Question about Bissell THE BISSELL LITTLE GREEN MACHINE Vacuum
No water comes out - Bissell THE BISSELL LITTLE GREEN MACHINE Vacuum
    Sniper:
  • 67 Answers
Im sorry to say, it sounds broken. you may wanna try hot water it may be clogged ( be careful) if that doesnt work out.... i know of this great site that sells bissell's for like half of retail check it out.....maybe your best solution....http://stores.ilikenew.com
Posted on Nov 17, 2010
    Problem Solver:
  • 5 Answers
Probably the pump go to VacPartsWarehouse.com order part#6035029 take it apart and replace with new one should solve the problem
Posted on Oct 11, 2010
Steam wont come out although filled with water and heated as required
If you are using tap water the holes where the water comes out are plugged. You will have to take it apart to clean. After that you should use distilled water you can purchase at your local grocery store. That is what my wife uses after I insisted.
Dec 01, 2013 | Vacuums
We have the water hooked up at the back of machine. there is a spout for the water to come in and fill the ice tray.but is does not. If we turn the water on it fills up the space under the ice basket. I...
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
With the fill tube blocked with ice the water can drip down the back wall or drip into the ice bin or just stop up. You can use a hairdryer to thaw the tube out.
Feb 18, 2011 | Vacuums
Cant squirt water, nothing is coming up from the carpet
Try filling soap solution tank with hot water and make sure that the red filter in the pickup tank is not clogged, and always run hot water in solution tank after cleaning carpet. steve
Jun 06, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Water doesn't come out of my Bissel Deep Cleaner
Did you use TAP water...not a good idea.Use de-mineralized water you can get at most pharmacies,there is probably mineral buildup in the lines.
Mar 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
No water/cleaning solution comes out on wash cycle
With this model, the soap dispensed is controlled by electric solenoids. these can be tricky to troubleshoot. I would take it to your nearest dealer. these solenoids fail, and cause a variety of symptoms.
Oct 08, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Water and cleaning fluid not coming out
water head pluged use tooth brush and hot hot water ,on bottem of vacc find water heads brush until clean
May 06, 2009 | Bissell Powersteamer 1694 Upright Vacuum
Hoover Steamvac F6025-900 leaks clean water when running
First item to check is the valve on the machine where the upper ank sits. If you install the tank and then remove it, you will have a small ammount of water in the black gasket area. this means that this is ok. if not and there is no water you will need to replace it. also ( a way to also verfiy this is to remove the brushes and put a dry towel under the fron and install the tank. if water comes out the diffuser then the resevoir is faulty. if it comes out from the right side then the pump is your problem.
Jan 21, 2009 | Hoover F6025-900 SteamVac Wet/Dry Vacuum
Bissell 1698 PowerSteamer ProHeat Upright will not work. The brushes spin, the soap comes out, but no water is getting to the carpet.
You may try the trigger assembly may not be releasing the water , your brushes spin and the soap comes out but no water – it may have come unhooked or broken, also the water line could be plugged, clogged or pinched and not releasing water to the brushes -- you may try the owners manual for the trouble shooting for the item or check the Bissell website listed below or the customer service phone number of 1-800-237-7691 – the website has a list of trouble shooting listed right on the website I you enter the Model number and hit trouble shooting
http://www.bissell.com/
By Phone Customer Service:
(800) 237-7691
Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Apr 15, 2008 | Vacuums
DIRTY WATER
remove the dirty water tank and see if the front nozzle is fitted correctly, also see if the filter is clean on the dirty water tank
Nov 19, 2007 | Bissell 1770 Quicksteamer II Upright...
Bissell THE BISSELL LITTLE GREEN MACHINE Vacuum Logo
93 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
