Question about Dell 1703FPs 17" TFT LCD Flat Panel Monitor
I have a dell LCD model no 1703FPs monitor, whenever i power the screen its displays for about 4secs and turns black while the light indicator remains green indicating a video signal.
  • 11,361 Answers
You may have bad backlight inverter board (shorted transistors, transformers, need test lamp to verify), or worst case the lamps assembly (need lamp tester to verify).
You can check and see if the power supply is putting out the 12vdc for the inverter board first and go from there.
http://www.lcdrepair.us/1703fps-inverter.html
http://www.lcdrepair.us/1703fps-power.html
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 03, 2010
White part of display is a light green colour
it is due to problem with monitor display wire connector, either it is loose and if not visit service center
Feb 19, 2010 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell monitor 1703FPs
you backlights are going off.y ou need to replace the power supply in this monitor very comon problem
Dec 30, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Every time I turn on the monitor it will work for 1 second and then gets a black screen
Hi ,
Check when you boot the system is there any display coming and when Operating system boots you get any Balck screen if it comes then there is a issue with the Graphics card in the system.
My dell monitor 1703fps comes on for about 2 seconds
i think if you can service your monitor please see all the filter capacitor i think capacitors leak and need for replacement.
Sep 28, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
How do I get the case open on my Dell Ultra Sharp 1703FPs?
kenm951, You may want to see some vids on YOUTUBE that show disassembly of LCD monitors. Some of the longer ones (8 to 12min) are ok, but audio leaves something to be desired. The big question to you is why would you even want to open up your monitor?????? Bye for now. I'm louie12fix on fixya
May 06, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Powering on
checked your monitor with a qualified proffesional.
Apr 01, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Black Screen
No, this is typical problem for defective inverter. Mostly screen appears for some seconds and then turn to black. If you are technician, you can use this link :-).
http://www.lcdrepair.us/1702inverter1900x.html
Oct 01, 2007 | Dell 1703FPs 17" TFT LCD Flat Panel...
Black screen
Try pressing the 3rd button, as it toggles the Analog or Digital inputs...
Oct 05, 2006 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell 1703FPs 17" TFT LCD Flat Panel Monitor Logo
223 people viewed this question
Alun Cox
