Question about Microsoft Xbox 360 Console
Over heating i have two fans on it in a open space and it still over heats in 2 to 3 minits
  • antbanks Jul 02, 2008
    I have the same problem but I have a intercooler
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 58 Answers
Do you get any red lights?
If you don't get any red light I suggest on using a cooler.
If you do and you are under warranty sending back to Microsoft will be your best choice.
Posted on May 12, 2008
Does the fan operation bring in outside air or just circulate air inside the space?
The fan is the same one use to circulate air thru the heat or A/C coil. When set to auto, the fan only comes on when the thermostat senses that it needs to add heat or cooling to the space. When set to on, the fan runs regardless of whether or not it is adding heat or cooling on not.
Mar 13, 2015 | Heating & Cooling
Space heater stops working after 2-3 minutes
The problem is most likely the over heating sensor thermostat located directly under the heating elements - The reason the over-heat safety thermostat sensor is tripping the warning buzzer is because either the cool air fan intake is obstructed with dust / dirt, or the fan motor stopped rotating, or the over-heating condition thermostat is defective, or over sensitive - Usually when the cool air intake is obstructed for any reason, the heating elements will glow brighter, and hotter without good air flow, and the elements may start to bow downwards closer to the over-heating safety thermostat - However, if the safety thermostat is defective, it can trigger the warning buzzer even though there may not be an over-heating condition / event present - The buzzer warning going off prematurely also occurred with my Holmes space heater - I checked the air flow first, and then the appliance tip-over switch second - Both were found functioning properly - It wasn't until I replaced the safety over-heating thermostat, did the buzzer stop going off moments after I plugged the space heater in an outlet.
Jan 05, 2014 | Holmes Products HRH316 Mid-Size Heater
My heater isn't sending any heat .It seems like the fan isn't comming on
Most units heat comes on first. Does it get hot at all? may have over temp switch open and needs reset, after that check for fan operation. If fan does not come on it may lock out again. That would confirm bad blower motor.
Not sure if this unit needs this blower? Some space heaters it is an option.
Sep 07, 2011 | Dimplex Compact Electric Flame Stove...
Hi, my pc just shuts down after 10 to 15 minites as if there was a power cut then i put it back on it will not last 5 minites but if i leave for a few hours it will last for 10 to 15 minites again. can you...
From the information desribed it appears that your PC is over heating. You may need to clean all the vents especially the fan vents with an air duster (can of compressed air).
It is possible that your fan(s) has failed or is running slow - they might need replacing.
Also make sure you operate your laptop on a solid surface so that air can freely circulate under and around it.. I hope this has helped
Jul 30, 2011 | Computers & Internet
I have been problem wid my nokia5800xm,when im downloading nd surfing up to 5 minit above,then handset is beganing heating start.then after few minits,its getting very heat up..only heating prob in while...
Possible that the phone has been installed with some software that activates when you are ONLINE and so the processor heats up. It can be also due to problems in the software and hence it is best to take an advice from the nearest NOKIA CARE center or check the link below and call for support:
http://www.nokia.co.in/support
Jul 19, 2011 | Nokia 5800 XpressMusic Smartphone
Never overheated (and still not certain I did) BUT Sat nite(Feb 6 2010) after a run about 20 miles the 2001 venture started to loose ground like it was runnning outta gas. HAd plenty. It was -10 C outside,...
One of your intake manifold gaskets went bad and it is sucking in air where it should'nt be. This problem is very common on this motor. I'm 100% sure that is what it is. But no ofense if you can't figure out how to get your radiator cap off , then this job is probably a little much for you.
Feb 08, 2010 | 2001 Chevrolet Venture
2 red flashing lights
The Xbox console is overheated.
  1. Let your Xbox 360 console cool. You may have to wait several hours for your console to cool enough. Don't turn on your Xbox 360 console when the console is hot.
  2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating.
  3. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support.
To try to prevent this problem, follow these precautions:
  • Don't block any ventilation openings on your Xbox 360 console.
  • Don't put your Xbox 360 console on a bed, on a sofa, on a carpet floor, or on any other soft surface that may block ventilation openings.
  • Don't put your Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Don't put your Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
Taken from Microsoft support.
Best of Luck.
-Mind
Jun 30, 2009 | Microsoft Xbox 360 Console
Line o/p J6810 Over heated and Fail in few minits
if u get thermal heat or over hetat message from your computer. ......1/ your cpu fan is not fitting well and fan is damage. for solution tied it or change thanks
Jun 10, 2009 | Computers & Internet
Over heating
Ventilation is better if it is sittion horizontally, as opposed to vertically. Also, keep it off carpet and give it plenty of room to breathe. Make sure the vent is clean and clean the area regularly to keep dust away. Also, make sure the fans are working. You can also buy the cooler that sets under it to help keep it cool, though a regular fan usually works and is much cheaper.
May 11, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
18 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
