Question about Fisher and Paykel GWL11 Top Load Washer
When only used in spin mode, machine refuses to get up to speed, and squeals loudly. Could it be the drum brake which is actuated when the lid is opened?
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting,Now is the machine noisy when the spin 1st starts,this is when the pump starts pumping the water out,or when the bowl is turning.This machine has no drum brake.The polarity on the motor is reversed to stop the bowl from spinning.Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Posted on Sep 03, 2010
THE MACHINE RUNS VERY WELL QUIET UNTIL THE FINAL SPIN CYCLE THEN FROM THE BACK OF THE MACHINE THERE IS A SQUEAL THAT GETS LOADER AS THE SPEED PICKS UP
This may well be the drum drive belt in the back of the washing machine. This belt transfers drive from the motor to the drum for both wash cycles and spinning. If the belt is slipping slightly on the pulley then a squeal may well be heard on the spin cycle and will change in pitch as the speed of the drum increases. At lower speeds (wash cycles) the belt probably won't slip. I don't personally know of this model but there is usually a tension adjustment nut/bolt near the motor to tighten the belt and stop it slipping.
Dec 26, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
My dryer is making a squealing sound
Your drum bearings are wearing out or the belt driving it is spinning. The drum could be binding up and causing it to slow down and brake itself. The belt will continue run at regular speed and cause a loud noise as at literally slides across the drum. Kind of like spinning your tires on the pavement.
Feb 22, 2013 | Maytag SDE4606A Electric Dryer
My washing machine drains,but when on a cycle the drum doesn't move at all and it doesn't go into spin mode?
Check the actuator for the lid switch to make sure it isn't bent or broken. To find the lid switch, look for a pin on the lid that goes through a hole in the top of the machine when the lid is closed. The lid switch actuator is under this hole. If you can't see the actuator lever through the hole, it's probably bent off to the side or broken off. It's also possible to see it, but it's bent down to far to be actuated by the pin. If the lid is bent or the pin is broken off, that would have the same effect.
Apr 04, 2012 | Washing Machines
Washer runs very loud while spinning and stops very loud. Squeaks and squeals!
Sounds like the main drum bearings have failed. remove drive belt, and spin drum by hand, if it feels rough or is noisy, then the bearings have failed.
Please rate my solution.
Thanks.
Nov 05, 2009 | Washing Machines
My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Mar 10, 2009 | Kenmore Washing Machines
Bangs in Spin Cycle even Empty
alot of people don't level there machine properley pull out a level and level the machine what it is when the machine gets up to speed the drum is not level
Feb 12, 2009 | GE Energy Star WCVH6260F Front Load Washer
Drum Speed - Unstable
The spin bearing or basket drive may be worn. When these components are worn-they prevent the drum from spinning freely, and usually you hear a loud sound during the spin mode.
Sep 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Spin cycle doens't work
Your hand probably won't depress the lid switch far enough to actuate it. Use a pencil, pen or old toothbrush handle to press the switch down and see if spin starts. If it starts, the lid actuator is likely broken or out of alignment.
Apr 09, 2007 | GE WBSR3140DW Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
46 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
