Question about Vizio L32 32 in. LCD HDTV
Channel scanning I can't stop my L32 to stop scanning channels. I have no dvr connected, but I do have cable. The picture is fine, but the tv just scans channels from 1 to 122. Please help. I also am unable to change the input from cable to tv. Julie
    New Friend:
  • 129 Answers
SEEMS LIKE CONTROL PANEL SWITCH, ONE OF THEM IS STUCK OR DEFECTIVE, CONTROL PANEL NEEDS TO BE TESTED
Posted on May 16, 2008
Stuck on one channel
Is it the tv's remote? Change the batteries
are you on a cable box? You need to use the providers channel changer. Tv is made to stay on one channel like channel 3 and the cable box runs the different channels.
Dec 01, 2015 | Vizio L32 32 in. LCD HDTV
Digital tv tuner not displaying picture
. Try putting you tv set to channel 3 or 4. Try your tv in all modes. Check the back also to see if in the right spots with the wires. Check your channel scan status, try it on anntena and try it on cable, run channel scan on both. good luck. Try vcr wires if cable wires dont work. vcr wires are yellow red and white. Try another cable cord sometimes they get old. Try looking at your remote and setting it to tv.
Sep 02, 2012 | Panasonic PT-50LCX63 50" Rear Projection...
Connected lg tv directly to cable wall jack. Can only get one channel. Manual scan grayed out. Ez scan does not find any channels. Main input is set to cable box. No option for just cable
Why not get a box and hook via rear inputs--not that expensive from most cable companies. If items such as the channel scan are grayed out it means something in the set is set wrong---
Apr 21, 2012 | Televison & Video
I can not get channels on my vizio hdtv. i have a cable cored hooked up to the tv and i can not get the channels to come on the tv screen. it keeps saying "No Signal!"
You will need to make sure that your cable is connected to the correct input (if more than one) and then enter the Menu and look for a "set up" screen and select "Scan for Digital Channels".
After the scan the TV should be fine.
Jun 14, 2010 | Vizio L32 32 in. LCD HDTV
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
I have it hooked up to the cable dvr with a hdmi
You don't need to scan for channels if it is connected by a HDMI connector, just select HDMI 1 or 2 depending which one you have connected the cable to at the rear of the TV. You should now receive the already set channels from your cable box.
Sep 24, 2009 | LG Televison & Video
I can only get 2 channels on my TV hooked to Cable
Please do the Auto Channel Program once again and let me know.
Aug 28, 2009 | Westinghouse SK-42H240S Television
Have a vizio lcd tv . can not get any channels today with the switch over to digital. i use an antenna
Your TV probably does not have a digital tuner connected to the DTV/ANT input. Mine didn't. I had to connect the digital antenna to a digital converter box THEN go to the DTV/ANT input. Only then would it activate the DTV menu and allow me to scan for channels. If your TV worked fine with Cable TV connected to the input, it was because your signal was coming from the digital tuner in your DVR, or your cable provider was sending you an unscrambled digital signal (not likely).
I used a digital converter box I had purchased with the government $40 coupon back in 2009 but the resolution is only 480 and looks like a Monet or Renoir. Now I am shopping for a high quality tuner.
Jun 13, 2009 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
240 people viewed this question
Top Vizio Televison & Video Experts
Dave Naylor
Dave Naylor
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
