Question about Astro Pneumatic (AST5512EX) 12 Ton AirOverHydraulic Transmission Jack
Adjusting craftsman 50190 motorcycle jack so it doesn't come down so fast with a load on it
It idles fast if I turn the idle down it stalls running rich on top end at fast idle sometimes it will drop to a very low idle and shut off
adjust the idle mixture screws first and then adjust the idle speed screw to compensate
adjusting the idle mixture screws will alter the idle speed but when properly adjusted then adjust the idle speed screw,
Aug 24, 2015 | Motorcycles
Can't automatic adjust rear shocks
Actually, the Goldwing doesn't have adjustable shocks. What it has is a load levelizer and in order to adjust it for the various weight loads it needs to be on the main stand. Viewing the display will let you know the weight level it is set at. If that doesn't work, you will need to check for a blown fuse.
Sep 26, 2012 | 2008 Honda GL 1800 Gold Wing
Dod grunge metal fx69 pedal led doesn't work
Try jacking up car and put on stands as high as poss as you could have air returning when the pedal is returned ,so jack up car pump pedal 4 times fast and hold down bleed l/h/s/first ,do 2 times then the r/h/side and then push down pedal clamp rubber flex hose over back axlewith small G clamp if pedal good do same to FRONT
Sep 11, 2012 | Cars & Trucks
Weed eater bogs down when i try to give it full throttle, won,t get up enough speed and torque to trim grass. i tried new gas, spark plug, and still doesn,t help.
have to adjust the high on the carb. should have, 3 screws, 2 that are together is your h for high, and L for low. the one by itself is for idle. when mackine is running, squeeze throttle and adjust the high til it clears up, if it stalls real fast, back counter clockwise while off, and try to restart it, if worse, go the other way. i do mine by 1/4 turns. keep count of turns in case your going the wrong way! hope this helps!
Sep 15, 2010 | Craftsman 25cc Gas Line Trimmer
Craftsman motorcycle jack model KT2002050642 - I
There should be some notches either in the top rails or the bottom. If I remember right they were on the bottom. Looks like peices of small round rod welded. Maybe 3 or 4.
Look for the locker arm and see where you need to lift them up from. You will have to have the jack raised enough to loosen teh arms to make them come away from the welded peices.
Aug 11, 2010 | Craftsman Original Sears Craftsman...
My craftsman lawn mower acts like its slipping going up small hills
check ur drive belt [ runs from the engine upper pulley under frame to the rear trans axle thru a series of pulleys and spring loaded adjusters] the belt has probably worn down or has streched to where it slips under a medium load
Mar 13, 2010 | Craftsman Garden
I'd call them and give them the product number and see if they can mail you a manual.
Oct 06, 2009 | 1979 Harley Davidson XLS 1000
I have a 19hp craftsman 42 deck. It has two blades. It does not cut the grass in the center. It leaves a strip uncut. What adjustment should I do
You may be running too fast on ground speed for the mower deck to cut completely. It may be time for some new blades. The blades may be worn down to where they are shorter than when they were first put on.
Sep 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 3 ton floor jack will not stay up
you need to bleed the air from the cylinder. there should be an air bleed or else you bleed it at the relief needle. also, if it still leaks down after you bleeed out the air, the seat for the relief valve or the seals at the relief valve cartridge are worn
Apr 01, 2009 | Home Fencing
Astro Pneumatic (AST5512EX) 12 Ton AirOverHydraulic Transmission Jack Logo
147 people viewed this question
Top Astro Pneumatic Air Tools & Compressors Experts
Trippy Tripp
Tom Chichester
Are you an Astro Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
