We could not turn on the Panasonic Double Feature by remote or by manual. It is dead no power going in. What is the problem and how can we fix it?
  • roberto_cuat Sep 06, 2010
    Checked the fuse its o.k. What is a bad power converter, how do you know that it is bad, whats it look like?
  • 11,896 Answers
Remove the cover, look inside next to the power supply. You should see a glass bus fuse. It may be blown. If not, it may be a bad power converter.
Posted on Sep 03, 2010
  • Nate Stansfield
    Nate Stansfield Sep 06, 2010
    That is the little box that is attached to the power cord. It switches the 120 volt house power to a lower voltage that the control board can carry. If you look on the back of the microwave, it should say DC Voltage Output. This number should be the same reading as your voltmeter. You can test the inverter where it is attached to the control board.
I have a Panasonic SC-BTT775 which will not switch on, there is power there, but when I press the power on button on either remote or the unit there is a double clicking sound and then nothing happens
The clicking sound is probably a relay that is performing a safety feature. However the fact it double clicks might mean it is switching on then switching straight off again.
That to me indicates that it has detected an overload. You should check your speakers and wires for short circuits, bad connections and all the rest that can cause shorts in the speakers set up. If that doesn't clear it, you could have a short in one or more of the power amplifier transistors or semi-conductors found on the big heat sink inside.
Aug 01, 2015 | Panasonic Audio Players & Recorders
Can't turn on my direct tv from remote
1) reset the code again.
2) clean the contact batteries
3) retight the spring contact batteries for better contacts
4) resolder the wire contacts batteries.
5) try again,
6) if doesnot resolve the problem go to the repair shop TV for fix it.
God bless you
Jul 20, 2012 | Raymarine Televison & Video
Need a remote code for a panasonic double feature (vcr/dvd combo) for a philips magnavox universal remote
Hello, here are the panasonic codes, one of these should work:
007 107 516 608 618 718 807 901
To enter the code, follow these instructions:
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the code tables. Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand.
Sep 05, 2011 | Universal Remote Control Remote Control
Everytime we try to use the DVD remote the code RC 1 pops up on the player and it doesn't perform the desired function. Is there a simple way to fix that?
Yes there is a simple way to fix this. I do not have a Panasonic manual in front of me right now but this is how to fix this problem on a different brand. If this does not solve the problem the answer should be within the first few pages of the manual:
Do this please. Turn off the power to the blu ray player if it is on. Press and hold down 1 and without letting it go press power along with it and hold them down together for more than 5 seconds.
If the power to the blu ray player turns on walk over to it and turn it off by pressing the power button located on it. If the power to it doesn't turn on then don't worry about that step.
Next point the remote control at the tv and press and hold down the display button for more than 10 seconds. Now press the power button on the remote control and the bluray player should turn on and off normally and you shouldn't get rc-1 anymore
Sep 28, 2010 | Panasonic DMR-EZ17 DVD Recorder
Universal remote will not work my panasonic DMP-BD605
Have you tried all the codes associated with Panasonic on your universal remote?
Mar 17, 2010 | Panasonic DMP-BD60K Blu-ray/DVD Player
Panasonic Double feature DVD/VHS deck. DVD player not working. Inserted disc, pressed play. Says, "Reading" then cuts to blue screen.
Oct 12, 2008 | Televison & Video
Remote control does not work at all.
The winner is....
SET 1 on the console; press and hold the ENTER button down and while holding Enter; press and hold "1" button for about ten seconds together. Your remote and console should be in sync again and try cutting off the dvd recorder with the remote and it should work.
THIS WORKED FOR ME!!!!
THANKS!
Feb 18, 2008 | Panasonic DMR-ES35VS
Panasonic CQ-VD7001U
You will likely have to purchase another remote. I don't know of any solution. When I had a problem with my panasonic, it was VERY hard to find a solution to the problem. They wanted me to ship it back to them and it ended up being I had a dead battery in my remote and the radio wouldn't turn on with the power button on the radio. Good thing I tried the battery before I sent it back. I would try ebay first to find a remote. If you can't find one, try to find someone who has the same radio and borrow their remote long enough to disable the anti-theft feature.
Nov 21, 2007 | Panasonic CQ-VD7001U Car DVD Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
