use tooth brush) and IPA. Insert memory module and check again, if you still in the same error remove the front panel cable and check.
    Sergeant:
    Champion:
  • 389 Answers
If u have another pc at home ,u could try the memory from the dell in it if its compatible.(by dell) reseat the memory,any add in cards,and any video cards,and check all power supply cables to the mb.per the dell site(the 2 beeps are for the memory moduals) though it said to take out the memory and put 1 of them in and boot,if it works fine,then check the other 1.
Posted on Sep 03, 2010
Pc won't power up
Not much to work with. Can you give more detail? What happens when you push the on/off button? Fans spin? LED's Blink? Anything on the monitor?
Jan 18, 2013 | Dell Inspiron 531s Desktop Computer
I have a dell inspirion 531 and cannot get it to start...tried f8 & f11 ad nothing works...what r my options to set back to factory
if you've tried f8 and f11 (although i think you should be pressing f12) then there is only one logical step and that is to reinstall. you can download a version of whatever windows OS it came with and use the sticker on the machine for the serial key. you can then go to support.dell.com to download the correct drivers for your hardware.
May 08, 2012 | Dell Inspiron 531s Desktop Computer
I have vista on my dell inspiron 531s. Once it goes into hibernation, it won't come out of it when I move the mouse. I have to turn it off without powering down correctly. How do I fix this?
If it didn't used to be a problem, but now is, and you've added some program recently, try removing that program. Other than that, the solution is probably too difficult to track down, so open the power settings in your control panel and set the power savings mode to never, never, never to keep it from hibernating.
May 06, 2011 | Dell Inspiron 531s Desktop Computer
No power when I push the power button.
This may be that either your power button is stuck or dirty or broken worn or your power supply unit went bad. You can replace these rather cheap these days. I get them at Amazon.com just remove the cover and get the same one as you have replace and you are on your way again. I do not believe it is the mother board. If you are not sure how to do this take it in and have it tested it is cheaper than a new computer to get it done correctly then spend money on this trying to isolate the issue. This is usually a sign of a bad power supply unit, thanks for using FixYa! John
Apr 12, 2011 | Dell Inspiron 531s Desktop Computer
Push Button and Computer fan starts then immediately shuts off (1 Second) .Yellow light on front does the same comes on 1 second then off .Nothing else happens . It is a Dell Dual Core 2 fans.
chek your power unit or the cpu fan working or not if the cpu fan is not working computer will turnoff immediate to save it you better show you computer for technician soon
please rate this solution.....
Apr 11, 2010 | Dell Inspiron 531s Desktop Computer
When we turn on our dell desktop,the fan goes into overdrive,it start and continues with one long beep.The monitor stays black and says auto anolouge input entering power save and stays black.We have...
Try another monitor first, if that causes the same error message, suspect Graphics card problem, try replacement graphics card. One long beep points also to Ram issues
Feb 09, 2010 | Dell Inspiron 531S (DDCWGA1_5) PC Desktop
Computer won't boot up
i tell you m idea....first, maybe there is no operating system like windows or etc...second maybe your hard disk is not detecting or its damage,third, check the bios setup for the drives..it can help to solve the problem
Mar 03, 2009 | Dell Inspiron 531s Desktop Computer
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
