Question about Fisher and Paykel Fisher Paykel 21768 - ActiveSmart Refrigerator W/ Right Hinge (White)
E442bre not working at all, I think it may have tripped my power last night, there is power at the plug still but no light or cooling in the fridge or freezer
  • 15 Answers
SOURCE: Left door open on freezer last night and now it wont work
turn it off for a day or two let it defrost and then turn it on. it just has frozen up the coil, or the compressor has heated up cause it was working to hard turn it of for a cople of hours to let the compressor cool
Posted on Feb 03, 2009
dmftrucker
  • 1922 Answers
SOURCE: Frigidair Gallery fridge/freezer... Freezer is
change the control board in the rear lower left corner of unit part# 4334000 2 appliance parts pros
Posted on Nov 02, 2009
BIKER T
  • 909 Answers
SOURCE: We have a 3 way Dometic fridge in our caravan.
Temperature does play a big part in the efficiency of the fridge. The condenser at the back of the fridge needs cool air flow to allow gas vapour to be converted back into a liquid.again.
Posted on Nov 12, 2009
Testimonial: "Tks Guru, BikerT. To prove that you are right - since the weather/heatwave has gone - a nice cool morning today and I have frozen milk. Cheers, "
  • 50 Answers
SOURCE: American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Posted on Jan 05, 2010
heatman101
  • 43501 Answers
SOURCE: FRIDGE NOT COOLING FREEZER OK, DEFROSTED FREEZER
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 04, 2010
Fisher & paykel fridge e521t no power to fridge,not any power coming to fridge
Did you try an other electrical outlet? Can you test the outlet has any voltage?
does the fridge have an on / off switch? I don't think so, so if nothing works also check the cable and the plug going in the outlet.
Mar 17, 2015 | Fisher & Paykel Paykel E521TLX2 Fisher...
Power surge brand new maytag fridge not cooling
That power surge probably burnt out the guse on the circuit board. I suspect you may need a new board unless you know an electricity geek who can replace the fuse. New I would check your warranty. That circuit board might cost $200. plus..
Dec 21, 2014 | Maytag MSD2756G Side by Side Refrigerator
I have a Dometic RM2652RBX Refer. The last two trips out it has given us problems. The first trip it worked fine all the way to Texas. We spent 2 weeks in Texas with no problems. We went to the Grand...
If the RV was level when it did not function. First you will want to open the rear vent of the fridge on the RV and check for a yellow residue above the burner area. If you do see that, then you will require a replacement cooling unit because the pipe ruptured. It is common in all new RV fridges that the cooling units lets go within 3 to 7 years. Check out ArctiCold Refrigeration We keep it cold the replacement cooling unit can be purchased through Ebay Dometic RM2652 Brand New Manufactured Cooling Units LIFETIME WARRANTY
Sep 17, 2013 | Dometic RM2652 Refrigerator
Side by side , fridge & freezer both stopped cooling last night, cleaned every thing this morning, unplugged for about 2 hours, plugged in and can hear fan running, but fridge and freezer do not seem...
did you feel the compressor runing?if not , need to check have power to the compressor. if power ok. i think the start relay or capacitor is bad. but make sure the condensor not drity. sometime it cause the problem. good luck
Jan 09, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
My Hoover Nextra fridge freezer is 9 years old in perfect condition. Fridge has stopped cooling but freezer is working ok. I have turned up temp control to super, motor is warm but silent. What could have...
Hi, I have a Hoover Nextra Fridge Freezer and last night it tripped all my electric. When I plugged it back in, it sounds like it is starting, but then after a couple of seconds clicks off again. Any ideas?
Dec 26, 2010 | Refrigerators
We have a 3 way Dometic fridge in our caravan. Have lived in the van for last 12 months ( grey nomads) have had no probs until trip home this week from Yulara to Victoria. Pulled up at night and freezer...
Nov 12, 2009 | Dometic RM2652 Refrigerator
Not cooling fridge or freezer.
need cooling at the back, unplug for about 15 mins, move it for about 1 foot from the wall then plug back.
Sep 15, 2009 | Refrigerators
Refrigerator compressor not working
unplug the fridge,remove the electrical cover on the compressor to see if any wires are burnt off.you may have a defective start relay,wire off or compressor seized,that age not cost wise to replace compressor
Apr 09, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Fridge not working on 12V or 220V
hi simon, i would say your ac heater is gone bad. it could have open up and no longer heating when you have a power surge . these heating elemenent are also located in the gas generator. you have to replace this heating element.
Feb 22, 2008 | Refrigerators
Fisher and Paykel Fisher Paykel 21768 - ActiveSmart Refrigerator W/ Right Hinge (White) Logo
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
