Question about Sport & Outdoor - Others
Wiring diagram for 2002 Polaris Sportsman 400 4x4 four-wheeler
I have a 2009 Polaris Sportsman 500EFI 4 wheeler. Recently, the number 1200 started flashing under the speedo. What does this indicate?
that sounds like your clock. engine codes don't go that high.and if it was your clock you must of lost 12 volt power at some point.
Jan 29, 2016 | Polaris 2009 Sportsman 500 EFI Touring
I have a code that makes no sense.Lo 010.8 Any idea what this means?
New 2012 850xp won't start - Polaris ATV Forum
www.polarisatvforums.com > ... > ATV Repair and Maintenance
Jul 29, 2012 - With only 6 miles and 2 hrs on my new 850 the battery was dead. ...Location: Mc Minnville TN ... 2012 Sportsman XP 850 H.O. .... code 10.8 on a 2012polaris 850 four atv ... Copyright ©2000 - 2015, vBulletin Solutions, Inc. Broke my first axle
Apr 20, 2015
Sportsman 570 with or witout EPF
Nov 10, 2013
BRAND NEW 850xp PROBLEMS!
Oct 16, 2010
More results from www.polarisatvforums.com
Thread: Lo 10.8 code - Polaris Ranger Club
Dec 25, 2015 | Polaris 2015 Sportsman 850 SP Base
2001 Sportsman 500. Where can I get a wiring diagram?
I'm attaching a picture that has 2 wiring diagrams side by side. The left side is the 2000 Polaris Sportsman 500 (Early) wiring diagram and the right side is the 2000 Polaris Sportsman 500 (Late). The Late wiring diagram for 2000 is more than likely either the same or extremely close to the 2001. And they may have just carried it over (the late wiring diagram). I've got a lot of hours on ATV's and Polaris especially - they stuck with what worked and didn't reinvent the wheel from one year to the next (usually). This may not be exact - but it should be extremely close. Hope this helps. Good Luck.
All The Best, Justin Lee
Nov 10, 2015 | Polaris ATV
2005 600 polaris sportsman clanking noise just off
Sounds like you have a bad knuckle or you have a secondary clutch issue. It could be a cv joint
Aug 17, 2013 | Polaris ATV
I need to adjust my carb on my four wheeler .. How to
you posted in the wrong forum, this is for the polaris kids toys
Mar 25, 2010 | Polaris 800 Twin Sportsman Ride on Toy
We have a New ATV 250cc that will not start..getting fuel,getting spark, engine just turns over!
  1. eHow
  2. Car Repair & Maintenance
  3. Car Oil Maintenance
  4. Drain Car Oil
  5. How to Repair a Polaris Four Wheeler
How to Repair a Polaris Four Wheeler By Brianna Byrne, eHow Contributor repair-polaris-four-wheeler-800x800.jpg Spark plug inspection and adjustment can be one way to repair a Polaris ATV.
Almost every vehicle needs regular servicing and repairs in order to continually perform at its best, and Polaris' lineup of four wheelers is no exception. The company has released dozens of ATV makes and models throughout the years, ranging from sporty racing quads to youth models to heavy-duty utility ATVs. Despite the differences between the company's many makes and models, general repair tips and troubleshooting instructions remain consistent for all Polaris four-wheelers. The electrical, ignition and fuel systems are some of the most common sources of Polaris ATV problems.
Read more: How to Repair a Polaris Four Wheeler ' eHow.com http://www.ehow.com/how_8074861_repair-polaris-four-wheeler.html#ixzz26pmQIzeh
Nov 21, 2009 | RTO 200cc Full Size Four Wheeler ATV
Electric Start Wont Work (Four Wheeler)
Solenoid Faulty or loose connections, short out the solenoid on its contacts and see if this throws on the starter motor, other than that it could be brushes inside the starter motor itself. Good Luck , the eti
May 20, 2009 | 1979 Yamaha RD 250
Sport & Outdoor - Others Logo
515 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
