Question about Hoover U8171-900 / U8172-900 / U8173-900 / U8174-900 Savvy Bagless Upright Vacuum
Belt change on savvy upright
How do you change the belt
  • linda79 Aug 25, 2008
    I did as described...but found a smooth pulley between the brush and the ridged pulley. I'm assuming the belt needs to go over both, and I'm unable to figure out how to get it over the smooth pulley as it seems to be tightly enclosed. I have the U8174900
    President:
  • 1,673 Answers
Take off the bottom plate, also remove the screwsfrom the bottom to remove the top cover, also there is a screw under the Hoover emblem on the top cover, with these removed you can get to to brush roll and belt.
Posted on May 15, 2008
Replace belt on Hoover savvy vacuum
There is not a brush belt on your model. It has a drive mechanism that turns the brush rolls.
Feb 20, 2016 | Hoover U8145-900 Savvy Bagless Upright...
How to change belt on hoover savvy vacuum
How do I change the smaller brush belt on a Hoover Windtunnel Cyclonic?
Jan 11, 2010 | Hoover U8145-900 Savvy Bagless Upright...
Roller bars on bottom not rolling
The belt has probably broken. Hoover says that the belt on this model should last the life of the vacuum, but that is rarely the case. They do wear and break. Changing the belt is simple and the belts aren't to much. You can get a replacement here:
Savvy Replacement Belts
Oct 30, 2009 | Hoover U8145-900 Savvy Bagless Upright...
Changing the belt
If this is a Savvy, then take out the screws for the bottom plate, then remove the screws that hold the top on, turn the vac over, and remove the Hovver emblem, there is a screw there, then the top cover comes off and you can replace the cogged belt.
May 31, 2008 | Hoover U8185-900 Upright Vacuum
Hoover US8174-900 Savvy Bagless
It uses a cogged belt, turn it over, remove the bottom plate, remove the other screws from the bottom, turn vac back over and remove the Hoover emblem, there is a screw there to remove and the top comes off, then you can get to and replace the belt.
May 26, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover savvy changeing belt
There some screws on the bottom to take off, then turn vac upright, under the round Hoover logo sticker is another screw. It is just a sticker, so will peel off. You can work the belt onto the motor pulley, or unscrew the motor, put the belt on the pulley, then reinstall the screws to hold down the motor.
Jan 06, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover U8171-900 / U8172-900 / U8173-900 / U8174-900 Savvy Bagless Upright Vacuum Logo
277 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
