Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
What is the part that keeps the door from falling open fast when unlatched
  • 122 Answers
Your door spring is probably broken
Posted on Sep 03, 2010
2 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: door tension gone
Rico,
Mybad... Before I knew the model number I assumed door springs. Now that I know what we're working on (a KitchenAide), I know that it's NOT the springs but the linkage! Cool!
The repair is a little intense, OK? Not so much that you can't handle it, but enough so that it's kind of a pain. You'll first need to pick up (or order) the parts. The part number is 8194001 and lists for about $20 USD. (plug the part number into a search engine) When you have the parts, you're ready to tackle the beast.
Ready?
You'll need to KILL THE POWER TO THE DISHWASHER BEFORE DOING ANYTHING MORE! DO IT AT THE BREAKER IF YOU HAVE TO, OK?
OK. The DW is gonna have to slide out from the cabinet. I generally don't have to pull them out more than like a foot or so. Open the door and remove the 2 screws mounting it to the bottom of the counter top. Then you'll need to remove the "kick panels" near the floor (there are four 1/4" screws holding them in place).
Here's the tricky part... look closely at the water valve (it's mounted just behind the front left leg), what type of water line do you have going into the valve? Is it copper or is it flexible stainless steel braided hose? If it's the flexible stuff, you should be OK. If it's copper then you have to do the following;
Reach under the sink and shut off the hot water valve (the one on the left), then remove the copper line from the DW valve (this is tough to do, btw. Crowfoot wrenches are a life-saver here.) See? The flex hose will come out with the DW and the copper one won't... that's why you have to remove it.
OK... now you gotta start sliding the DW outta the hole. Do this slowly... by inches, don't just **** it outta there 'cause things can get snagged (drain hose, electrical, inlet hose, etc...) so take it easy and watch what you're doing.
After you have it out about a foot, use a flashlight and locate the springs (I BET you that one of the springs and rope are still good... look at that one and see where and how it attaches). Click this link to see a full sized diagram of your DW. Your part is number 24 and the spring is number 18. The spring connects all the way in the back by the rear leg support on the frame.
All ya gotta do now is install the new parts (do both even if one is still intact) and rebuild the unit! I know it sounds all complicated and stuff, but it's really not. It'll probably take you about an hour to get it completed.
There ya go! After you follow these instructions and your DW is happy again, would you please rate this solution as "FixYa"? My "Guru" status is counting on you. :-)
Also... if you have any further questions regarding this repair, don't hesitate to write back. I'll get your post in my email. OK?
SG
Posted on May 02, 2009
My driver side door handle is broke on the outside and inside, I cannot get the door open to remove the panel.
You may be able to remove the front fender and drive the pins out of the door hinge.
Jan 01, 2014 | 2001 Chevrolet Tracker
Falls open when? This unit wom't operate unless the door is secure so I assume you mean the door assist springs are disconnected or broken and the door just falls heavily to the open position after you unlatch it from the closed position. Try these, part 18 here
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDI01FLSS3/0593/0130000/W0503111/00007
should attach to frame in an easy to distinguish hole or slot and to door hinges, number 2 here
http://c.searspartsdirect.com/lis_png/PLDM/W0503111-00001.png
Aug 27, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
1998 4x4 ford explore driver side door will not
There are long linkage rods from the inside handle to the latch assembly. There should be an adjustment on these links. Too tight keeps latch from locking, too loose it won't unlatch. Use a screw driver or rod to trip the latch asm so you don't have to keep opening and closing the door. Also if it sticks closed and won't unlatch, the door won't be locked closed on you.
Feb 05, 2010 | 1998 Ford Explorer
My screen door got latched somehow in a position so that it is held open. How do I unlatch it so it will close?
On the door there is a round cylinder type closer that keeps your door from slamming closed and lets it gently close. Now, on the rod of that cylinder that is stretched out is a small clip that will go back against the cylinder to hold the door open. Push the door slightly more open and then move the clip to relaese it and more it back the rod, so the door is able to close....
Heatman101
Jan 29, 2010 | Hardware & Accessories
I can't open the rear driver side door on my 2002 Jeep Liberty...any ideas? It locks and unlocks, but when I try opening it by pulling the handle, it appears to be jamming on something and won't open....
the retaing clips have probably broken, and the plunger rod has fallen down in the door, its really hard to get the door panel off with the door closed, but it can be done without destroying it, just gotta be really careful. good luck.!!
Oct 29, 2009 | 2002 Jeep Liberty
Door feels very heavy and falls open when not latched.
There are two springs attached to the door under the machine. They are attached to arms that extend down from the door frame. Turn off the electricity, remove the bottom inspection panel, in the toe kick area, and the lower decorative panel. Probably two phillips head screws in the toe kick panel and one at each top corner of the lower decorative panel. Remove all four.The broken spring is probably lying right in front. Take note as to the way the good one is attached. The manufacturer will have a replacement available, but the local hardware may be faster. Take the spring with you for a match. I would buy two if they have a close match and replace both. Don't buy a longer spring it will just fall off. Yes, a knowledgable handy woman can do this. I'm here on and off until 9 pm est if you need advice.
Jul 06, 2009 | Dishwashers
Left side rear door will not unlatch.
stupid question but did you try inside latch?If so you should be able to remove seat from other side and remove door panel and replace parts (probley clip) as needed or at least open door if latch is defective
Oct 16, 2008 | 1999 Chevrolet Suburban
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
111 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
