Question about Maytag MEW5530D Electric Single Oven
Install electric walloven under gas cooktop
I have mgc5536bd gas cooktop to be intalled over mew6530dd walloven in regular 36 inch cabinet
  • Anonymous Dec 03, 2008
    Is is safe to install an electric oven under a butane cooktop?
  • Anonymous Mar 13, 2014
    Why do manufacturers use silk screen decals on hot gas cooktops?
    Problem Solver:
Cheked on installation guide available with product online
Posted on May 11, 2008
Constant beep beep beeb from Maytag
Jun 30, 2014 | Maytag 30" Built-In Single Electric Wall...
I just had a Frigidaire electric Single Wall Oven (FGEW2745) installed under a Bosch gas cooktop. The cabinet maker didn't allow enough room for the oven so my contractor had to lower it. However, as...
Any handle you replace on the oven will certainly void its warranty, especially if you have to drill the door to fit it. Generally the oven handle is designed for the oven, and as such most manufacturers dont make different door handles for them. Most likely you will need to get a different oven altogether, or void your warranty and find a suitable handle and attach it to the oven door yourself by some means.
Hope that helps.
Feb 24, 2011 | Frigidaire FGEW2745KB FGEW2745KW Electric...
MEW6530DDS keypad not working
Check out for a good price on your control board.Have the part# available you need or click on their "live chat" feature for help.
Aug 06, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
The wire that connects the heating broke off on
You're going to have to pull the walloven and take off the back panel. And probably replace the high temp terminal on the wire. You may want to pay a pro for this. You mess up the cabinet it's your problem but a reputable service company has experience and insurance and the right equipment to remove the oven
Aug 06, 2009 | Whirlpool RBD306PD Electric Double Oven
Gas oven electrical hookup issue
Hello. I can help you. What you have there at the wall is a circuit with 120 volts of power available. Your Gas oven requires 240 volts of power, thus the additional [red] wire. That said, they do not match up.
You will have to run a 240 volt wire from your electrical panel to rear of your stove opening with the correct circuit breaker in the panel, the correct amperage wire to the stove, the correct receptacle for the stove and the correct plug on the stove.
This is serious electricity here so do not proceed on your own as you could get seriously hurt or worse.
Aug 02, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
Gas Double oven (Built in)
It is definately not possible to change a gas to an electric. There are very few options for double gas ovens as electric is far superior. IF you have to go with gas , check out the local Habitat for Humanity store. You should be able to buy a used gas oven. It probably won't have the self clean feature. You would be better off trying e bay or a local scratch and dent outlet for a nice electric convection oven. It will need a seperate 220 volt circuit probably 40 amps. This isn't as expensive as you would think. Use the installer from the dealer you purchase the oven from. They are usually a lot cheaper than a union electricial worker. The 4 sizes available for built in ovens are the old standard of 24" the newer standard of 27" and the most common and useful 30" This is the current standard but you will also still be able to get 27" There is also a custom standard of 36" which would be for the very high end lines. These are all width measurements. The height will vary with the model. Most cabinets are made to accept various heights by removing one or more drawers underneath.
Jul 15, 2008 | Equipex PZ-330 Electric Single Oven
Front Panel Buttons not responding
The touch control panel is a piece of ****! Call MAYTAG, and get a new one, you should still be under warranty. Make them send you the part direct ( its the WHOLE front top panel ), then call a tech to put it in for $50 bucks. Takes about 10 minutes to do. The panel plugs into the electrical Board behind the panel.
FYI...the Top panel includes the Stainless Panel + the Touch controls! Its all one integrated part. The part that goes bad is the "cable contacts" that latch to electrical panel.
FYI....the Cable is made of "thin clear film " similar to Film you put in a Camera.
Jun 19, 2008 | Maytag MEW6530DDS Stainless Steel Electric...
Thermador 6 Burner cook top
It sounds as though you have soem nice, well sealed cabinets and a good installation on your cooktop. When you open the drawer. it creates a momentary vacuum that sucks the oxygen away from the cooktop, as the bottom of these are not airtight. The only thing you can do is to open the drawer more slowly or have a vent of some sort installed in the back of the cabinet to let air in as you open the drawers, so it does not suck it from the top.There really isnt anythig wrong per say, it something that happens with most gas cooktops with drawers/ doors below them. Hope this is helpful.
Dec 27, 2006 | Thermador SMW272 Electric Double Oven
Maytag MEW5530D Electric Single Oven Logo
174 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
