Question about Yamaha TX-497 2 Channels Tuner
Finding a compatible remote
I have bought a new Yamaha Tx-497 AM/FM Receiver. It has a remote sensor, but no remote control is provided with it. The manual says a remote for a Yamaha AV Receiver or amplifier will work with it, but there are a great many available. I would like to find a remote control that will work with this receiver, and any help I can get would be greatly appreciated. Thanks
  • 1,512 Answers
Hi there, this may take a little research to find, back to you real soon
regards
robotek
Posted on May 11, 2008
  • 1 more comment
  • Graeme Ross
    Graeme Ross May 11, 2008
    You can get many replacement remotes that are called universal remotes, that will do the job for you. Price becomes a contributor to the product that you eventually get. They range in price from $30 to $300. How much did you wish to spend?
  • Graeme Ross
    I just did a search on ebay also. There are many Yamaha remote that are going cheap. You can use just about any yamaha receiver remote for your unit as the coding used has remained the same over the years with Yamaha
  • Graeme Ross
    This one is a cheapo Yamaha remote that would work for you
    This one or this one could also do the job for you, and being programmable, run your other electronics as well. I can get the instructions for you if you go for one of those 2.
    I checked that Yamaha dont have one for it, but it seems that they dont. They say that ANY Yamaha remote will work.. guess thats how they can sell this model for such a great price, a remote hand piece adds to the sale cost.
    Oh, and I forgot to ask, you dont have a universal remote already do you, because I could get you the codes that will make it do the job for you.
I need codes for a Yamaha rx-v2500 receiver. The codes listed turn it on but not off. Can you help??
Joseph, codes 0081,0082,0176, 0186, 1176, the attached manual may have more codes.
Yamaha rx-v2500 receiver, try the auto programming feature on your remote to set up universal remote. It is possible the remote may not support your equipment and you will have to replace with compatible remote. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RC Yamaha RX V2500 Receiver and DVR PVR 5 HELP
Codes for Universal Remotes Codes for Universal Remotes How to Program Universal Remote
Yamaha RX V2500 Owner Manual Setting Remote Control Codes
Aug 08, 2016 | Yamaha Audio Players & Recorders
Can I find a compatible remote control for my Denon AM FM Stereo Receiver
If you know you model number you could try using the following website. http://EzRemoteFinder.com
Just enter in the manufacturer and model number of the remote or receiver and this website will search several websites on the internet for a compatible remote. Best of luck!
Looking for that lost remote control
May 15, 2016 | Denon Audio Players & Recorders
Trying to control Zenith DTT900 box with Yamaha RX-V463 remote
Since Insignia and LG share compatible codes for digital-to-analog converters, review your remote control's manual for LG VCR codes as they should work to control the Insignia converter.
Feb 26, 2010 | Yamaha RX-V463 Receiver
Onkyo remote won't control Samsung components.
I got an Onkyo RC-717M remote control. It is the remote that comes with the Onkyo TX-SR706 receiver. It is a learning remote. When i entered the cde for the Samsung Blu-Ray it did the same thing as the other remotes I got from Onkyo, the pause, next / previous track buttons wouldn't work for the Samsung BD-P3600. I used the learning function of the new remote and programmed it to work. It works ok now but it sure was a hassle to get it done. In fairness i should have called Onkyo support but their support hours don't match my schedule.
Sep 12, 2009 | Onkyo TX-SR606 Receiver
Unit does not respond to remote control
I had this same problem with the Onkyo TX-SR706 this evening, and finally found the solution in the "Controlling Other Components" section of the manual: Resetting the remote control did the trick. (P.S. This problem started after I spent many hours today trying to get my new Acer laptop equipped with a Hauppauge TV tuner stick to correctly display its image on my Samsung HDTV, with sound. I tried connecting the laptop via HDMI first to the Onkyo receiver and then directly to the TV, neither of which worked as it should. I assume that somehow, in all those hours of much plugging and unplugging and fiddling around, I screwed up the remote sensor -- thank goodness I eventually found the "Resetting the Remote Controller" solution a little while ago -- I was approaching the point of ripping everything apart and throwing it out the window!)
Jul 06, 2009 | Onkyo TX-DS575 Receiver
What's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
Dec 30, 2008 | Yamaha HTR-6130 Receiver
Remote Control codes to control other brand devices
i have sony receiver codes 31759, 30158, 31758,
or 4 digit codes 0158 and 1758
Dec 01, 2008 | Yamaha Televison & Video
Cant find universal remote code for the onkyo tx-sr605
Your onkyo receiver and remote controller only decodes 4 digit codes so what you have to do is to call the manufacturer of the remote controller it self and ask for the hexa decimal codes for their remote. They should provide it to you coz they're the ones responsible on doing that.
Nov 27, 2008 | Onkyo TX-SR605 Receiver
Remote for Yamaha TX 497
oh hey... didnt see this ask:) I have posted some info at your original post here. Go have a readup and let me know how you go :)
regards
robotek
May 11, 2008 | Yamaha TX-497 2 Channels Tuner
Yamaha TX-497 2 Channels Tuner Logo
123 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
