Question about Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
Bought a scratch & dent freezer. Door seal is not sealing properly, lets in air. How to fix? I don't see any dents near the seal, but lots of frsot and even drips are forming. I can plainly see when the door is closed that it doesn't have a good seal, but I can't tell why. This is a frost free model.
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 03, 2010
Condensation on top of freezer. It got something very heavy dropped on it. Dented the top corner. Door seal gasket IS sealing properly. is there a way to re-insulate just the door?
Hi - I understand that you recently had something heavy drop ontop of your freezer door. From my experience the condensation does typically indicate poor door seal. When cold air and warm air outside is entering into the freezer it causes condensation. Try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then I suggest contacting your manufacturer and see who they recommend to repair the unit. Hope this helps! JK
Oct 21, 2015 | Frigidaire 13 cu. ft. / 368 liter Chest...
We have a frigidaire upright (ffu17m7hwd) which formed a lot of ice and we are in the midst of defrosting and don't want to experience this again. Can you assist please? Had to throw food out due to...
Freezer burn to food is caused by air & moisture in contact with it.
There should be a tight seal by the rubber gasket along all the inside edges of the freezer door. This gasket prevents unwanted hot moisture and hot air from entering the freezer compartment and causing ice build up. You can test the integrity of the rubber gasket seal by seeing how the freezer door will pinch a slip of paper in various spots around the freezer door. If the slip of paper pulls out easily, there is not a good seal at that spot. If that's the case (which I believe it is), the door gasket needs to be replaced. By the way, ice will build up over time because you need to access the food in the freezer, hence you will introduce moist air each time you open the freezer door.
Aug 28, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have 20 cf Whirlpool model #evl202nxtn freezer,I can feel cold air from the top of the door seal.Anyway to stop this with out replacing the seal.The freezer 18 mth old.Thanks
oh wow . i have the same freezer with same exact problem. i bought it brand new. i can definately see the seal on top is not installed properly. i always thought it was only my freezer but i guess its a manufacturing issue.
Sep 24, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezer wont freeze beyond a chill. Please Help
Sorry to say that this happens a lot. More then likely there is a refrigerant leak and the place you bought it from had it charged right before you saw it. That is why it worked then, but not when you reached your destination.
Jul 09, 2010 | Freezers
Door not sealing properly. Visible gap in the upper left corner. Notice ice building up near gap. How do I fix it?
dear sir,
i think your freezer,s door there is one rubber between door and body it has been turn and damaged its need to replace. after change this rubber your who is sealing your freezer,s door your ice problem will be solve.
hope answer the question
thank you
please vote!
Jul 08, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer seal isn't gripping properly
in that case. you may have to consult your problem to the store where you bought that freezer. so they have to fix your problem
Jun 21, 2010 | Freezers
How to fix a dent in refrigerator? There is about a quarter size dent in refrigerator door in the outside. No pain is damaged? Is there is a way to **** it out flat again?
get a milk bottle,some cotton wool,some meths and some bluetac,put the bluetac around the neck of the bottle(to form a gastight seal to the door)drop meths soaked cotton wool into bottle alight,then offer bottle to door applying small amount of pressure to ensure seal when cotton goes out the vacuum should pull out the dent.slide a credit card down to brake seal.
this has worked loads of times for me.....
Mar 15, 2010 | Frigidaire Freezer Refrigeration White...
My upright freezer has condensation dripping down the door and also on back of it a bit
Hi, It sounds like the door gasket is not sealing properly. Look on all sides of the door and see if there are any openings between the seal and the cabinet.
Sometimes the door can get twisted and not seal proper. If there is an area not sealing, try readjusting the door for a better fit.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 03, 2009 | Freezers
Temp control flashing E 9
Look online and see if you can find an installer's manual. Sounds like the control board hasn't been set to your model yet.
Mar 07, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Not Freezing
Check the door seal all the way around. We purchased one recently that was slightly dented (not noticeably and the seal was not tight.) You need to get in touch with whomever you purchased it from immediately so that it can be repaired or replaced.
Aug 18, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
87 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
