Question about GE JVM1640 Microwave Oven
The microwave has been working fine, but we just tried to heat something and although the oven sounded like it was on and the turntable was spinning it did not heat the food - just some soft tacos. The power is at ten and we tried several times using a one minute setting. Thanks much, Chuck
  • GE Master
  • 12,061 Answers
Hi, this is a classic MW Magnetron, problem, usually when this happens, it is the magnetron, and or the High Power Diode that has failed.
Realistically, there are NO user serviceable parts in a MW, and they are VERY dangerous to self service.
I suggest that any monies you would have spent on repairing this unit would be better spent towards a NEW MW. with a warranty.
Below is your user manual.
http://www.retrevo.com/support/GE-JVM1631-Microwaves-manual/id/6329bh327/t/2/
Posted on Sep 03, 2010
My GE over the oven microwave does not heat (1.5 years old). The heating and turntable stopped working at the same time. When you start it, it sounds fine, but nothing heats. You can hear a relay or...
It does sound like a relay malfunction or similar switch. Could be repaired but call for a quote or better yet, take it to a repair depot (probably cheaper).
Dec 13, 2014 | GE Microwave Ovens
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
The microwave runs like normal but doesn't actually heat anything. I went to heat something and it came out cold. Timer set just fine, it ran and sounded like it always does, turntable turned, it dinged at...
The most likely problem is the magnetron that heats the food, the other less likely is the high voltage transformer that energizes the magnetron. To replace either part with labor would be as much if not more than a brand new microwave oven.
Jan 19, 2011 | KitchenAid KHMS145KSS Microwave Oven
Light and turntable work, but it won't heat
There is a fuse in this microwave.The fuse is difficult to get to.
But i do not think it is this fuse.You have lights and the carousel
spins.This sounds like the thermostat or the magnetron tube that
creates the heat.
Feb 02, 2010 | Maytag MMV5156A 1000 Watts Microwave Oven
Microwave not heating
OK, you have two components that are faulty. the magnetron and the turntable motor as well. replacing these two components will fix both issues.
Jun 10, 2009 | Frigidaire FMV157GM Microwave Oven
Whirlpool MH1140XM: has power, but no heat, turntable not spin.
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
May 11, 2009 | Whirlpool MH1140XM Microwave Oven
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable does not work
If the rest of the oven works fine, then this indicates that you might have a problem with the motor that turns the turntable.
If you try to turn the turntable manually (gently), does it turn freely or is there resistance? If it turns freely, the mechanical mechanism between the turntable and motor may be broken and the motor may be ok.
The oven's microprocessor also controlls the motor. There could be a problem there.
You'll need to have it looked at by a service center. Although its not that difficult to determine which of the reasons I mentioned above is the cause, it can be however, dangerous to operate a microwave oven with the cover off and with high voltage circuits exposed.
Please let me know if I can be of further assistance to you.
- Jim
Mar 08, 2008 | Goldstar MV-1526 Microwave Oven
GE JVM1640 Microwave Oven Logo
47 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
