Question about Black & Decker String Trimmer Cordless 12" 18V
I lent my B & D Grass Trimmer, model CST80, and not realising it, it came with the cable all unspooled & tangled up. What is the proper way to re-spool the line. It is the correct .065 blue line. Thanx in advance...
5 Suggested Answers
  • 313 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
the problem is the white lever may be broken. its located at the bakc of the spool line,
Posted on Jun 01, 2008
SOURCE: Worx WG150 Cordless Grass Trimmer spool nut keeps falling off
Thanks for update. Glad you got some resolution.
Would you mind rating my response?
thanks...
Charlie
Posted on May 30, 2009
#1 Taper
  • 1041 Answers
SOURCE: Installing new line on my string grass trimmer
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Posted on Jul 03, 2009
  • 133 Answers
SOURCE: B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Posted on Apr 21, 2010
I used it yesterday and today it will not start. Battery is full charge. Button key is in place.
I would first take a meter and test that the battery actually charged. If that tests out fine ( should read at about 12.8 to 13.5 Vdc), I would then check all the wired connections to make sure they did not come loose.
Jul 19, 2015 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Trimmer starts but hardly rotates when giving it gas.
Check for a tangle of grass or wire just above the string head where it attatches to the shaft. A buildup in that area can interfere with the movement of the head.
Sep 10, 2011 | Craftsman Convertible 14" Gas Line Trimmer
The head of the trimmer will not turn. What could be common issues as a result?
Sometimes, strands of long grass wrapped around the shaft above the string head impede movement. On a more serious note, the driveshaft could be broken, or the clutch assembly could have malfunctioned. Disassembly will be required if tangled up grass above the head is NOT the problem.You can get help here to do the disassembly and repairs here, just ask!
Jul 01, 2011 | Echo Rapid Loader, Trimmer Head
Parts for Black & Decker 14" Grass Hog Xp Trimmer/Edger
Easily, the best place and discounted parts place for this Black and Decker trimmer is eReplacementParts.com
Oct 06, 2010 | Black & Decker 14" Grass Hog Xp...
Describe your Black & Decker
You can order these thru black and decker at blackand decker.com
Sep 12, 2009 | Black & Decker 14" Grass Hog Xp...
Jim
Jul 03, 2009 | Homelite Mighty Lite Lawn Trimmer
Line continues to advance and wrap around axle
I used a file to sharpen the line cutter which controls the amount of line. After sharpening the small cutter on the trimmer, the length of the line is now under control and now my trimmer works just fine.
Sep 13, 2008 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
Black & Decker String Trimmer Cordless 12" 18V Logo
32 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
