Question about Bosch SHU9926UC Built-in Dishwasher
The washer arm that extends between the upper and lower rack has fallen off from the back wall of the dishwasher. Is this supposed to be removable? I dont see any broken plastic....
  • Bosch Master
  • 2,605 Answers
Hi, Welcome to FixYa. In a word...yes, to answer your question. I would also add it shouldn't come off too easily. If you observe closely on the back wall of the diswasher where the supply tube is mounted you'll see a metal "clip" the tube snaps/fastens to. I'm presently using my iphone, but I can attach an image tomorrow if it isn't clear to you how it fits back in place. Let me know how it goes or if you need further assistance. Thanks for choosing FixYa. I'll watch for your reply or post of your progress/results. Regards, Macmarkus :)
Posted on Sep 03, 2010
  • Mark MacDonald
    Mark MacDonald Sep 03, 2010
    This is what it should look like...
    Let me know if you need anything.
    Good luck.
    Regards,
    Macmarkus :)
Why doesn't my Bosch SHU43 c06uc dishwasher have any cleaning force?
With your dishwasher empty, roll out the bottom rack. The feed line for the upper spray arm runs from a pump outlet directly behind the lower spray arm spindle. This tube runs up the back wall of the dishwasher and mates with the upper rack when it is pushed in.
This feed tube simply snaps into place in the bottom of the machine. It is a high pressure line that makes an immediade 90-degree bend towards the rear of the unit. They have a tendency to pop out. When and if it does pop out you get almost no water coming out of the upper arm and you lose effective pressure in the lower arm, too. The cure is to push that feed tube back down firmly into the port until you hear it snap into place. While you have the lowere rack out it is a good idea to clean the intake screen out and check for any debris in the intake well.
May 24, 2014 | Bosch Dishwashers
Hello there, I have a Bosch Logixx dishwasher which I purchased just over 2 years ago. My upper dishwasher tray is not fitting properly into the hose pipe holes on the inside of the back wall of the...
Hello Deepak,
You can definitely fix this yourself, but I'm not entirely sure from your description which part is "dropping off". It may be a simple fix where something needs to be clipped back into place or you may need to replace something. Please can you take a look at the images below and identify which part you are having trouble with.
Below is the back of the upper spray arm which clips on to the upper rack. It has a grey plastic cover behind which is a large white plastic washer / gasket. The washer simply slots in to the back of the spray arm and the grey cover clips in over the top.
Your description suggests the grey plastic cover and/or the white washer are dropping off. If the grey plastic cover is missing, it may have fallen into the bottom of the washer under the lower rack, in which case you should be able to find it and clip it back on. If it's missing or wont clip back on, you will need to replace the upper spray arm as the cover and washer are not available separately.
This is the water delivery tube which clips to the back wall of the washing compartment. There is a metal clip which secures the tube to the wall. The open hole and one of the spigots slot in to the two holes in the back of the upper spray arm above. The spigot used depends on which height setting the upper rack is on.
Basically, everything simply clips together. If nothing is broken, you should be able to fix this at no cost by simply clipping the offending part back into place.
Hope this helps. If you need further assistance or help locating replacement parts, please let me know what needs to be replaced. Nearly all Bosch parts are available and in stock direct from Bosch.
Regards,
BElectric
Apr 13, 2011 | Bosch 24 in. SGS69L02 Logixx Built-in...
How to replace the top rollers on a GE dishwasher model # gsm1800nww
Lower Rack
  • Remove all of the dishes from the lower dishwasher rack.
  • Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
  • Lift the lower rack up and out of the dishwasher.
  • Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
  • Upper Rack
  • Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
. Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
  • Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
  • Pull the upper dishwasher rack straight of out the arms to remove.
  • Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
  • Align the end caps with the ends of the arms, then push the end caps into place.
Feb 04, 2011 | Maytag Dishwasher
Not sure if upper spray arm is working. Dishes on top shelf remain dirty. Lower arm works early in cycle but not top. Are they supposed to be working at the same time?
Something is blocking the extender from getting to top spayer arm. Push all drawers in and look to see if extender can be manually raised to arm. Slug buildup can effect a dishwasher also. clean with bleach and water. Pour bleach in the washer and run thru one cycle.
Oct 11, 2010 | Asko D1776 Built-in Dishwasher
Lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Suggestion;
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
Dec 14, 2009 | Siemens Dishwashers
Upper rack is not cleaning. Greasy dishes on top seem that dishes are not being washed. Seems the upper water turning dispenser is not working, Bottom rack seems ok. I guess I only have half a dish washer...
Check the upper arm for free spinning, then remove the arm and check that the seam between the upper and lower halves has not split somewhere. Also check all the small holes for debris plugging. Run the machine in wash cycle for a little while with the upper arm off--that should flush out anything blocking the pipe up to the arm. If still nothing from the upper arm, tear down the lower arm assembly down to the deck while noting position of all parts removed. Clean the big screen at the bottom in white vinegar and hot water. Inspect the holes in the bottom for anything blocking them.
Aug 15, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
How do you fit the upper spray arm to the back of the dishwasher
The upper spray arm does not fit on the back of the dishwasher. There is a separate "Extra Tall Item Sprinkler" piece (about a 3-4" round gray piece that looks like a shower head) that mounts in the back of the dw.
Note that this option is only to be used with the top rack removed (i.e., for washing tall items in the lower rack). Refer to page 37 of the Use & Care Manual that came with your dishwasher.
Jun 23, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Upper wash tube assembly came off back of unit. can not reattach.
We had the same problem with our Bosch 4800 and found that the upper wash arm and tube assembly should attach to the bottom of the upper rack (rather than to the back of the dishwasher). The wash arm and tube assembly slides in and out with the upper rack. When the dishwasher door is closed the tube assembly is forced up against the back mounting/water supply.
Nov 30, 2008 | Dishwashers
Dishwasher needs repair
Bonnie, the spray arm itself will have a tower that extends upward. On the lower rack in the center will be a tower protector and the upper rack should have a water diffuser in the middle. The protecter and diffuser will clip on to the center of the racks. Hope this gets you going..
May 28, 2006 | Roper 24 in. RUD5750DB Built-in Dishwasher
Bosch SHU9926UC Built-in Dishwasher Logo
63 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
