Question about HP Pavilion dv6000z Notebook
The laptop won't turn on, the computer is plugged in and the battery supply is full. If you press the power button. the keyboard lights up for only 3 seconds before going dark......a blue screen won't even show up.
    Guru:
  • 377 Answers
Soon as your pc boots start pressing f-12 then reboot from last known good configuration
OR
system restore earlier time
Posted on Sep 03, 2010
Stuck sleep mode
The solution to no post on a computer is to remove everything that you can, take out the hdd, the ram, and optical disk and see if it boots. If it does, put the RAM back, then try again, if it does, put the hdd back and try again. It is a process of elimination. If everything is removed and it wont boot, it may be the motherboard. I have also seen bad batteries do this. There is a chip inside the battery that wont let the machine boot when the life of the battery is expired.
Aug 19, 2017 | Toshiba Computers & Internet
I cannot get my Asus U52F laptop to turn on.
Unplug from AC, remove battery, plug into AC , boot normally.
Dec 06, 2012 | ASUS U52F-BBL9 Laptop
No power , computer will not turn on
Hi, IF the system is not turning on any more, try removing the power cable, then press the power button for 10 seconds. then try to power it on again . If it is still not powering up there could be an issue wiht the power supply of the computer. But if it start to turn on, like showing the Sony logo then windows but not going to the desktop. you can try to log on using safemode. you can go there by pressing F8 on the keyboard after turning on the computer. If it still not turning on even on safe mode. there couldbe an issue with the operating system of the computer and needs to be reinstalled.
Thank you for using Fixya, your recommendation is highly appreciated for the free support.
Aug 20, 2011 | Sony VAIO V2M (VGCV2M) PC Desktop
Logitech m205 won't work, the light keeps blinking
If your unit is a wireless keyboard only, then there is a button on the bottom of the keyboard and another on the receiver that is plugged into the usb port of the computer. In order to calibrate the system when it looses its signal, you have to press and hold both buttons down at the same time for 30 to 45 seconds. That means press the button the receiver and the button on the bottom of the keyboard at the same time and hold them down for 30 to 45 seconds. This will revive the signal and bring it back to working condition.
If your unit is a wireless mouse and wireless keyboard then there are probably 3 buttons involved that need to be pressed and held for 30 to 45 seconds at the same time. One button on the mouse, one on the keyboard and the last on the receiver.
If you press and hold the buttons down as explained above, it will correct the problem.
Jul 17, 2011 | Logitech Computers & Internet
Dell inspiron 6000 dead when connect power adeptor to laptop the led light on psu goes off is this mother board fault or psu.
If the led on the power supply turns off after connecting it to your laptop, the problem most likely lies with the power supply especially if the machine will run on battery power. This can be tested by
1. Turn the laptop off.
2. Remove the battery and power supply plug.
3. Press and hold the power button for at least 15 seconds to reset the laptop.
4. Replace the power supply plug into the laptop without replacing the battery.
5. If the computer will not start and there are no lights turning on on the laptop the power supply is bad.
6. Replace the battery and attempt to start the machine both with and without the power supply plugged in.
Apr 04, 2011 | Dell Inspiron 6000 Notebook
How to unlock the key pad on a dell latitude D600 laptop
Hi. Please do troubleshooting steps below:
1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
2. Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
3. Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
4. Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
Have a good one!
  • Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  • Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  • Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
  • Read more: How to Unlock a Dell Keyboard | eHow.com http://www.ehow.com/how_5063232_unlock-dell-keyboard.html#ixzz0uguUk4bZ
    Jul 25, 2010 | Dell Latitude D600 Notebook
    My compaq presario laptop keeps getting an error: 0211 keyboard error it says press F1 to resume or F10 to setup but neither one of them does anything when I push them. Can this be fixed?
    1. Turn off computer and unplug power cord.
    2. Disconnect all external devices(open up the computer tower and then )
    3. remove battery
    4. press power button and hold for 10-15 seconds
    5. plug power cord back into computer and press power button.
    6. Check LED’s and listen for power supply fan.
    7. If LED’s are on or power supply fan starts spinning, watch for boot screen
    8. If coputer begins to turn on, turn it off.
    9. Reconnect battery and external devices.
    10. Press power button and make sure computer starts.
    This should work....all the best
    May 19, 2010 | Computers & Internet
    Any idea why my Dell D610 is not booting up and showing a dark screen only
    You can try the following steps:
    1. Unplug the power from the laptop and remove the battery then press the power button of the laptop for 15 seconds
    2. Put the battery back in, turn on the laptop without plugging the power to the laptop (If this didn't resolve the issue)
    3. Remove the battery and press the power button of the laptop for 15 seconds, after that, plug the power cord and turn on the laptop (if this didn't resolve the issue)
    4. Remove the power cord and press the power button of the laptop for 15 seconds, disconnect the Hard drive and turn on the laptop (If this didn't resolve the issue) reconnec the hard drive
    5. Remove the Optical Drive and turn on the laptop (If this didn't resolve the issue) reconnect the optical drive
    6. Remove the memory chip, if you have 2 memory chips installed in the 2 memory slots (remove both of them) now test each one of the memory to each slots turning on the laptop. (If this didn't resolve the issue) Put the memory chip back in
    7. Reseat the CPU and try to make sure that it's installed properly. Turn on the laptop and test if it's gonna work (If this didn't resolve the issue)
    8. Reseat the power cords coming from the power supply of the laptop and test the laptop. (If this didn't resolve the issue)
    9. Disconnect everything and just leave the CPU installed and turn on the laptop.
    10. If all else fails, there's a big possibility that the problem may be with the power supply or the motherboard of the laptop.
    (Note: you may try to clean your computer if there is a large amount of dust. You may try to remove the CMOS battery)
    regards,
    sl4x
    Feb 13, 2010 | Dell Latitude D600 Notebook
    The computer is plugged in but it will not turn on
    Try removing battery, press and hold power button for 5 seconds, wait a minute, put battery back in and then try it again. If problem persists, then power supply is likely bad.
    Dec 16, 2009 | Acer Aspire 3680 Laptop
    I have plugged my Alto Coredless but it is not work. The like in the stand is not on.
    1. Make sure you have plugged in the stand’s USB plug into your note book first, and turned on your computer.
    2. Next, on the right side of the stand, there is a connection button.
    3. Press it. You will see lights (A and 3) Flashing back and forth.
    4. While the lights are flashing back a forth, look under the keyboard inside the battery compartment.
    5. Place in battery slot, 2 (AAA) batteries.
    6. Next to the battery slot is a little red button, press it.
    7. The lights on the stand should go out.
    8. Your keyboard is connected to your laptop.
    Jul 07, 2009 | Logitech Alto Cordless Laptop...
    HP Pavilion dv6000z Notebook Logo
    80 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
