Question about Cameras
Piece that holds lens doesn't close properly and now camera won't go
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 03, 2010
How do I fix lens error problem on the described camera?
hi,
lens error occur normally when it fell or the lens shaken, if so open the camera, take the lens unit out, disassemble the lens unit, then fix it again properly. example below:
(this is not the told model)
Dec 10, 2015 | Nikon Coolpix S3000 Digital Camera
Lens error restart camera canon SX10IS
Here are some troubleshooting steps for a lens error. And here's a video summary of those steps:
Jan 23, 2013 | Canon Cameras
My lens won't close on a lumix DMC-TZ5
Here are troubleshooting steps for that issue:
Dec 14, 2012 | Panasonic Lumix DMC-TZ50 Digital Camera
Canon PowerShot A3100 IS won't turn on
Make sure the battery is installed correctly.Try opening, then closing the cover to the memory card and battery compartment while holding pressure against it until you hear it click closed. Then try to power it up. The camera will not power up if the cover is not properly closed.
Aug 22, 2012 | Canon PowerShot A3100 IS Digital Camera
Lens won't close and On/Off button doesn't work
Even though the battery appears to be charging it may be shot. Some batteries if they run down too far can not be recharged. You need to try a new battery in the camera.
Jul 25, 2012 | Nikon COOLPIX S6000 Digital Camera
New Canon EFS 18-135mm IS lens failed to auto focus on EOS Rebel XTI and shutter won't release to take photo. Lens over a few months has worked without a problem. What is the problem?
Make sure both the lens and the camera are switched to af (auto focus). If that doesn't work remove the lens and replace it to make sure it is mounted properly. You can also check the camera with a different lens to make sure it isn't a problem with the settings on the camera. If all of that fails take it to a camera or electronics store that does service work to make sure it hasn't been damaged.
Jul 30, 2011 | Canon Cameras
I dropped the camera and the zoom lens got off line. It won't close or go back in the camera. It looks stuck and I tried pushing it in but I'm afraid that I might push hard that it'll break...
The lens may be fixable but most likely will need to be replaced.
If the lens is stuck straight or won't come out at all it needs to be replaced.
If the lens is stuck at an angle then you may be able to snap it back to the center by pressing the edge of the lens back towards center while holding on the outer ring of the lens.
Hope this helps!
Thomas Drayton
Owner, www Darntoothysam com Digital Camera Repair
Jul 21, 2011 | Canon PowerShot SD1200 IS / Digital IXUS...
My SL502 camera's lens won't open or close properly is there a way to fix it?
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
heatman101
Jun 28, 2011 | Samsung SL502 Digital Camera
MY lens on my camera wont go down and now my camera wont work
If I recall correctly, there was a recall for this issue and alot of people had this problem in the past. We contacted the manufacturer and they refunded our money. Here are some other things you can try. Hope this helps.
Here are some simple things to try first for a camera that won’t power on. They won’t work for every case, but they’re worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
If you get it to respond, and if next the lens doesn’t want to retract:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 26, 2009 | Polaroid T730 Digital Camera
Not turning on
Hello Ariel, You need a new battery lid. The problem is the lid has a pin that when closed properly, allows the battery to power up the camera. You can get one for $30.00 on Ebay item number 7623965577 if you act fast. This is a good camera and would be worth $30.00 (plus 5.50 shipping) to fix it. Please let me know how it works. Best regards, nightdiver
May 31, 2006 | Kodak EasyShare C340 Digital Camera
Cameras Logo
13 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
