Question about Frigidaire FMV156DC Microwave Oven
How to replace door for frigidaire fmv156dc - Frigidaire FMV156DC Microwave Oven
  • 122 Answers
If you remove the vent above the door, a couple of phillip screws hold it on top, it slide off to the left, open the door and pull up on door, look at hinge and remove off of tabs
Posted on Sep 03, 2010
5 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave door handle
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 25, 2008
SOURCE: Frigidaire FMV155DC - defective door interlock switch
I had the problem where the timer continues to count down but turntable doesn't turn, fan doesn't come on and food doesn't heat. Holding the door up worked for awhile but even that temporary method stopped working.
I bought a door interlock switch the cost $23 from an appliance repair place and replaced it myself. It worked like a charm. To replace the switch, you need to remove 3 screws that hold the plastic grille above the door, which exposes the 1 screw that is holding the control panel. Remove that screw and slide the control panel up to remove it. There are three switches left of the panel. Note the middle swich has a different part number so I'm not sure what that one is called. The bad one on mine happen to be the bottom one. The switch is held on by a "pin" and tab that holds it in place. Push the tab and spin the switch on its "pin" past the tab to remove. Reverse your step to put the new one on. I hope this helps.
Posted on May 09, 2009
jyackle5
  • 8197 Answers
SOURCE: Frigidaire FMV156DC manual
You can get the manual on link below.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0409267.pdf
Posted on Jan 08, 2010
MicrowaveSvc
  • 9047 Answers
SOURCE: how do i replac the interior light on my
We have the service manual and have uploaded it to our site here to help you.
From page 33:
OVEN LAMP and Lamp Socket REMOVAL
1. Disconnect the power supply cord, remove the oven from
the wall and remove the outer case. (Refer to procedure
of "Removal of Oven from Wall" and "Outer
Case removal ".). And proceed as follows.
2. Open the door and block it open.
3. To discharge the high voltage capacitor, wait for 60
seconds.
4. Remove the three (3) screws holding the hood intake duct
R to the oven cavity top plate, the oven cavity front flange
and the fan duct. And remove the hood intake duct R.
5. Turn the lamp socket and release it from the magnetron
duct.
6. Screw the oven lamp off from the lamp socket.
7. Now, the oven lamp is free.
8. Pull the wire leads from the oven lamp socket by pushing
the terminal hole of the oven lamp socket with the small
flat type screw driver.
9. Now, the oven lamp socket is free.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 11, 2011
Cannot open door or frigidaire microwave
Good Afternoon Friend,
I understand that you are unable to open the door on your Frigidaire microwave, model# FMV156DC. Due to this being a microwave, I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance and should be able to get the door open without any damage to the appliance, or harm to you or your home. Hope this is helpful.
-Best Regards-
WP
Jun 11, 2014 | Frigidaire FMV156DC Microwave Oven
Door won't latch & lite stays on . door hooks like spring fell off them.
I understand that you are having trouble with your Frigidaire microwave, model# FMV156DC, and the door not latching which leaves the light on inside the appliance. I also see that it looks like a spring fell off the door hook. For safety reasons, when dealing with microwaves, I don't suggest trying to repair them yourselves. I suggest contacting your local authorized technician for further assistance. They will be able to better assist in making sure your microwave is repaired correctly and there are no safety issues. Hope this is helpful.
-Best Regards-
WP
May 23, 2014 | Frigidaire FMV156DC Microwave Oven
Frigidaire FMV156DC 950 Microwave sometimes stops heating
This sounds like a common primary interlock switch. Need to check and or replace both door switches. DISCHARGE high voltage components first with no power applied prior to touching anything in the unit. Failure to discharge High Voltage Components can result in death
Aug 13, 2012 | Frigidaire FMV156DC Microwave Oven
I don't know how to replace the charcoal filter on my Frigidaire FMV157GC microwave. There's also food between the grate and the glass on the microwave door. Help !
This is billed as the Use & Care Manual for the Frigidaire FMV156DC Microwave Oven:
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Springfield/316495004en.pdf
Not sure it is the correct one but you will find instruction for cleaning the exhaust filters on page 19.
Below is the Use & Care Manual for a model direct from the Frigidaire site:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316495057en.pdf
This is more helpful as on page 20 it includes illustrated instructions for removing the charcoal filter to change the oven light. Disconnect from power, remove the ventilation grate at the top to access the charcoal filter, slide back and lift to remove. With the grate removed carry out any required cleaning.
Mar 20, 2011 | Frigidaire FMV156DC Microwave Oven
NEED A DOOR FOR MY MICROWAVE
Hello. I can assure you that you can purchase a new microwave for the same or less than a replacement door. J.
Mar 23, 2010 | Frigidaire FMV156DC Microwave Oven
FRONT GLASS DOOR HAS CRACKS
Sounds to me like the door needs to be replaced.
Jul 29, 2009 | Frigidaire FMV156DC Microwave Oven
Frigidaire Professional series microwave won't heat
The most likely problem is the magnetron. Check your warranty in owners manual, I believe you have five year warranty on magnetron.
Mar 15, 2009 | Frigidaire FMV156DC Microwave Oven
Microwave door handle
Feb 22, 2008 | Frigidaire FMV156DC Microwave Oven
Frigidaire FMV156DC Microwave Oven Logo
220 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
