Question about MyMusix PD-6030 MP3 Player
Cant figure this out
I/O device error
cant open the disc can do anything
anybod have an ideas
or do i need the disc if it needs one
  • 8,596 Answers
Make sure the hold switch is not engaged. If not:
If you have a Windows-based computer,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If that fails,
Check the battery polarity. (+ and - must be in correct psoition)
Set the hold button to the unlock position.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format
If that fails,
go to www.mymusix.com to see if the latest software update will correct the problem
-Tha Mp3 Doctor
Posted on May 24, 2008
Samsung dishwasher dmr57lfs goes quite a long way through the cycle, then throws up error code HE. If I switch off and restart, it goes into "rinse" and then "end" skipping the "dry" cycle can anybod
HE means that there is a problem with the heater. Check the heater for continuity. If it is open, replace it. If it's not open, then, I seem to recall that there is a thermistor or something in there. Check the thermistor for proper resistance (sorry, I can't remember what the reading should be at room temp. But, it most of them are around 5K or 10K ohms at room temp.). If they are both okay, then your control board is most likely malfunctioning and you'll need to replace it.
Good luck.
Oct 22, 2014 | Dishwashers
Tascam md-350 "cannot copy" error
Like all home recorders, yours will not let you digitally record digital originals. The Serial Copy Management System (SCMS) is designed to prevent piracy.
Unfortunately it also means you cannot copy your own digital originals digitally.
Record them via the analog input. It will sound fine.
Nov 06, 2012 | Tascam MD-350 Advanced MiniDisc Recorder
I cant figure out what chords i need
Take the monitor to any computer-store.
They can inspect the connectors, and sell you the correct cords (not "chords").
Mar 03, 2010 | Star Logic 17" LCD Monitor
I cant open the music player
You need to update your device's software , so that all errors can be automatically fixed . Updates of your device cam be found on the manufacturer website . Just get to www.samsung.com and i'm sure that you'll find what you are looking for .
good luck .
Jan 23, 2010 | Samsung S7350 Ultra SLIDE Cell Phone
Tray wont open and tuner seems not to work
Disc tray belt that opens door has too much slack and need to be replaced,$2 item,belt size 1.9.To get tray open use your knuckles and tap on TOP of cabinet just above disc door while pushing open button.When open you will see the tiny belt that operates door to the right,use twizzers to remove an replace.Make sure new belt is seated properly in tracks if not tray won't move.
Jul 30, 2009 | iLO DVDR04
LG DVD player Disc Error message even when playing lens cleaners!
LG DVD Player Disc Tray opens & closes automatically & unnecesarrily
Apr 29, 2009 | LG LXD5230 System
Cd changer is jammed in denon dcm 360 5 cd changer
Simply remove the outer casing and remove the jammed disc
Nov 28, 2008 | Denon DCM-360 5-Disc CD Changer
Won't read dvd's or anything, just says mechanics error
no try to open the cover and inspect anything stuck in loading mechanisum.check the all reed swiches and clean all if they are dusty.
shall we try to repair it.
nuwan..
Nov 17, 2008 | Sony DAV-C770 System
Disc read error
You will ne4ed to clean up the PS2. open it up and clean the laser lens with alcohol on a cotton swab. If it is the Slim Ps2 model you should not use Alcohol. Use A glass Cleaner like windex on the slim. Sometimes the magnet gets week and you need to add some magnetism to help improve the spindle grip on the Game disc. Cut up a refridgerator magnet and place it in the white cap thatt clamps the Game disc in the cd player.
Jan 06, 2008 | Sony PlayStation 2 (PS2) Console
Error message
I had this happen to me as ell. you've probably got a cd stuck under the revolving tray. I took the top cover off and then opened the drawer and removed the offending disk. If you're not technically minded it's probably better to take it in to a repair shop. Mike
Dec 24, 2007 | Marantz CC-4300 5-Disc CD Changer
MyMusix PD-6030 MP3 Player Logo
29 people viewed this question
Top MyMusix Audio Players & Recorders Experts
Greg Cann
Greg Cann
michael galang
Sandeep Shenoy
Are you a MyMusix Audio Player and Recorder Expert? Answer questions, earn points and help others
