Question about GE 36 in. JGP628 Gas Cooktop
The igniter doesn't work at all. If I turn any knob to the ignite setting, you can hear the gas coming out but there is no ticking sound, and therefore no ignition. Can I fix this myself?
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Posted on Sep 03, 2010
Middle section ticking sound with sparking as if trying to ignite even though knobs aa
see this steps and fix it. God bless yo
Relight an oven pilot:
  1. Turn all controls off, open the doors, and allow gas to dissipate.
  2. Hold a lighted match near the tip of the pilot on the burner assembly. If a burner does not light within two minutes, adjust the pilot, step 3.
  3. Turn the pilot adjustment screw (located near the pilot or the thermostat) in small increments and retest until the pilot has a blue flame.
  4. Check and replace an oven spark igniter:
  5. Turn all of the appliance controls off.
  6. Open the door and remove the oven bottom and the baffle (see above).
  7. Unscrew the igniter from its mounting bracket and inspect it for cracks or other defects. Replace it if it is damaged.
  8. To replace a faulty igniter, find the ignition control module, unscrew the cover, and disconnect the module. Install the replacement part and test.
Oct 02, 2012 | Fisher and Paykel GC36 Gas Cooktop
Try using a pair of pliers and pushing down as you turn first counter clockwise as if you are turning the gas on then back clockwise till it won't turn anymore. If it's still trying to ignite see if its the oven or make sure that its the burner that's trying to ignite . I''m not a appliance person just a home maker so if it were me and none of those things work turn off the gas to the stove unplug the power to the stove and call the gas company or appliance center. One thing though some of those type of knobs are two parts like they have to be pressed down to turn on the gas. Or the have to be set in a certain position to engage the ignite switch. If you know a little about wiring look at the switch and check the wires. But make sure before you do anything that there is no gas on.!!!
On our 6 burner gas coocktop, the right two burners don't light
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 10, 2010 | Thermador SGS36GS Gas Cooktop
Gas comes on but no fire comes out when knob turns on. must light manually
ur igniter is not working either the igniter wire or the transformer...igniter wire is in the buner base color white ceramic that the igniter wire..if is broken pelace it..check all the igniter wire...if no sound it is igniter transformer...its expensive to replase the igniter transformer.
Jan 13, 2010 | Cooktops
We have a belling gas hob. Intially when we turn on the control knob it gave a ticking sound even after it got ignited. then when we were turning on one burner it gave ticking sound in all burners . but...
take out the control knobs. clean the grease and food partilcles if any using hot water and dish washing liquid .if the washer under the knob is stuck, put it properly and put the control knobs back into it carefully
Jan 11, 2010 | Stainless Cooktops
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
I have a JGP636 or 960. One burner won't do
When you turn the burner knob on does the igniter click and turn off on it's own when the flame ignites? If it does then it has flame rectification. That means it can sense when the flame is on. Or does it click when the knob is in the light position and not stop until you move the burner knob? Then this is standard ignition. If it is standard ignition it sounds like it is the igniter switch built into the burner knob might be defective. Are you able to turn on any burner knob and when they are in the igniter position do all the electrodes spark or just the burner that you are turning on? If they all come on then they are wired in a series. If they are wired in a series do you get a spark at the electrode of the problem igniter? If so you can turn on one of the other burners to ignition position then while it is clicking turn on the problem burner to light it. If the cooktop uses flame rectification then there may be a problem with the switch built into the burner knob or the flame rectification sensor for that burner might be bad.
Sep 29, 2009 | GE Profile JGP636 Gas Cooktop
Ticking sound of gas igniter continues after off.
try to clean the place wen u remove the control knob,by using a vacium.
Nov 19, 2008 | Cooktops
Ticking sound does not go off even after knob is turned to high or medium
A lot of questions on this site but very few answers. I have the same problem. After an overflow from a pot, the 2 front burners now won't light one rear one lights but won't stop sparking and the littlest one is fine.
Mar 30, 2008 | GE 30 in. Profile JGP933SEFSS Gas Cooktop
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
GE 36 in. JGP628 Gas Cooktop Logo
392 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
