The glow igniter should light up and after a delay the sensor will click and turn on the gas valve. If the gas doesn't flow and light the cycle will repeat.
Most likely you need a gas valve coil kit. The coils get weak and wont open the gas valve.
You may have to get a new heating element when they go out the jet dryer where the heat comes out will not work normally this is caused buy a bad heat element. If not take back panel off and check the little white fuse and replace it, Almost all dryers are the same in that area.. Hope that helps....
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis electric no heat tip...
Some dryers have a small inspection hole covered by a small platic cap.
Remove cap and look inside unit for pilot. Newer dryers have an igniter that glows when the dryer is turned on. It ignites the gas then goes out.
it mean it dont have a gas pilot and it has a ignitor instead ,,,, if you turn on the dryer and dont see a glow then it may have a bad ignitor ,,, on a kenmore it should not have a door to open unless it is a old unit and the newer ones has a peep hole to see into.
