Question about Peg Perego John Deere Gator HPX Ride on Toy
No reverse on either side, and no 2nd gear on the right
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Bad motor, you can order a new one here www.powerwheelsoutlet.com
Posted on Jun 13, 2012
3 Suggested Answers
SOURCE: will only drive forward in 1st gear, 2nd gear and
It is propably the gear box. Take the seat off and you will see the gears inside. Mine works only in 2nd and not the 1st or reverse. But I know it is the gear box since my husband replaced the 1st one a while agao. Just need to find the web site for the repacement part. Only cost us about $30 to fix last time. Hope this helps.
Posted on Jul 10, 2009
espressonist
  • 1711 Answers
SOURCE: I have a John Deere
From your description the problem is a motor problem. You should turn the wheel manually and is it can rotate freely, if not then the motor is stuck and you can check the ball bearing if it is rusty or dirty or both and this can make it hard to rotate and that is why it become warm.
Posted on Nov 13, 2010
Only 1 wheel turns in 2nd nothing in 1st or reverse
you have a bad motor, whichever side isn't turning you need to replace that motor
Jun 28, 2013 | Peg Perego John Deere Gator HPX Ride on...
Gear shifter will not go in park. shows in reverse but is actaully in park. all are off by 1.. R=park, N= reverse, D-= neautral, etc
check that the selector on the side of the tranny is tight and properly adjusted. Re adjust so that gear selected lines up with lights
Jan 13, 2013 | 2002 Ford Excursion
Peg Perego John Deere Gator left wheel wont engage in 2nd gear, just replaced both motors and problem still exists. Any help?
disconnect the wires from one of the motors and check to see if it works in all gears, then do this with the other motor, then swap the wires from the left side to the right and vice versa, if both wheels spin in all the gears then you need a new shifter switch
May 22, 2012 | Peg Perego John Deere Gator HPX Ride on...
Will not go in 2nd 4th reverse
HI there
God Bless you
AS you said there is problem with 2nd, 4th and Reveres gear if you observe all gear are position is to down side or one side all gear have to shift one direction , it seems problem with gear box , need to open and check gear box assy.
Thanks for using Fixya
Sep 26, 2011 | Cars & Trucks
How do you engage 2nd gear. only works in reverse and 1st gear.
is the limiting screw still in the gearbox? just remove it and it should shift right into 2nd gear.
good luck!
Jan 01, 2011 | Peg Perego John Deere Gator HPX Ride on...
2nd gear won't work
probably a bad/disconnected shifter switch first of all check to make sure that the shifter switch is connected underneath
Oct 08, 2009 | Peg Perego John Deere Gator HPX Ride on...
Will only drive forward in 1st gear, 2nd gear and
Jun 28, 2009 | National Little Tikes Hummer Yellow
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
No reverse sometimes geo metro a/t
The accelator cable is "Y" shaped. one side goes to the carb and the other to the tranmission. If you have the carb.side too tight it will give you the problem that you are having.
Robert
Jun 28, 2008 | 1991 Geo Metro
Peg Perego John Deere Gator HPX Ride on Toy Logo
29 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
