Question about Furuno GP31 GPS Receiver
Furuno gp31 Everytime i go to put the pin in the back of the gps unit it blows the 2 fuses on the +/- wires to the battery. What am i doing wrong?
I dont think you should have a fuse on the - wire its only a return to earth its like closing the stable door after the horse as bolted
Posted on Sep 20, 2008
Antenna GPS Tram 1655 is compatible with GPS FURUNO?
If the Furuno unit you're referring to uses a GPS antenna with a coax (i.e. GP31/32) then the Tram antenna will work but the connector is wrong. The Tram antennas usually come with BNC connector and Furuno uses a TNC. Will need an adapter.
Oct 14, 2013 | Furuno GPA019S GPSDGPS HField Antenna...
Radar install problem
the GP31 has an NMEA in/out in the power cord - out is yellow green in blue(or black) and white on the 1833 you will use data 4 typically which has an in and out also, same colors hook out to in and in to out, program and done
Mar 23, 2009 | Furuno 1833C/NT GPS Receiver
LCD furuno GP31
Contact your local West Marine, Boater's World or contact Furuno directly.
http://www.furuno.com/
Mar 12, 2009 | Furuno GP31 GPS Receiver
Furuno gps wiring diagram for usb
Hello!
I have the connection diagram for the GPS unit below.  It should be simple to wire up.  You will need a USB to RS-232 converter, which is available in a number of computer shops/Radio Shack.
Hope this helps you out,
Jan 06, 2009 | Furuno GP31 GPS Receiver
Furuno GPS 30 Receiver
When the GPS unit was wired in reversed, a number of the electronic components would be damaged. However, in most units (but not all), there is a component specifically made to sacrifice itself to go dead in such event(s) other than the fuse. The is often called the reverse protection diode. This would normally be connected right after the power entry point after the fuse. In some designs, it would be after the power ON/OFF switch. Should there be no such diode, then next in line to be the most likely culprits would be capacitors, transistors, ICs, other diodes (specially zeners). If the trouble is basically limited to power supply, familiarity with electronic components and circuitry, use of a DVM and a soldering iron should be sufficient to initiate diagnosis and repairs.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 14, 2008 | Furuno GP31 GPS Receiver
Can we connct furuno gp31 to pc
Hello!
Yes, the GP31 can connect to a PC.  With the wiring harness, it has an RS-232 port, which allows it to connect to most PCs, laptops, and even most palmtop systems.
Ken
Sep 19, 2008 | Furuno GP31 GPS Receiver
Furuno GP31 - PC wiring instructions
try
http://furuno.inforce.dk/graphics/14_Softwares/09_gps/FURUNO_GP-32_pc_connect.pdf
Jun 27, 2008 | Furuno GP31 GPS Receiver
Furuno GP 30-35 GPS
je viens de prendre possession d'un gps furuno 30/35 Jje n'arrive pas a afficher ma route pour allaer d un point a un autre merci de m'aider
Jun 14, 2008 | Furuno GP31 GPS Receiver
Furuno GP31 GPS Receiver Logo
241 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
