Question about Kenmore Elite 45986 Front Load Washer
Water appears in drum after time. - Kenmore Elite 45986 Front Load Washer
  • 122 Answers
Sounds like you have a seeping water valve. Turn water off at shut off valve and see if that corrects problem, is so replace water valve
Posted on Sep 03, 2010
LG 1814CW washing machine leaking water
It may be time to replace that door seal again
May 07, 2014 | Washing Machines
When the washing mashine is finished, after two days water appear in the drum.Slowly but after one week probably would be full drum.What is the problem?
The water valve needs to be cleaned out or replaced. The water valve is the part on the washer that the hot and cold hoses hook to.Hope this helped.
May 29, 2011 | Washing Machines
There is a water leak but does not appear to come from the attached hose, nor does it appear to be coming from the door as the water appears to be coming from under the maching
youve got a cracked drum that needs to be gooped up. its easy to do, just pull the back off the machine apart then remove all the wiring to gain excess, once youve done this remove the plastic drum and goop the crack
May 04, 2011 | Kenmore Front Load Washer
New Samsung Wasging Machine Model:- WD-J1255R/YNG not functioning
your drain pump seems to be obstructed. If water is still in the drum, no spinning will take place. Remove pump and check the impellar for obstruction and the 2 pipes connected to the pump. make sure they are clear by blowing into the 2 ends. If you are able to, it would help to test the pump before you put it back into the washing machine.
Jul 17, 2010 | Samsung Washing Machines
Bosch WFMC 3200UC can't rotate the drum
that test indicates a faulty speed sensor or wiring harness.
Jan 23, 2010 | Bosch WFMC 3200 Front Load Washer
Water leaking under washer but no appearance of leaking from hoses
water seal inside washer drum may be damaged, causing water to come out along drum shaft.
Oct 24, 2009 | Frigidaire Washing Machines
I have water leaking out of the bottom of the drum. We came home one night and the floor and carpet were all wet after running a load of laundry. My husband and I,after cleaning up the mess, investigated...
Could be damage to drum ie hole in it .Pour some water in to it with a kettle or alike, this should tell you..Is it quite old or has damage happened due to coin,,Kind regards...
Sep 29, 2009 | Maytag PAV2300 Top Load Washer
Water appears in drum after wash cycle is finished.
if you remove the front cover there is a drain plug that holds change and lint paperclips etc, it fills up and gets plugged and wont go throught the drainig pump. if you find this and clean it out you will be good for another 6 months...its important to check pockets before washing
Sep 09, 2009 | Washing Machines
Water appears in drum hours after being emptied
could be several reasons...condinsation, if small amount of water moisture try leaving door ajar and see if evaporation takes care of it then you will know and it's possible that your water inlet valve has some "dirt" trapped in the seat and allowing water to seep into washer even though unit not calling for water
May 19, 2009 | Kenmore Washing Machines
Loud squeaky Noise
this is not 100% diagnosis as can't listen to noise but fault may be bearing lip seal disintegrating which is a serious fault and if im right then bearing will shortly go as well. reason it is noisy during start is that seal is dry and gets wet when full of water
Apr 18, 2007 | LG WM-2277HW Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
22 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
