Question about Linksys Wireless-G WRT54G Router
Im tryig to piggyback my wrt54g router to another part of the house. I have a cable coming from my linksys e1000 n router which is my main router. When i plug the cable into the 54g i can access the router page but not the internet. I have selected gateway for the 54g and turned off the dhcp server part but still no luck. Any help would be awesome.
  • mark948971 Sep 03, 2010
    Ok so my newbie question of the day is that do i have to use port 1 or can i use another port such as 2 or 3. And to make sure that its not the internet port. I know dumb question but my brian is fried from all of this been fighting with it for a day
    Ok so my newbie question because my brain is fried from this can i use other ports such 2 or 3. Also when you say port 1 you mean not the port that says internet but the physical 1 port. Dumb i know but gotta double check. Thank you again foe the help will check to see if that fixes it.
  • 550 Answers
What is the IP address of the E1000 router ?
If the IP address of E1000 router is 192.168.1.1, Then change the IP address of WRT54G router to 192.168.1.2. Connect the Ethernet cable from the Ethernet port of E1000 router to the Ethernet port of WRT54G router ( port 1 of E1000 to port 1 of WRT54g). Disable the DHCP server.
You can do it in a different way also.
If the IP address of E1000 is 192.168.1.1. then change the IP address of the WRT54g to 192.168.2.1. Do not disable the DHCP server of the WRT54G. Connect the E1000 to the Internet port of WRT54G.
Click Here to know more about router and network
Posted on Sep 03, 2010
Testimonial: "Omg that was so amazingly helpful it worked perfectly! Thank you again so much!"
When I try and install my E1000 linksys router it causes the phone line (dial tone) to disappear. Also it doesn't have PPPOA as a protocol option. Also the linksys setup software says that it is n
Don't you require an RJ-11 for a phone line, cause I don't see one on this model? In any case, the ATM protocol should be handled by the ISP modem, and the router should just pick up the established network over Ethernet.
Connect the ISP modem to main uplink port. Then connect pc to any other port. Done. Some models come with a setup disc, but not absolutely required.
http://homedownloads.cisco.com/downloads/userguide/E1000_V10_UG_USA_NC-WEB,0.pdf
Nov 22, 2012 | Cisco Linksys E1000 WirelessN Broadband...
I have an E1000 Linksys. It stopped working after the storm. I uninstalled the software, rebooted my computer and unplugged and waited for 2 minutes after nplugging the modem and router. No such luck. ...
Your Linksys most likely been zapped by the storm.
It pays to connect your computer equipment into a power surge protection power board to protect the equipment from storm and power surges.
Sep 01, 2011 | Linksys Wireless-G WRT54G Router
For beginners-how do i connect the linksys e1000 to my hughes net modem? or do I hook the cable directly to my tower so i can use my laptop in another room
The modem will plug into the router, it should come with a cable for this, there will be 5 ports on the router, one will be labeled as internet most likely , this is the one you use, the other 4 will be numbered and you can use any of these to connect your tower. the wireless should work automaticly for your laptop, but if you want to make it a secure network, please contact me directly and ill walk you through it.
hope this was helpful
Jun 26, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Manual for linksys e1000 how do I connect router to my compuyer?
You can either connect an Ethernet cable from the router to the built-in Ethernet jack that most machines have OR you can install a wireless (Wifi) adapter in your computer and follow the instructions to set up a wireless network...
May 11, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Intermittent/non-existant connection with LinkSys WRT54G router
I would get a Range Expander... it sounds like you are having problems recieving a constant signal. When you do get the range expander plug the Range Expander halfway between you upstairs computers and your downstairs where your router is at. I hope this helps!!
Sincerely,
cdixon18
The ManInsideTheMachine
May 19, 2009 | Linksys Wireless-G WRT54G Router
Linksys wireless wrt54g
check or replace ur cable first, reinstall software,
Aug 15, 2008 | Linksys Wireless-G WRT54G Router
Useing WRT54G WITH STARBAND
your starband is if im right the cable modem ? connect the modem to the router and then the router to the computer ? then run the linksys easy connect @ www.linksys.com/support
Jul 19, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
606 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
