Question about Dell Inspiron B120 Notebook
Hi, I'm getting a bsod with c00000021a, and cant get pass that; please help.
Reboot problems
Hi Dear,
The problem you discussed is hardware related, IT has to do with the cmos battery or the Sata cable.
Disconnect/Connect CMOS battery and reconfigure BIOS settings again based on defaults
- Replace "ALL" SATA Cables and reconnect all drives
Regards
Samson Ved
Oct 18, 2013 | Gateway GT5670 Desktop PC
Im always having this BSOD "BLUE SCREEN OF DEATH' EVERYTIME i open it BSOD always appears.. and everytime it appears i do the" repair(recomended)" then it turns on.. and when i...
Hi Faith,
BSOD's can be caused by ....well, lots of things...Drivers, hardware incompatibility, operating system, etc. Also diagnosing the cause would require above average knowledge.
I would suggest upgrading all your hardware drivers to latest releases. If not fixed, a clean re-install of Windows should fix it. (remember to back up your data)
Jun 11, 2011 | Computers & Internet
132-YW-E178-A1 Boots 1) XP x64 2) Vista Ultimate 64 3)Ubuntu 10.04 64bit & 4) Ubuntu 10.10 64bit Upgraded memory from 4x1GB 800MHz to 4x2GB 1066MHz. Both Ubuntu boot and run with no...
http://download.cnet.com/biosagentplus/3000-2098_4-10175528.html
This is an efficient, easy-to-use tool to help you figure out the details that make your computer tick. BIOS Agent is a lightweight freeware application with a clean and well-designed interface that lets you get the information you need with only a few button clicks. The program can retrieve information on the type of BIOS your computer runs and chipset type, as well as information on CPU, ROM, and RAM. Once you've gathered the details you need, you can save the report in TXT format or print it. There's no installation required for BIOS Agent. This program will be useful for administrators or power users looking to keep their systems up to date also there are many BIOS patches or udates you can download
hope this helps.
Apr 09, 2011 | Evga 132-YW-E178-A1 Motherboard
I cant installed the windows OS , its always giving me a blue screen windows. then it will stop installation. pls help me, thanks
first tell me what kind of windows your installing and what kind of BSOD your getting. every BSOD has a specific codes starts with 0x0. if you can provide thouse information maybe i can help you
Mar 27, 2011 | Acer Aspire T650 (AST650UC3601) PC Desktop
Cant activate windows xp home edition
Hi
Try and see what the BSOD says , when it suddenly reboots. Press F8 until it gives you a menu , go to advanced options or something similar highlight don't reboot or restart automatically.
Can you start your PC in safe mode. Try a crack although I wouldn't recommend it.
May 24, 2010 | Microsoft Windows XP Home Edition
Cant install audio driver, think i have the right
gaza1512
To be able to properly address your BSOD I will need some info from the BSOD. The link below will show you the info that I need.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Thanks
Issken
Dec 16, 2009 | Samsung V20 XVC 2400 Notebook
Bsod problem due to reliance lxu 800 usb modem drivers
Hello dear, I'm one of the users of LXU 800 modem. I tried all the sources and found there is no way resolving this issue because the manufacturer has not yet released any updates till now. I also heard the team at Reliance doesn't care about this issue because the actual manufacturer is LG. Anything to share? Meet me at 3hackerdude3@gmail.com. Have a great day. Yours truly, N Bhargav Reddy.
Aug 15, 2009 | Computers & Internet
Getting a bsod when projector is connected to laptop
Some projector have driver to get connected to a computer, check the manufacturers web site if there are driver downloads for the computer you're using.
Second;
What is your computers Operating System?
Have you updated your video card's driver? (some manufacturer release updated driver, check PC manufacturer website.)
Have you updated your Computers BIOS?
download the new Bios in your manufacturers website and install?
please indicate your PC's brand and model and Projectors Brand and Model so that we can help you better. Thanks
let me know the result? Good luck?
Mar 15, 2009 | Computers & Internet
R3000 Compacq laptop wont boot up
Hi.
Can you please give me full details on what the problem is, the BSOD, does it appear after the boot is finished and loading the OS?
Does the OS start and then get the BSOD, ETC.
If You have the original install cd, enter your bios and at BOOT DEVICES [OR BOOT SETTINGS] make sure that the first device to boot from is your cd/dvd etc, Put The Cd of the OS in the cd/rom and restart the machine, it will hopefully start the instalation of windows do not tell the program to install a fresh copy, but rather use the R for repair.
If that does not work or you still have problems it sounds like it's time for a new instal of windows, the BSOD [Blue Screen Of Death] pops up when files get damaged, if you overclock without checking everything voltages, fans, TEMPERATURE of CPU etc.
Also can you please tell me how long ago the system was activated, and what if anything did you do or were working on when you got this BSOD.
What the OS you are using is can help also, and is it sp1? sp2? sp3? for win XP even vista is up to SP1 already for a supposed new os from ms.
HTH
Zues
Dec 21, 2008 | Computers & Internet
Dell Inspiron B120 Notebook Logo
285 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
