Question about Dryers
I have an Amana "Commercial Quality Electric Dryer" and it runs, but won't heat. Can you help me to troubleshoot and repair? If a little history helps, I bought the dryer, used, two days ago. It ran one load of clothes fine and felt very hot. However, there has been no heat since. I have checked the breaker switches. I have also checked to make sure there are no ventilation issues. I'm ready to take the dryer apart and go to work. Please let me know what I should do / check. Thanks so very much for your help!
  • 1 more comment
  • brooke_franc Sep 03, 2010
    I mentioned in my original comment that I had already checked the ducting & ventilation. All ducting and ventilation is clear. Dryer won't heat. Please help. Amana commercial quality electric dryer. Tumbles but wont' heat.
    Where is the "moister sensor" and how would I test it? Isn't there also a fuse somewhere that could be blown?
    Sorry, but when I paid for this solution I was under the impression I would get a thorough, step by step solution.
    Can someone explain to me what I need to take apart and which parts I need to test, to see what is not functioning?
    There is absolutely no lint anywhere in the dryer or ducting. Does anyone have another solution and/or can you tell me how to locate and test the potentially bad part(s)?
  • Dryers Master
  • 43,501 Answers
Somewhere in that dryer, is a manual reset high limit switch. It would be in the wiring going to the heating element.... This rest is tripped and needs to be reset. However there probably is another problem also. The thermostat did not seem to cut out so therefore the high limit did. Replace the thermostat for the dryer also while you have it torn apart.
heatman101
Posted on Sep 03, 2010
  • 10,319 Answers
Clean the exhaust vents ductwork first or disconnect the venting and try the unit again o see if heat comes about. lint filled inside the vent exhaust tubing will cause the moister sensor to shut down the heat
  • frank thomas wilson
    frank thomas wilson Sep 03, 2010
    then the moister sensor is at fault
Gas dryer won't heat
Sounds like the solenoid is not opening and letting gas flow. There should be a small plastic plug on the front of the dryer near the bottom. Remove this and start the dryer, look in, if you do not see a flame, this could very well be the challenge. Applianceparts.com sells most parts needed for basic repairs. If you are not comfortable working on gas lines, have a repair person check this for you. Hope this helps.
Jun 02, 2012 | Amana Dryers
My Amana dryer won't start or power on pls help.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 15, 2011 | Amana NED7200TW Electric Dryer
Regardless of settings, my Amana Commercial Dryer does not stay hot all the time whilst drying. Sometimes when I open the door, the air clothes are cool to the touch. Then some time later they are hot...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 26, 2010 | Amana Dryers
Dryer tub doesn't spin - motor runs and hot air comes into the tub area but the tub itself has quit spinning. Could this be the belt since the motor is running and the dryer is heating up? This is an...
Unfortunately you will have to search for thebelt with auto stores to see if any of the models will match. Check to see if any machine spares shops can help, get intouch with industriaal spares outlets to help you.
Sep 23, 2010 | Amana DLE330RAW Electric Dryer
Drayer runs but does not heat up what's up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 10, 2010 | Amana NED7200TW Electric Dryer
My Amana heavy duty dryer will not get hot
heatman101
Jul 05, 2010 | Amana NDE6800AYW Electric Dryer
My dryer is not blowing hot air? I have a whirlpool, commercial quality, super capacity plus, 8 cycles & 4 temperatures. help.
heatman101
Jun 10, 2010 | Dryers
Dryers Logo
71 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
