Question about Brother XL3750 Mechanical Sewing Machine
I have a brand new Brother XL-3750 I cannot for the life of me get the tensions to work. I know it is probably a threading error or something but I have tried everything so far. I need help!
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 56 Answers
Hello to fellow seamstress; from repair tech.
I went to this manual site, and found YOU can request a professional search for a users manual or a REPAIR manual (for a sm chg)
With purchasing a NEW unit, didn't they give you a warranty or training or a manual? Why haven't THEY helped you?
I found a download for $8. for the Users manual.
I think my good unit is a Brother, it has been a while since i sewed -- medical prob -- but, when i set my tension, I would start by putting the bobbin all the wa tight then loosen it until it just flows out at a pull but NOT a tug...hard to desc on paper.
THEN on to upper tension....thread machine -- not thru needle, just above, As you pull thread thru upper area, again, tension should give just a tiny tension to you, not a tug.
This should give you a start. Then, with light wt fab, ck to see if LOOSE loop is on top or on bottom, and adj from there...a teeny tiny bit at a time.
Do NOT Rush this...take your time.
(If this has been helpful, please rate my help++++Thanks for using FIXYA)
Posted on Sep 03, 2010
I'm having a problem threading my brother sewing machine model XL 3010
1. Clean up any loose thread in the bobbin area.
2. Pull on the bobbin thread while it is out. It should give a tension that is equal to the top tension of three. You'll have to approximate. Adjust the screw tension on the bobbin. It is the screw nearest to the thread exit hole on the side.
3. Put it back in.
4. Now, the top tension should be at about three. If it still allows a little wad on the bottom of the fabric you can adjust the top tension by tightening a small amount and monitor each time you adjust. The wad should go away.
Oct 05, 2016 | Brother Sewing Machines
The top and bottom threads won't connect, to make a stitch.
Replace the needle with a brand new "Schmetz" needle..
If it still won't pick up the bottom thread, take it in for service.
May 13, 2014 | Brother XL-2610
Brother XL-2600i upper tension too tight even when set to ZERO
I agree with you to take it back & buy another brand
Sep 30, 2012 | Brother XL-2600
When moving top tension thread not tightening.
Raise the presser foot and pull the thread through at the needle.
Re-set the tension to mid-range.
If this does not work, then tension control needs a new spring or the control needs to be replaced.
Apr 21, 2010 | Brother XL-2230 Mechanical Sewing Machine
Sewing machine XL 5500 settings
Your bobbin is probably too loose. When you set a new bobbin, stop every now and then and try with your fingers nail if it's nice and tight enough. Not extremely tight, but tight, not loose and moves easily when you set your finger between the threads.
With most fabrics (99%) the plate is fine at the the top position, just with very thick and "fragile" (satins etc) you might need to adjust it.
Settings: Tightest tension for the thinnest materials, more loose for the thicker ones, better have a test piece, it rarely goes under 5 anyway.
May 31, 2009 | Brother XL-5500 Mechanical Sewing Machine
Thread tension for Brother XL 2230.
If you have pattern dials set correctly then I might guess that one or more sets may have been missed when the thread was being set up in the machine. most of these models show either arrows or numbers for each or way the thread needs to be routed.
Apr 26, 2009 | Brother XL-2230 Mechanical Sewing Machine
Brother xl 3750 threating
take out the bobbin (thread holder) beneath the sewing area. Clean that cavity with a brush or cotton/soft cloth. Refill the bobbin with new thread and put it back in the cavity. I hope it will solve your problem.
Dec 27, 2008 | Sewing Machines
Brother XL-5340 sewing machine
Try a new needle, making sure it is put in properly. A bent needle can break thread. Make sure top tension is set properly.
Dec 01, 2007 | Brother XL-5340 Mechanical Sewing Machine
Open Questions:
See all Brother XL3750 Mechanical Sewing Machine Questions
Brother XL3750 Mechanical Sewing Machine Logo
139 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
