Question about Sony KDF-E55A20 55 in. LCD Television
How do I connect cable to a vega television that I bought in Iraq
How can I hook up my cerwin Vega ht 10d subwoofer to my computer surround system
You'll need some adapter cables. I would probably try a Y cable in each front speaker line, then connect the pair from the left channel to the "L" binding posts on the back of the Sub. Same for the right.
Not sure of the configuration of your existing surround system. Essentially, you want to "Y" the left and right channels wherever you can get a hold of them and connect each to the back of the sub.
Apr 23, 2017 | Cerwin Vega Audio Players & Recorders
FLAT BATTERY - WHAT SHOULD I SET MY NEW CHARGER ON TO CHARGE A FLAT BATTERY ON A VICTORY JACKPOT VEGAS 2010
2 amps. If the battery is completely dead, and will not charge, try connecting it to a known good battery with jumper cables and then connect the charger.
Apr 11, 2013 | 2008 Victory Vegas Jackpot
Iq massager professional battery replacement
then your charger or cable or connections are bad,the internal battery isnt replaceable, https://tensunitmassagers.com/catalogsearch/result/?q=lithium+battery
Jan 24, 2013 | Health & Beauty
How to replace clutch cable for 2008 vegas 8 ball
I have a 2008 Vegas 8 ball that the clutch cable broke it seems simple to replace but the shop keeps sending me the wrong cable can anyone tell me what cable I need
Jul 15, 2012 | 2008 Victory Vegas 8-Ball
Connected the Wii to new Panasonic 42 in plasma. Had been working fine on Sony Vega 27 in. Now picture quality is terrible and there is no sound. Checked all TV and Wii settings and unable to fix it.
That's probably down to the AV cable. Have you tried it on another TV to eliminate the TV?How are you connecting? Component or Scart adapter? Tried swapping from one to the other to eliminate any possible issues?
Nov 23, 2008 | Televison & Video
Sony-Vega-TV-a'whole lot of snow , no sound can BARELY see the :NO SIGNAL in the bottom left corner . Been through the troubleshooting guide
Check teh cable connections for a bad ground. It is also possible that the tuner has failed. Can you please post the model number from the back of the set? That will help me to provide you with specific options.
Thanks,
Dan
Apr 16, 2008 | Televison & Video
Plasma P50H401 tv will not display picture
I know this might sound stupid but try changing the channel or changing the aux / cable / tv button... I  had to put my phillips 50" in the shop for the same problem ..but I had it for 3 yrs .they said it was the power supply and will cost 1k to get the power back and may cost evne more if one of the boards went out (video i guess?) so make sure u get the extended warentee u will need it .Its only a matter of time ... good luck quickdrj
Oct 12, 2007 | Hitachi P50H401 50 in. Plasma HDTV
Sony KDF-E55A20 55 in. LCD Television Logo
21 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
