Question about Caterpillar American Construction Equipment 1:87 Scale
320 Cat Excavator- engine idles, but does not power up, black smoke come out. Checked the turbo , it's okay. ??????
  • Shawn Mohabir
    Shawn Mohabir Sep 10, 2013
    you sould check your fuel pump and the timing of your engine the problem should be fixed or you should check your fuel line theres alittle strianer in the feed kine bolt take out and clean
320 D Excavator Bzp ..., start-up cannot on , there is
error 39: 590-9, please how to solve this problem, what should I check
Posted on Sep 19, 2013
Please let know the meaning of the code EOM
Posted on Jan 06, 2011
2001 Golf TDI. customer blew the turbo, sucked all the oil out of the engine. Installed new turbo unit, will not accelerate above 2k rpm. Dropped the exhaust to make sure cat. converter wasn't plugged, no...
check inlet valves, turbo can shoot parts into the intake, cause valve seal damage, Check engine compression, it can make is way into the pistons.
Jul 10, 2017 | 2001 Volkswagen Golf
Codes P0101 and P0299. No power off idle and heavy "light" colored smoke. MAF "looks" okay, air filter okay, wire harness at alternator checks okay. No visible air leaks. Turbo suspect,...
P0101 Mass or Volume Air Flow Circ Range/Performance 16485
TSB Number: 3068 NHTSA Number: 10009606 TSB Date: n/a Date Added to File: October 8, 2004 Failing Component:Engine And Engine Cooling:Engine:Gasoline:Turbo-Charger Summary:Oil seepage from turbo air charge cooler hoses or hose blowing off during acceleration. Possible diagnostic trouble code P0299. Updated 04-24-07.there you go good luck
Dec 22, 2010 | 2005 Chevrolet Silverado 2500HD 2WD
330 excavator with a c9 cat engine, heavy SMOKE
Why did you do all of the engine work? Due to the same problem? Have you ran an ET on it to check for codes ?
Feb 25, 2010 | 2006 Lamborghini Diablo
Car smoke white when idle and nothing when driving
Engine also smokes when car driving if turbocharger still faulty. Did you change the engine timing belt (the timing belt kit) meantime? What about engine oil consumption? When engine glow plugs (one or more) burnt then engine exhausts white smoke at idling. Also white smoke at engine idling when water is still present in diesel fuel.
Jan 24, 2010 | 2002 Audi A4
1986 C Lebaron turbo 4 cyl. black smoke when
Black smoke is excessive burnt fuel. White is excessive unburnt fuel. Have your turbo checked and the air filter. Good Luck
Aug 22, 2009 | 1986 Chrysler LeBaron
2000 93 saab black smoke out of exhaust losing power wants to stall out when idling check engine light is on please respond
Sounds like you might have blown a ring on a piston. and the black smoke is oil being burned...find out what the engine code is....but a blown ring usually requires an engine rebuild to fix. Hope this helps.....sorry about the bad news
Jun 09, 2009 | 2000 Saab 9-3 Viggen
Turbo leaking oil
turbo oil seals will cause a lot of smoking .
Apr 02, 2009 | 2003 BMW 330
TDI loss of power
check the hose on the intercooler and around the turbo, check for split on turbo and the intercooler hose not too soft as they can collaps while driving
Jan 07, 2009 | 2000 Volkswagen Jetta TDI
Black smoke, using alot of petrol, no loss of power, funny smell
MASS AIRFLOW SENSOR THERE ABOUT £6O WHEN THEY PLAY UP THE CAR WONT IDLE PROPERLY AND POOR RUNNING/HESITATES BEFORE IT PICKS UP AGAIN, NOT SURE ON THE BLACK SMOKE THOUGH, GOOD LUCK .
Oct 05, 2008 | 2001 Volkswagen Golf
Caterpillar American Construction Equipment 1:87 Scale Logo
760 people viewed this question
Top Caterpillar Toys Experts
fordexpert
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
