Question about GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer
Ge spacemaker washer and dryer just stoped in a middle of wash and dry
I had washer agitate, but not drain or spin.  screws holding relay switch for lid closed sensor had come loose and was not registering that lid was closed.  pushed long stick (few inches) where lid sensor went, and it started draining.
Posted on Aug 17, 2008
    Scholar:
  • 150 Answers
Check power at the receptacle make sure you have 240v
Posted on May 11, 2008
Dryer not getting hot / washer won't run unless dryer on.
If these are separate units, you might have an electrical wiring problem in your house or apartment. If one unit (washer with dryer above), check to make sure the power cord is firmly attached to the terminals. Many other possible causes, too.
Apr 02, 2016 | GE Spacemaker GTUN275EMWW 27" Electric...
The dryer timer stopped working
Is that a temperature senor in the GE spacemaker Laundry dryer? My dryer stops spinning when it gets too hot. After it cools down, it will spin and dry again.
Jan 05, 2013 | GE WSM2700W Unitized Spacemaker Washer and...
Ge stackable wsm2700DAWWW makes noise and not drying properly.
GE HAS A REARBEARING THAT GOES OUT OVER TIME .. NORMAL WEAR AND TEAR FROM USE COULD ALSO BE YOUR HEATING PROBLEM IF THIS IS ELECTRICAL DRYER TUB COULD BE GROUNDING ELEMENT
Jan 24, 2011 | GE WSM2700W Unitized Spacemaker Washer and...
Ge stackable wsm2700dawww Dryer making noise,maby belt,and not drying very well.
USUALYY FRONT DRUM GLIDES AND REAR BEARING ASSYMBLEY PARTS ARE MADE OF TEFLON AND THEY WEAR OUT
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Lint basket keeps falling out during drying.
Bent the spring tabs to tighten the hold of the basket to back of the drum . If that doesn't work you will have to buy a new one. I found that a lot are damaged by heat.
Apr 27, 2009 | GE WSM2780DWW Unitized Spacemaker Washer...
GE Unitized Spacemaker Washer and Gas Dryer
It may be your pressure switch... it is what stop the water from over flowing the washer let me know if you want to change it yourself...I can help
Oct 24, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Washer wont start
your vent is prob. stoped up so the dryer got to hot a blew a thermal fuse..it is located at the top of the element housing
Apr 12, 2007 | GE WSM2700W Unitized Spacemaker Washer and...
GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer Logo
263 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
