Question about GE Profile Spectra JGBP90 Gas Kitchen Range
DOOR LOCKED FLASHING CONTROL PANEL WONT WORK - GE Profile Spectra JGBP90 Gas Kitchen Range
Was showing a FC Fault.
Mine did the same thing but would constantly lock and then unlock.
When it unlocked I turned off power. Opened door. Took two screws out at bottom of oven oven top and then removed two screws to the door latch. noticed one of the 2 switches did not make the clicking sound. bent over the switches far enough to remove with phillips screwdriver. Then disassembled the switch, the spring had came loose from its position. I repositioned spring, re-assembled everything and now its working great. hope this helps
Posted on Nov 07, 2011
  • 4,323 Answers
Hi
To unlock the oven turn off the oven and unplug it for 10-20 minutes. Let the oven cool and plug it back and check. If the oven door doesn't unlock then start the self clean cycle again and cancel the cycle after 15 minutes. Now let the oven cool down and try to unlock the door. If it still doesn't open then unplug the oven and you have to open the control panel and remove the door lock. Remove the three screws from the bottom of the control panel. You'll heed a 1/4" open wrench. Pull the bottom of the control panel toward yourself and push it up to release from the upper tabs. The door lock is secured by the three screws. Hope this helps...
Daniel
Posted on Sep 04, 2010
2 Suggested Answers
  • 132 Answers
SOURCE: My oven door is open but the panel is flashing "LOCKED"...
Pull the plug, wait 5 minutes and plug it back in. Don't touch anything! First check to make sure the door closes. If it does you are ready to set the self cleaning mode.
Posted on Mar 26, 2009
Central Locking not working remote makes indicators flash but doors wont lock or unlock. Also the switch in side on door panel
It looks like the system is working but the signal is not getting to the doors. If you know the supplier of the remote control contact them or the agent to check if the system has a relay which (my best bet is there is one) needs replacing, Otherwise trace your wiring backwards from the door actuators to the sender unit to see where your power is being broken.
May 11, 2015 | 2006 Suzuki Swift
Wont start machine error come up
Door open error code can also be displayed as "dOE" On non-display panel models this fault code is denoted by the light for the door lock being lit or flashing.
  • Check door is closed correctly and latched
  • Check door handle for damage or wear
  • Check door safety lock if inoperative replace door lock
  • Check door lock wiring
  • If there is a clicking sound once or twice when the Start/Pause button is pressed the main control board may be faulty
Apr 08, 2014 | LG WD-1280FHD Front Load Washer
Whirlpool awo 9663 wont start cycle
This can be due to failure of motor components or the control panel as there is no communication for the drive . Check the motor to panel wiring, check the panel for failed component
Jul 05, 2012 | Whirlpool Washing Machines
When I hold the button for it to start it clicks and starts flashing F then dL It will not start washing
The "f" part is saying that you have a fault, and the "dL" part indicates that your control panel thinks that there is an issue with your door lock. The brain will attempt to lock the door six times, then flash the error code. Press pause/cancel twice to clear the alarm. Then check your lock. Usually, it's something loose on the lock or catch; it can be the wiring to the lock being loose, or the control panel may have a fault. Start with the lock, and work back to the control panel.
Best regards, --W/D--
Aug 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I accidently put the lock on my oven.Now the lock will not come off. Please help
Hi
The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above.
To lock the control panel and both oven doors:
  1. Press and release Cancel.
  2. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” appears in the display and “Lock” flashes while the controls and oven doors lock. Both oven doors lock. “Lock” remains lit in the display.
To unlock the control panel and both oven doors:
Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
Please see this link for more information as how to disengage the lock on your Jenn Air Oven---
Door Lock On Oven
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Drivers door power lock wont work.
Either the wring going to that motor or the motor itself is bad.
Mar 08, 2009 | 2000 Toyota 4Runner
My oven is in lock mode after i had cleaned it. I can't open it now and the lock light is on.
Control panel and oven door lock
The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above. The current time of day will remain in the display when the controls and oven doors are locked.
  1. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
Dec 22, 2008 | Jenn-Air Electric Double Oven
Kenmore double oven flashing locked door, door not locked, oven wont respond
hey  i have the same problem, i moved into this house so i have no manuel. this is crazy, i hate this oven. i would personally never buy this oven. if you guys have figured out this problem i would really appreciate a response.  thanks Justine  Canada
Nov 22, 2007 | Ovens
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
399 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
