Question about Refrigerators
I am replacing the left side panel of the crisper drawer but not sure how to remove the screw with the hexagon top where the access hole is to small for plyers. Is there a special tool I should use?
  • 122 Answers
1/4 socket of nut driver
Posted on Sep 03, 2010
Water in bottom left crisper drawer and under drawer
I'm sorry to say that it sound as though your door gasket may no longer be sealing correctly.
For me, it's simply a task of getting a replacement gasket for that make and model.
To remove the old one you would, simply, peel the inside of the gasket toward the outside of the edge of the door revealing the mounting screws. Remove these screws all the way around and replace with the new one in the same fashion...
The reason that I recommend this is that humid air outside of the refrigerator can seep past a worn gasket and condense on the inside surfaces making its way to the bottom and into those drawers.
Feb 16, 2014 | Whirlpool Refrigerators
My refridge is leaking a little bit out the bottom .No hose lines are leaking.What could it be?
as a general rule for refrigerators with top freezer compartments, if you have water
leaking under fridge it usually is the drain line exiting the freezer compartment.
This is accessed by removing (usually 4) screws on the back panel and pulling
the panel forward and unplugging the fan, sometimes it is necessary to remove the
fan seperately and carefully unplug the fan.
in the center there will be a hole exiting the freezer, sometimes with an aluminum
wire in it to help keep the hole de iced. clean this hole out and squirt a turkey
baster or two of hot water in to check drainage. listen for the trickle under the fridge.
Remember to pull crisper drawers out and remove water as it has accumulated below.
If the temp control assembly
goes all the way to the back of the fridge, it may also have a
built in cup which clogs. It detaches by removing 4 screws and pull forward and
down then unplug the unit and slide out. Make sure to unplug unit before servicing.
Apr 05, 2011 | KitchenAid Refrigerators
I need directions how to replace a 1630 fuser assembly.
Make sure copier is unplugged. You need to remove the glass by removing the left side panel. Remove the two screws and remove the panel. Remove the glass. You should see a ribbon cable on its side with a black cover. Remove the cover. It provides access to the hole you should see. Slide the top to the left and remove the drum unit. While the blue top is up, remove the screw that holds the control panel secure. Lower the blue cover and remove the control panel. Be careful of the ribbon and unplug it. You should now see the access hole to get to the screws that secure the fuser assembly. Remove 2 left side covers by removing the three screws. The one screw you see at the front I remove to make it easier to remove the cover that has edges below that cover. Then remove the cover that is above the delivery area. Turn back the milar sheet and unplug the three connectors that are routed to the fuser. Remove the three screws and carefully remove the fuser assembly. Carefully reverse the procedure for the replacement fuser or rebuild the fuser assy by taking the fuser assembly apart. I hope this is enough to get you started in the right direction.
Jan 29, 2011 | Canon Image Runner 1630 Copier Copier
How do you get the front panel off of a Frigidaire Washer Model ATF8000FS1 to get at the coin trap?
The 7000 model and probably yours too, does not have a small front panel at the bottom that comes off. You can't access it from the back. The four screws at the bottom of the full front panel come off-- then go to the back and take off the top. Remove the screws at the detergent/softener drawer, and take it out-- remove the screws on the control panel and it can lay on the top of the machine... you can then get at the top screws on the front control panel... remove them and before taking it completely off... remove the contacts in the right side of the door by removing the two stainless screws similar to the ones removed from the detergent drawer. You should be able now to pull the front panel to access the boot.. Be sure to pull out the coin trap fully and rinse everything out... when putting it back be sure all the clamps and brackets are replaced properly or it will leak.
Jan 08, 2011 | Frigidaire ATF6000ES Front Load Washer
Water in wood's fridge
If you have the wire metal shelf model, there is a wrap around cooling plate (back and two sides) at the top of the inside. The frost that forms on this while it is running melts off after the compressor stops and the water runs down, into the drip channel, and out the drain hole at the center of the channel on the back wall. Clean out that hole so the water will flow out instead of down the walls to the bottom of your refrig.
If you have the glass shelf model, you have to remove the metal cover at the bottom back of the refrig and clean out the defrost drain hole located there.
May 21, 2010 | Refrigerators
How to completely clean the Crisper drawer
I don't know if you've already figured out how to remove the front panel on your refrigerator crisper bin, but here it is. Once the drawer is removed, pull back those clips on the top left & right of the front of the drawer.Just hold the side and pull back at the same time, then you can remove it. Once both side have been released you should be able to remove the clear plastic front and clean both pieces. I hope that is clear enough. Best of luck, unless of course you've already discovered the answer yourself.
Feb 21, 2010 | KitchenAid Refrigerators
GE with top freezer has water accumulating in bottom of frig under the crisper drawers.
Remove the food from the freezer , then remove the icemaker , if it has one ( 2 screws ) . Remove the rear freezer panel . Useing a hair dryer , start in the middle of the drain trough , and defrost until you see the drain hole . Keep defrosting the hole ( hot water helps ) until water will go thru . Use a piece of tubing inserted into the hole , and blow thru , to remove any debris accumulated in drain line .Remove any excess ice from trough . Reassemble freezer .
Aug 27, 2009 | GE Refrigerators
Water pools under the crisper drawers and looks as if it is draining from the upper freezer down the side of the refrig door, looks like the little hole under the crisper is clogged with rust?? It is a old...
Mine clogs with a soft fungus mat but rust actually sounds better. I run a stiff wire like an unwound hanger into the hole and open it up so the water will drain onto the tray made to collect this water underneath the fridge. Last time I left the wire in place with a long handle and I haven't had water to mess with for many months now. My hole is between the two crisper drawers and when I get into either of them the wire gets a jiggle and I guess that's all it takes to keep the hole clear so the water can drain like it's supposed to.
Otherwise the fungus builds and builds until it sluffs off as a wad and plugs up the works on a regular basis. Too funky for sure.
Jun 21, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Whirlpool duet washer model GHW9400PWO
Removing the Washer Top
Three screws secure the washer top at the back of the washer. Remove the three screws and lift the top from the washer.
Removing the Console from the Cabinet
Disconnect the Touch Pad/LED Assembly ribbon connector from the left side of the Central Control Unit and release it from the wiring harness brackets on the right side of the washer top
Remove the detergent dispenser drawer by pressing down on the release tab at the back of the drawer and pulling it completely out of the washer.
Once the drawer is removed, remove the screw in the recessed hole next to the drawer opening. Release the tab securing the right side of the console to the washer
Open the washer door and place a flat-bladed screwdriver into the slot in the bottom center of the console. Push the console up to release center console tab. Be sure the ribbon cable clears the cabinet frame.
Removing the Touch Pad/LED Assembly from the Console
The Touch Pad/LED Assembly is removed as a single unit and contains the Push Buttons, LEDs, cable, etc. The buttons can be replaced separately
Jun 28, 2008 | Whirlpool GHW9400 Duet Washer
Hotpoint FFA70
Remove the plastic venting box which feeds cold air over the top of the freezer drawers,There are 4 hexagon headed self tapping screws,two at top.and two bottom.Now defrost all ice off rear of freezer and back of vent box.Now replace and door will shut with draws in.Make sure no ice left round fan housing.
Jan 21, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerators Logo
16 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
