Question about Exercise & Fitness
My hyper extension trademill item number shows error 7 on the screen and does not work work what should I do
3 Suggested Answers
SOURCE: My Hyper Extension 1360 model is diplaying a error
hi im wanting to know if there is anywhere that i cld buy a orange switch its to turn the readmill on and off
Posted on Dec 04, 2010
AJIN G
  • 6694 Answers
SOURCE: trademill 93tclassic shows the error
hi,
You have to check the Driver circuit board for the motor. There is motor control IGBT Insulated Gate Bipolar Transistor) in this board .If the IGBT is short then the treadmill will not run or will run at high speed. . You have to check the OHMS between the seocnd and third of lead of the IGBT. If it shows less than 100 Ohms then the IGBT is short and you have to replace the same. Also you have to check the connection to the control pannel. Is there is any loose conatct. Remove the connection in the motor control board which go to the control pannel and reconnect it. Also check the speed sensor. In most of the treadmill you can find the speed sensor near the motor pully. Remove the speed sensor and clean it and the refix it. Remember one thing remove the power of the treadmill and leave it for 30 minutes then only oppen the treadmill. Because there is high voltage storage capacitors in the motor control board which will hold charge for some time even after the power is disconnected. i have added the picture of IGBT for your refference
Posted on Aug 16, 2011
Dynamix trademill kp329 console showed all digits then not responding and all display showed -- in all boxes. It was working fine previously and now not working Has anyone got manual or solution
Presumably you mean 'treadmill', not the dark s*tanic variety. This query might be better posted in a forum dealing with exercise machinery
Feb 28, 2017 | Cameras
How do I add a separate Samsung ssd 128gb drive with windows 7 on a Dell xps 8700 with windows 8.1 already on it? Is it possible?
On some computers, pressing a special key before boot up displays all the bootable devices. Using the arrow keys one can select which device to boot.
Sep 16, 2014 | Dell XPS 8700 Desktop PC - 4th Gen. Intel...
My hyper extension shows er 1
provide make and model number
Aug 26, 2014 | Refrigerators
Error code 3
1) lube the deck belt
2) lube the rollers bearing
3) measure the voltage input motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block diagram.
God bless you
Jun 29, 2012 | Exercise & Fitness
What would cause a projection screen tv (toshiba) to have to warm up when turned on? the picture flutters and is unviewable for 6 to 7 minutes
The Hyper module needs replacement. There were repair kits available for the hyper boards several years back the capacitors ( surface mount) need replacement
Jul 01, 2011 | Toshiba 57H81 57" Rear Projection...
My Hyper Extension 1360 model is diplaying a error 4 message
Nov 16, 2010 | Exercise & Fitness
I am building a webpage in Expression web if i publish and view in ie 7 or 8 all of my hyper links work, if i view in chrome they all work, if i view in firefox none of my hyperlinks work not even the hand...
hyper links are formed with a simple tag caled anchor. <a href="">text</a>.
firefox recognises onlty this format. but EW has other formats which is recognised by chromes as well. so chek ur source manually and verify that it is of that format.
Oct 23, 2009 | Microsoft Expression Web: Windows
Lens error code R740-033 on an HP R742 camera. Lenn will not close I have the same problem that my lens won't close and screen only shows Lens Error Code R740-033 It tells me to go to hp.com to get the...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 12, 2008 | Cameras
Exercise & Fitness Logo
259 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
