Question about Pioneer DEH-P730 CD Player
Pioneer Premier DEH-P730
Does anyone know the wiring for this deck? i just bought one used and hooked up the red and black wire but there are 2 yellowish ones? like no power when i try either one... is this deck toast or am i doing it wrong?
    Brigadier General:
  • 6,966 Answers
Pioneer follows standard color coding for stereo/headunit wiring. Pioneer car stereos needs two wires plus the ground wire to be activated. The yellow is connected to the always on B+12 such as the positive terminal of the battery, the red goes to a switched B+12 such as the ACC of the IGN switch while the black of course goes to the chassis/body ground.
Should the above been done correctly and problem persist, then perhaps the fuse may have blown, there is a loose connector at the rear of the head unit or a probable internal electronic defect has developed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 11, 2008
I bought the deh-2200ub to replace an infinity stereo in a 2005 kia optima. There's less wires on the pioneer, which I just taped off, I have no sound. AARRRGGGGGG!!!! help
Hi, the wires should be connected as indicated below. Please let me know if you have questions, and thanks for using FixYa.
2005 Kia Optima Car Stereo Wiring Schematic Pioneer wire color
Car Radio Battery Constant 12v+ Wire: Orange yellow
Car Radio Accessory Switched 12v+ Wire: Yellow red
Car Radio Ground Wire: Black/White black
Car Radio Illumination Wire: Brown/White none
Car Stereo Dimmer Wire: Gray none
Car Stereo Antenna Trigger Wire: Gray blue/white
Car Stereo Amp Trigger Wire: Green blue/white (same as above)
Left Front Speaker Positive Wire (+): Yellow white
Left Front Speaker Negative Wire (-): Black white/black
Right Front Speaker Positive Wire (+): Blue gray
Right Front Speaker Negative Wire (-): Red gray/black
Left Rear Speaker Positive Wire (+): White green
Left Rear Speaker Negative Wire (-): Brown green/black
Right Rear Speaker Positive Wire (+): Orange violet
Right Rear Speaker Negative Wire (-): Green violet black
Apr 10, 2011 | Pioneer DEH-P4000UB CD Player
NO POWER TO MY DECK
wire it to the live wire most older cars don't have 6 wire config while nearly all new stereos do connect all other wires as they were on the loome but wire the ignition wire to your cars live bypassing the ignition
Jun 01, 2009 | Pioneer DEH-2300 CD Player
NO POWER TO MY DECK
Hello clarky909,
On your Alero, the 12V constant wire is ORANGE and should connect to the YELLOW wire coming from the DEH-2300 wiring harness. 12V switched on your Alero is YELLOW and should be connected to RED coming from the DEH-2300.
Hope this helps.
Pioneer deh-2000r wiring
Pioneer usually use:
red - 12 volt batt. ignition/acc
yellow - 12 volt batt. memory
black - ground
blue - power ant.
blue/white - amp turn on
orange - illumination ( 12 volt light ) ( not all deck )
orange/white - dimmer ( not all deck )
gray - right front +
gray/black - right front -
white - left front +
white/black - left front -
violet - right rear +
violet/black - right rear -
green - left rear +
green/black - left rear -
Is this what your looking for?
Dec 01, 2008 | Pioneer DEH-1600 CD Player
I need a wiring harness for my deh-p730
Most Pioneer units follow the below detailed color codes for the wiring.
Yellow - +12V Constant Power
Red - +12V Switched (accessory) Power
Blue - Power Antenna
Blue/White - Amp Turn-on
White - Left Front Positive Speaker Wire (LF+)
White/Black - (LF-)
Gray - Right Front Positive Speaker Wire (RF+)
Gray/Black - (RF-)
Green - Right Rear Positive Speaker Wire (RR+)
Green/Black - (RR-)
Purple - Left Rear Positive Speaker Wire (LR+)
Purple/Black - (LR-)
Jun 16, 2008 | Pioneer Car Audio & Video
DEH-P580MP
If you are referring to the presets tuner station settings being deleted when powered off and or the clock resetting its time, then you have to verify that the Pioneer DEH-P580MP is wired as follows:
Black - chassis/body ground/GND
Yellow - always on/constant B+12 such as the + terminal of the battery;
Red - switched on B+12 such as the ACC of the IGN switch.
Mar 28, 2008 | Pioneer Premier DEH-P580MP CD Player
Pioneer Premier DEH-P680MP
more importantly the yellow is key hot and the red is constant
Jan 31, 2008 | Pioneer DEH-P680MP CD Player
Pioneer DEH-225 Car Audio
The system remote control is usually a blue wire on your decks harness and it is for an amplifier for a sub or other speakers. It sends power to the subs amp when the deck is turned on. You may need to find the wires coming off the antenna and splice them into the red power switching wire 12v on you decks wire harness. Good luck
Oct 07, 2007 | Pioneer DEH-225 CD Changer
Pioneer deh p730
Has it always been like this? I know that the display inverts automatically to save the life of the OEL...otherwise the brightness of the same pixels being on all the time will cause the OEL to 'burn-in' If that isn't the problem, the OEL is going bad. They can run about $100 and usually aren't worth repairing.
Aug 14, 2006 | Pioneer DEH-P730 CD Player
Pioneer DEH-P730 CD Player Logo
370 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
