Question about GE Eterna EGR2000EMBB Gas Kitchen Range
How do you get the GE externa series stove to fire? the gas stove will not light.
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Posted on Sep 03, 2010
We have a GE gas stove. The burners all ignite; the broiler lights up, but the oven does not heat up. Doesn't even start to heat up. Can homeowner repair this kind of problem? We don't have any money to...
If you just purchase it or it is still under warranty take it back it going to cost the same to repair. You also run the danger of creating an electrical fire.
Nov 13, 2010 | GE Spectra JGBP35 Gas Kitchen Range
I turn on the stove and it lights and then it dies, then it won't turn on anymore. The other pilots don't turn on either. It worked this morning and when I came home this is the problem I encountered.
Ok, now that I know it's natural gas, what I would like for you to do is fire off the other gas appliances (furnace, water heater, etc) you have in the house to see if you having a similar problem with them as well. If so, you may may a regulator problem (at the meter) and will need to contact your gas co to replace or repair their equipment. If not, and the problem is isolated to the stove only, then you may have a defective appliance regulator, which supplies gas to all the burners on the stovetop and the oven. How old is the stove? Is it still under warranty? If so, you can call G.E. and have them service the stove for free.
Jun 03, 2010 | GE Spectra JBP78 Electric Kitchen Range
Ge spectra eterna series gas stove broiler will not fire up. The glow plug gets hot, but the broiler fails to start.
I have an GE Spectra Eterna Series where the oven comes on and only gets warms no matter what setting the oven is set at. Can some one solve this problem?
Mar 07, 2010 | GE Eterna EGR2000EMBB Gas Kitchen Range
Gas burner will not ignite. Ignitor is firing.
city gas or Lp make sure the gas setting on the stove is on the lowest setting cause it wont light with it on any other setting.for safety.jet dont get clogged most of the time due to the pressure and the flame cleaning any food partical off it.
Oct 28, 2009 | GE JGBP28 Gas Kitchen Range
Montgomery ward gas stove. top burners work fine. oven barely gets warm
I have a whirlpool gas stove oven fire will not go off when in off position. Is the fire suppose to go off completely?
Aug 21, 2009 | GE JGRS14 Gas Single Oven
For the GE XL44 model, where would i find the pilot light? the stove is not working
There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Eterna EGR2000EMBB Gas Kitchen Range Logo
223 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
