Question about Makita Tools & Hardware - Others
Makita 9227 polisher runs wrong direction what do you think it could be
3 Suggested Answers
Biggdex35
  • 333 Answers
SOURCE: I need to know where to grease my makita
I dont think you can grease it. It has sealed bearings
http://www.ereplacementparts.com
Posted on Jun 02, 2010
yutianyunren
  • 848 Answers
I need to know where to grease my makita sander/polisher 9227? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
742GL2 715G2538 3 LEG Lenovo ADTV742GL2 Power Supply Backlight Inverter...
Posted on Jan 15, 2015
Makita 9227c polisher started clicking and i smell smoke
sounds like you have a problem with the armature. To easily check UNPLUG tool and turn the spindle by hand and listen for the clicking. It sounds like it may be a raised commutator bar. You can also remove the brushes and look into the brush tube with a flashlight and look for a major discoloration of the bars or one that is raised.
Dec 18, 2011 | Makita 7" 9227c Buffer Polisher Sander Kit...
Makita 7" 9227c I
the part number is 224517-1 and you should be able to find it at any hardware store that sells Makita tools or you can buy it online from "makitausa.com" they also have a service center locator that you can use to buy it locally. Let me know if you need more assistance.
Jun 17, 2011 | Makita 7" 9227c Buffer Polisher Sander Kit...
I need a set of brushes for the sander polisher.
try going to Makitatools.com and buying them direct from their site or find there service center locator for authorized repairs and buying them that way. Let me know if you need more help and if you do please furnish me with the zip code if you have one and the exact location and I will try and find someone local if I can.
Nov 23, 2009 | Makita Tools 7" Electronic Sander/Polisher...
Speed varies on its own
You must replace the speed control module. Any Makita service certer can supply you with the proper parts.
Mar 08, 2009 | Makita 7" Electronic Sander - Polisher...
MAKITA 9227C?
Copy and paste this link in to your web browser search.
You should find it there.
Good luck...
Feb 24, 2009 | Makita 7" Electronic Sander - Polisher...
How to wire the switch
It doesnt really matter on tehse machines as thay are double pole switches ( I think) so the switch operates against both terminals. I usally put live (brown) into pos 1 and neutral (blue) into pos 2. Like I say it shouldn't matter on this machine, but if the pad does spin the wrong way when you start the tool, just turn it off, unplug and switch the wires around. It's only really the older machines and those with reverse switches that are polarity sensitive.
Jun 24, 2008 | Makita 7" Electronic Sander - Polisher...
Makita 9227c stall
Hi hope to help
Have you tried this unplug the machine! then cut the cable about 6" from the machine then strip the machine and rewire the long length of cable back to the switch. The 6" that has been cut from the machine discard it.
The problem i used to get is where the cable is clamped in the handle the wire inside the insulation cracks so that when the machine is in one position is ok but then when is moved it goes off again.
It also could be the field coil (part of the motor) if it gets hot then cuts out the field could be braking down!!!
hope this helps.
Feb 29, 2008 | Makita 7" Electronic Sander - Polisher...
Tools & Hardware - Others Logo
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
