Question about Linksys Wireless-G WRT54G Router
Power light on linksys wrt54g is yellow and there is no wireless signal. i reset linksystem and tiny led lights are green,But power light is still yellow.
  • Linksys Master
  • 7,733 Answers
WHAT LIGHTS ON LINKSYS ARE SUPPOSED TO BE BLINKING
Note that incoming traffic will cause the WAN (or Internet) light to blink even if it is 'probe' traffic trying to break in to your network. Such traffic is to be expected and is the reason you have firewall functionality in your gateway router.
On the inside, there is a bit of traffic on any LAN when the computers are turned on. Messages generated by the router itself are used to find computers and printers for a lot of different legitimate reasons.
Feb 25, 2013 | Linksys Wireless-G WRT54G Router
The power led light is continuously red. But the other two lights ( Act, Link) are green. How do i get the power led light to be green?
Try Resetting it..... Or turning it off for awhile then turning it back on.... Unplug all devices connected to it..... Hope this works :)
Jan 06, 2011 | Linksys Wireless-G WAP54G 802.11g/b...
I have the WRT54G wireless-g router and I tried to switch it on (after I had switched it off because I was overseas). However instead of the yellow light to come on (over cisco systems logo), a white color...
Does the Cisco logo illuminate yellow? Is the power LED white?
In any case locate the reset button on the back. It is just to the left of the
Ethernet cable jack. With the power on, depress this button for 2-3 seconds and release.
All the lights should come on the go through a series of self tests. Once settled down after about
2 mins see if the lights change. If nothing changes, it sounds like it was dropped causing the
colored plastic tabs to jar loose.
Hope this helps.
Nov 29, 2010 | Linksys Wireless-G WRT54G Router
I was reseting my linksys routers, and now my power led light is not lighting up. Does this mean my routers are blown. I did this to 2 routers the same day. Any way of solving this problem
How did you reset them?
Can you try it by holding down the reset button for 1 min, while you are holding it down unplug and replug the power adapter.
If still power LED not lit, try another power outlet. If the routers and identical, swap the power adapter. IF same, call 1800Linksys for replacement
Nov 28, 2010 | Linksys Wireless-G WRT54G Router
Have Linksys WRT54G2. All port led's are lit and
How is your router connected? If you have all port lights lit, either green or orange, and nothing connects seeing the Internet, are your problems with wireless access? Is the Wireless set correctly, by going to http://192.168.1.1 and logging in to the router? Make sure the SSID (network name) and other security measures are set correctly ... I prefer WPA-PSK[TKIP] for its simplicity. You will need the passcode you choose to log in with wireless devices.
Nov 11, 2009 | Linksys Wireless-G WRT54G Router
My wlan light keep going on and off on my wrt54g
Also check if the power light on your router is blinking. If it is blinking, that's an indication of hardware failure. To revive it, do a hard reset. Press and hold the power button of the router for 30 seconds then unplug the power. Wait for 30 seconds again before you plug it back in.
Oct 27, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRT54G wireless router not compatible with Aztech modem?
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address - 192.168.2.1
DCHP - ON, Addresses - 192.168.2.100 and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router - 192.168.2.1, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
ALTERNATIVE,
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM junodr@yahoo.com or through this website.
once
Jan 04, 2009 | Linksys Wireless-G WRT54G Router
No conenction
What is the name of the lights that is yellow? Most of the time the lights on the router is yellow or green.
Aug 17, 2008 | Linksys Wireless-G WRT54G Router
Wireless connection to lap top
try opening network connections disable the default connection and enable linksystems
Jul 13, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
656 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
