Question about Microsoft Xbox 360 Console
Over heating when i turn my xbox on the first five minits i play it over heats i put fans on it and it still over heats
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 58 Answers
Great solution adam8117, I couldn't have it better. Just make sure you have plenty of air flowing in and out the console and buying a cooler is deferentially a smart move!
Posted on May 11, 2008
  • Daniel9
    Daniel9 May 11, 2008
    I forgot to ask...
    Do you get any red lights? are you still under warranty?
  • 47 Answers
Ventilation is better if it is sittion horizontally, as opposed to vertically. Also, keep it off carpet and give it plenty of room to breathe. Make sure the vent is clean and clean the area regularly to keep dust away. Also, make sure the fans are working. You can also buy the cooler that sets under it to help keep it cool, though a regular fan usually works and is much cheaper.
Why does my xbox turns off after 10 -20mins play
it could be over heating check the fan is working and not covered in dust buildup, failing that the prossesor is over heating as its coming away from the board.
May 01, 2014 | Microsoft Xbox 360 Console
How do I fix an E74 code on my xbox 360
U NEED TO OVER HEAT UR XBOX 360 BUY STOPPIN THE FANS WEN U BOOT UR CONSOLE UP IT WILL TAKE ABA 2 MINS IF THAT TO OVER HEAT IT WILL INDACATE ON THE RINGS WEN ITS OVERHEATD IT WILL SHOW TWO LIGHTS ON THE LEFT THE TURN XBOX OFF WAIT FOR IT TO COOL DOWN TO ROOM TEMP THEN TURN ON AND PLAY
Nov 26, 2010 | Video Game Consoles & Games
After playing 15 minutes two red lights flash and xbox shuts down
the xbox 360 is overheating. Try to clean the vents and have it elevated off carpet or anyhtign that will not allow it to get a airflow.
Check the fans in the back of the 360 to be sure they are running ok and not blocked up.
May 16, 2010 | Microsoft Xbox 360 Console
My xbox 360 keeps over heating, i dont play for very long and it over heats. i put fans on it and it still over heats. what do i do?
I recommend you try sitting close to some windows, and open the windows, use fans, and mabye not play so much :D
Apr 07, 2010 | Microsoft Xbox 360 Console
My Xbox keeps switching its self off after five minutes and then two red lights are coming on on the console. Do you know what would be causing this?
Yes I do . Some times when console take a fall or get bump hard
it will dislodged the heat sink from the C.P.U. breaking the thermal
seal . Then the console will over heat in 1-5 min .
The Fix is simple . open the unit up and press down evenly
and firmly on the large heat sink to re-seat it to the C.P.U.
leave it open turn it on and repeat if it over heats again ,
sometime it takes a few attempts .
Rob
Oct 08, 2009 | Microsoft Xbox 360 Console
2 red flashing lights
The Xbox console is overheated.
  1. Let your Xbox 360 console cool. You may have to wait several hours for your console to cool enough. Don't turn on your Xbox 360 console when the console is hot.
  2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating.
  3. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support.
To try to prevent this problem, follow these precautions:
  • Don't block any ventilation openings on your Xbox 360 console.
  • Don't put your Xbox 360 console on a bed, on a sofa, on a carpet floor, or on any other soft surface that may block ventilation openings.
  • Don't put your Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Don't put your Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
Taken from Microsoft support.
Best of Luck.
-Mind
Jun 30, 2009 | Microsoft Xbox 360 Console
Xbox 360 overheats on startup
there could be hardware problems! mine never gave the two lights when it started it but when playing certain games it overheated and thats whats happening.. i got upset and opened mine up[ voids warrenty for three red lights] and added a 3 inch fan with a 12 v converter for its on power. i set it in on the heat sink and the bottom right corner of the xbox..
so i think you should get a powerful 3inch by 3inch fan with its on power supply and set ur xbox so you can point the fan at the bottom of the xbox! this will help! dont open ur xbox just set a powerful fan[ radio shack, walmart, hardware store] and let it cool the bottom of ur xbox!!!!!!!!
Cheapist way
!!items needed!!!
1. 12 v dc brushless fan
1. 12 volt ac power adapter that hooks up to the wall and the fan for a Direct Current!
thats it may cost over 20 and walmart is cheap and a little less quality
but as long as air pushing on the bottom of ur xbox is moving fast[ dont put the fan to close] so heat is transfered ur good
Jun 19, 2009 | Microsoft Xbox 360 Console
Over heating
If you don't get any red light I suggest on using a cooler.
If you do and you are under warranty sending back to Microsoft will be your best choice.
May 11, 2008 | Microsoft Xbox 360 Console
Xbox360 problem
the fans heat reactor must have gone bad your system is over heating, your xbox must not think it is over heating (lol) put it near a cold place or open window or a place with lots of room
chris
Mar 31, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
